[NOT SUPPORTED] I2C on GD32F103C8T6
logd32
Post by logd32 » Thu Sep 07, 2017 8:55 pm
HI,
I am using STM32Duino with the GD32F103CBT6 core and i face a weird issue. The I2C scanner get stuck after hardwire init while the exact same code works perfectly on the same board with STM32F103CBT6, is there any specificity to GD32 regarding I2C and (hard)wire ?
Did anyone ever used I2C (sda,scl, no reset) OLED with GD32?
Re: I2C on GD32F103C8T6
Post by RogerClark » Thu Sep 07, 2017 9:09 pm
We found that the GD32 is not actually hardware compatible with the STM32.
Hence the community decided to remove GD32 from the list of supported MCUs, a few weeks ago.
You could try using software I2C, but as hardly anyone else now uses the GD32, you probably need to post your question to a GD32 forum
martinayotte
Post by martinayotte » Thu Sep 07, 2017 9:10 pm
Do you have PullUps on both SDA/SCL ?
logd32
Post by logd32 » Thu Sep 07, 2017 10:14 pm
OK i see GD32 support i now dropped. I will maybe change to STM32 since its pin compatible. Yes 10K pullups on SDA and SCL. The only thing i noted is when OLED is not powered (only SDA and SCL are connected) the init goes a tad further so it displays "Scanning..." otherwise it stalls at "I2C Scanner". The exact same code works normally with STM32, OLED address is found with or without pullups. note: if OLED is not powered it displays "scanning" but still stalls right after
Post by RogerClark » Thu Sep 07, 2017 11:17 pm
Good idea
Things will be much easier to get working if you use the STM32 as there is much more community and official support for the STM32
Re: Pullups
10k is far too high.
2.7k seems to be the recommended value for 3.3V systems
