Is anyone interested in helping to make an Arduino Due which uses [edited:] a 100-pin STM32L471
lkcl
Re: Is anyone interested in helping to make an Arduino Due which uses a 100-pin STM32F072 (or something else more suitab
Post by lkcl » Thu Sep 28, 2017 12:26 pm
edogaldo wrote:
Thu Sep 28, 2017 9:19 am
What could be the target price for this board?
Consider that on ebay you can buy chinese Due clones (with original SAM3X8E, MEGA16U2, etc) for 13$ each which grants you real full compatibility if you really need a Due board.
hiya edogaldo, yes i'm here in Taiwan, my friend in HK is going over the border to SZ to speak to factories, the 2560 arduinos are a *lot* less than $13 in the Huaquiang Rd markets (around the $6 mark), but he's finding it difficult to get Dues there so went to a factory: they quoted $16 to him. this is all for a 3D printer: RAMPS 1.4 plus 4x A4988 polulu drivers plus Mega2560... $16. incredible.
anyway yes: given that the Mega2560 Arduinos are around $6 i'm generally... objecting to prices of $USD 16 :) i'd be very very happy to meet a target of $9 to $10 for something with an STM32F.
lkcl
Re: Is anyone interested in helping to make an Arduino Due which uses a 100-pin STM32F072?
Post by lkcl » Thu Sep 28, 2017 12:43 pm
david.prentice wrote:
Thu Sep 28, 2017 9:26 am
The F103 is a fairly elderly M3 chip.
ahh that would explain why it's lower-cost
Its only redeeming feature is that Chinese BluePills and MapleMinis are very cheap.
hmmm... then it sounds even more attractive, as it means that it's popular. popular means mass-produced prices. mass-produced prices gooood :) also it means that the software support (i've been a fan of libopencm3 in the past) will be stable.
It has been succeeded by much better M3 and M4 chips
If you want a Due replacement, you would be looking at a Cortex-M3 or M4 chip with similar number of pins to the elderly SAM3X M3 chip that is used in the Due.
The STM32L4xx series would seem the obvious choice. They can run fast when required and consume low power if necessary. As well as having large memory and good peripherals.
and an on-board FPU, darn. i like them... but... argh, the STM32L496ZET6 is $5.48 in 10k (which means it would be around... nearly $6.50 in 1k volumes) and the other one which would fit the requirements is the STM32L471ZET6 which is $4.68 in 10k volumes.
with those kinds of pricing it doesn't quite justify the time and effort spent to end up with something *more costly* than an existing Arduino Due! :)
The F072 is a M0 chip with performance not much better than an AVR. Hardly a design for the future.
aww i know that noooow :) i didn't quite realise quite how stark the difference is between the STM32F072 range and the others that are available.
Having selected a suitable MCU, you want to think about which pins to route to the Digital and Analog headers.
IMHO, the Mega2560 assignments were crazy. Not a single XCKn pin is accessible for any of the four USARTs.
And the Due assignments are not very compatible with legacy MEGA headers.
that probably explains why the arduino company itself stopped making the Due (or did i get that wrong? read it somewhere... my memory's vague sometimes)
i did notice though that the 302 only has one DAC... i caaan... probably live with that.
If you address these design issues, it could be a viable project.
well, i'd really appreciate some input on pin-assignments. obviously they have to be compatible with a Due's *main* functions, but these MCUs have multi-function, so there really should be a way to get decent pin-outs that keep people happy.
If successful, it will be cloned by Chinese manufacturers.
You will receive nothing for your time and effort. The world gets cheap hardware. Much like the enthusiasm for BluePill.
and when there's cheap cloned hardware... i get to buy it! win-win! :) maybe they even cloned it correctly and didn't botch it, in which case i can buy 10 of them in the markets for the target application.
ChrisMicro
Re: Is anyone interested in helping to make an Arduino Due which uses a 144-pin STM32F072 (or something else more suitab
Post by ChrisMicro » Thu Sep 28, 2017 4:37 pm
I think the huge afford to make such a board only makes sense if it has more features than an Arduino DUE.
This could be more memory or a higher speed.
I used the DUE. The big disadvantage is that it doesn't have floating point.
My recommendation: take a MCU with floating point for your design.
lkcl
Post by lkcl » Thu Sep 28, 2017 4:49 pm
that's a good point, chris. i was focussing on price, not features. going the opposite direction (less memory, less flash, not more). about the FPU, you make a really good point, for example one of the things about RepRapFirmware is: it deliberately uses floating-point calculations even though the ATSAM3XE doesn't have a FPU (Marlin firmware certainly can't even attempt that as it's designed for 8-bit MCUs).
sooOoo.... that would actually favour david's suggestion, to use the newer 417. even if it's $5.50 as opposed to $4.18 (10k volumes). if i cut out the "management" feature of the Due (the 2nd microcontroller and 2nd USB port) and you flash the STM32 directly (i do that all the time anyway), that gets some of the cost back.
hmm.... ok will find the 417's datasheet.
lkcl
Post by lkcl » Thu Sep 28, 2017 5:11 pm
david, chris: the STm32F471ZE is niiice. $4.18 in 10k volumes. Cortex M4, FPU, 128k RAM, 512k FLASH (there's a version that has 1M), two DACs, 3 12-bit ADCs, PWM, SPI, UART - it even has SDMMC (niiiice). strangely it doesn't support USB which, given that so many others in this range do seems... odd, but hey. an FT230 will sort that.. :) section 3.7 of the datasheet: DFU mode is accessible using UART, I2C, SPI and CAN.
section 3.9.... ADC/DAC from 1.62/1.8 to 3.6v... looks good... all other VDDs go up to 3.6v as well... yeah i really like this one.
lkcl
Post by lkcl » Thu Sep 28, 2017 6:34 pm
http://www.engtaobao.com/item/556523180276.html
i checked the arduino mega, strangely that uses an 100pin not a 144pin... i also checked the equivalent of ebay... um.... $1.42 plus $1.98 shipping... yes these people are for real. no i am not going to buy from them. i'll ask a friend to check pricing properly. because of this sort of thing, see photos https://world.taobao.com/item/555750494028.htm
note description, says "USB"... sigh...
Post by RogerClark » Thu Sep 28, 2017 9:53 pm
@lkcl
Rather than putting your effort into making a board that is physically compatible with the Due, I think there is a much bigger market for a F4xx version of the BluePill
There have been a few discussions about this, and there used to be a board available called the STM32 Stamp, which is very similar to what I am suggesting.
But AFIK, its not currently in production and was very expensive as it was made in small quantities in the USA
We have plenty of people on the forum, who are totally able to do the CAD as far as PCB, but AFIK no one has contacts in China who could get a board manufacturer eg. populated with components at the sort of prices that the chinese companies seem to be able to do it.
We would need a Chinese partner company who would do all the manufacturing and make the boards available on AliExpress, probably through multiple third party companies.
This would not give anyone outside China any fiscal return on investment, but we would get a board that would be very popular and most likely sell in reasonable quantities
Edit
STM32 Stamp details including Eagle schematic and PCB files are here http://eleccelerator.com/stm32f4stamp-breakout-board/
I looked at the specs on the F405RGT and the main reason its used on the STM32 Stamp as its one of the few F4 processors in a small footprint, but has less IO's because of this
There is also the F415RG which seems to also have crypto, but I suspect there would be very little call for this by most Makers.
I can see 405RG's on AliExpress for
https://www.aliexpress.com/item/STM32F4 ... a1f23bab1f
US $4.25 / piece in quantities of 20, which isnt that bad....
lkcl
Post by lkcl » Fri Sep 29, 2017 12:06 am
@lkcl
that would be interesting... i should mention that i have a chain of requirements which means i (personally) would need to go via the due form-factor first: i'm doing an upgraded (open) version of the RAMPS 1.4, because RADDS 1.5 (the closest thing to it) is... proprietary. *sigh*. and sourced from EU/USA (digikey / mouser). eurocircuits is damn good but when the components are 4-5x the price because of tax, shipping and middle-man markups....
however i'm more than happy to help (and perhaps start a different thread?)
https://world.taobao.com/item/415598160 ... 0b62jQ1bU1
$0.81 on the china-version of ebay, selling for around double that with actual components. mad. absolutely mad.
... for now!! living costs in shenzhen now actually exceed london: most chinese people are moving progressively further out. i was able to stay at a hostel for $5 / night until the police dropped by (cameras on the street corners...) and found that they'd not registered for foreigners... whoops.
yeah i can help with that for sure. i have my regular contacts - a friend (mechanical engineer) who lives in HK, he does QA and Sourcing. does destruct-testing to make sure that factories have enough fire-retardant in the plastic, electrical safety checks, much more besides. the other main one is Vast Electronics, young guy, just taken over from his father about 3 years ago, very very conscientious... but also like everyone right now REALLY busy until after the main holidays beginning october. basically that's the time that everyone in the West rushes things ready for Xmas. so, mid-october he'll be back, and a hell of a lot less stressed out and able to help immediately. beyond that i have a couple others.
sounds absolutely great. i'll need gerbers and a BOM to get some quotes.
Edit
.... which are probably here! :) or i can generate them. can i suggest starting another thread for this one, roger?
http://www.st.com/content/st_com/en/pro ... 405rg.html
woww that's a nice set of specs. *shocked*... $5 in 10k volumes, what the hell is going if it's being sold - on an actual board - in china - for $2 for??? uhn??
well, the main thing is, buying using someone you trust because if they screw you and it's already outside of china, it's A a 30% taxable return item due to customs duty (or it will just... "disappear" at customs... had that happen...) and B as you're not a chinese national they don't actually have to do jack. agents (engtaobao) are good for this because their reputation is critically dependent on you not shouting loudly and publicly "i got ripped off!"
also... it's uuuusually a good idea to use someone in china who can actually inspect the goods... otherwise they tend to go "oh uh yeah we couldn't get that part cheaply any more.... so we just decided without telling you to totally replace the product with something else. are you phoning to place a repeat order? we'll take your money nooo problem".
*face-palm*....
[my friend in HK had to help out a client that bought USB sticks for the OLPC XO-1 laptops... samples no problem, first batch no problem, 2nd batch of 1,000... totally different IC, way cheaper... and not properly USB-compliant so the XO-1's BIOS refused to boot off of them because... yeah long story....]
anyway yes, great idea. will have to wait a bit though, my friend delayed his trip back to the UK because of helping out SZ clients before the holiday rush. he'll be back in... a couple of weeks, we can get some quotes then.
Post by RogerClark » Fri Sep 29, 2017 1:05 am
I'll export the files from Eagle to KiCad and stick them on GitHub, and start another thread
Re: Manufacturing in China
I know a trustworthy company in China, who I have used to get a nRF51822 Bluetooth "SmartBeacon" manufactured in small quantities (100 off) for a prototyping and field trials...
But the cost of boards made by them, are a lot higher than companies like Vcc-Gnd seem to manage (probably because of volume, but also I don't think they are quality for the special economic discounts etc that some companies in China seem to take advantage of)
I but I'll see if I can get a quote from them to manufacture (even though they are mainly a design house, and actually sub contract any volumes more than about 10 items - which they hand reflow solder)
I agree about parts supply, but AliExpress are probably better than eBay in terms of the escrow, and getting your money back if the item delivered is not as advertised.
Still... Buying though AliExpress is not viable for actual production, its only useful for making reasonably priced prototypes.
Post by RogerClark » Fri Sep 29, 2017 2:05 am
Eagle2Kicad seemed to do a reasonable job on the schematic, but at the moment the PCB looks like it didn't convert :-(
