hardwire i2c hotplugging
arpruss
Post by arpruss » Thu Oct 12, 2017 2:22 am
I've been wanting to use hardwire i2c with a device -- Wii Nunchuck -- that I want to be able to plug and unplug while the stm32f103 is running. No luck. It works fine if the device is plugged in permanent, but if I unplug, I get a hang. It works perfectly with the bit-banged i2c. Any suggestions?
Re: hardwire i2c hotplugging
Post by RogerClark » Thu Oct 12, 2017 5:47 am
Any idea which end is hanging
Did you try removing the battery from Nunchuck and re-inserting it, before you tried to plug it back into the STM32
Did you disconnect the Numchuck from the STM32 half way though a data transfer etc ??
racemaniac
Post by racemaniac » Thu Oct 12, 2017 6:41 am
probably the i2c port getting into an error state, and then hanging until you reset it.
have a look at the registers of the i2c port, see which ones you have to read to determine error states :)
arpruss
Post by arpruss » Thu Oct 12, 2017 12:47 pm
The Nunchuck draws power from the the connection, so when I unplug it, it gets unpowered and hence reset.
