FreeRTOSConfig.h parameters editing
paksoft
Post by paksoft » Fri Nov 03, 2017 10:05 am
Hello Dude,
I'm new to FreeRTOS and studying the book from FreeRTOS. I'm trying to test Idle hook function, so I need to edit parameter of FreeRTOSConfig.h (configUSE_IDLE_HOOK -> 1).
My hardware is STM32F103C8T6 blue pill from ebay and my code is as follow:
#include <MapleFreeRTOS821.h>
/* The task function. */
void vTaskFunction( void *pvParameters );
/* A variable that is incremented by the idle task hook function. */
static unsigned long ulIdleCycleCount = 0UL;
/* Define the strings that will be passed in as the task parameters.  These are
defined const and off the stack to ensure they remain valid when the tasks are
executing. */
const char *pcTextForTask1 = "Task 1 is running\r\n";
const char *pcTextForTask2 = "Task 2 is running\t\n";
	/* Create the first task at priority 1... */
	xTaskCreate( vTaskFunction, "Task 1", 1000, (void*)pcTextForTask1, 1, NULL );
	/* ... and the second task at priority 2.  The priority is the second to
	last parameter. */
	xTaskCreate( vTaskFunction, "Task 2", 1000, (void*)pcTextForTask2, 2, NULL );
	/* Start the scheduler so our tasks start executing. */
	vTaskStartScheduler();
	for( ;; );
void loop() {}
char *pcTaskName;
	/* The string to print out is passed in via the parameter.  Cast this to a
	character pointer. */
	pcTaskName = ( char * ) pvParameters;
	/* As per most tasks, this task is implemented in an infinite loop. */
	for( ;; )
		/* Print out the name of this task AND the number of times ulIdleCycleCount
        has been incremented. */
		Serial.println(pcTaskName);
		Serial.println(ulIdleCycleCount);
		/* Delay for a period.  This time we use a call to vTaskDelay() which
		puts the task into the Blocked state until the delay period has expired.
		The delay period is specified in 'ticks'. */
		vTaskDelay( 250 / portTICK_RATE_MS );
/* Idle hook functions MUST be called vApplicationIdleHook(), take no parameters,
and return void. */
void vApplicationIdleHook( void )
	/* This hook function does nothing but increment a counter. */
	ulIdleCycleCount++;
My problem is that Maple Mini is hanged, after upload sketch to the board.
If I restore back (configUSE_IDLE_HOOK -> 0) of FreeRTOSConfig.h, and upload the sketch and no hang, but ulIdleCycleCount is not counting as expected.
Any suggestion and advice are greatly appreciated.
pak
edogaldo
Re: FreeRTOSConfig.h parameters editing
Post by edogaldo » Fri Nov 03, 2017 1:20 pm
Try with:
extern "C" void vApplicationIdleHook( void )
	ulIdleCycleCount++;
paksoft
Post by paksoft » Fri Nov 03, 2017 3:16 pm
Thank you for quick response and helpful advice.
It's working now, so extern "C" is used for calling a C function from C++.
edogaldo
Post by edogaldo » Fri Nov 03, 2017 4:58 pm
Pak, now I have a question for you: if I try your example with only one task, everything is working fine; if instead I add the second task then the program hangs..
So questions:
  • when did you last get the Libmaple core code?
  • what OS are you using?
  • which version of Arduino GUI and GCC compiler are you using?
  • which board and board options are you using?
Thanks in advance and best, E.
paksoft
Post by paksoft » Sat Nov 04, 2017 5:33 am
Hello edogaldo,
Thanks for your help.
when did you last get the Libmaple core code? -> Recent one https://github.com/rogerclarkmelbourne/Arduino_STM32
what OS are you using? -> Win 10
which version of Arduino GUI and GCC compiler are you using? -> Arduino IDE v 1.6.9 and follow instruction from https://github.com/rogerclarkmelbourne/Arduino_STM32
which board and board options are you using? -> STM32F103C8T6 blue pill from ebay
Here is my another working code:
#define pinLED  PC13   //For STM32F103C8T6
static uint32_t ulIdleCycleCount = 0UL;
const char *pcTextForTask1 = "\n\rTask 1 is running, ulIdleCycleCount = ";
const char *pcTextForTask2 = "\n\rTask 2 is running, ulIdleCycleCount = ";
  ulIdleCycleCount++;
  char *pcTaskName;
  const TickType_t xDelay250ms = pdMS_TO_TICKS( 1UL );
  for( ;; )
    Serial.print(pcTaskName);
    Serial.print(ulIdleCycleCount);
    /* Delay for a period of 250 milliseconds. */
    digitalWrite(pinLED, HIGH);
    vTaskDelay( xDelay250ms );
    digitalWrite(pinLED, LOW);
  // initialize the digital pin as an output:
  pinMode(pinLED, OUTPUT);
  Serial.begin(921600);      //For Olimex Maple
  // Now set up two tasks to run independently.
  xTaskCreate(
      vTaskFunction   /* Pointer to the function that implements the task. */
    ,  (const portCHAR *) "Task 1"   /* Text name for the task.  This is to facilitate debugging only. */
    ,  configMINIMAL_STACK_SIZE   /* Stack depth - most small microcontrollers will use much less stack than this. */
    ,  (void*)pcTextForTask1 /* Pass the text to be printed into the task using the task parameter. */
    ,  tskIDLE_PRIORITY + 1     /* Priority, with 3 (configMAX_PRIORITIES - 1) being the highest, and 0 being the lowest.*/
    ,  NULL );/* We are not using the task handle. */
  xTaskCreate(
    ,  (const portCHAR *) "Task 2"   /* Text name for the task.  This is to facilitate debugging only. */
    ,  (void*)pcTextForTask2 /* Pass the text to be printed into the task using the task parameter. */
    ,  tskIDLE_PRIORITY + 1     /* Change priority looks at what happens*/
  // Now the task scheduler, which takes over control of scheduling individual tasks, is automatically started.
  /* If all is well we will never reach here as the scheduler will now be
  running.  If we do reach here then it is likely that there was insufficient
  heap available for the idle task to be created. */
  for( ;; );
    // Insert background code here
Use Termite terminal software to capture serial print data.
Pak
edogaldo
Post by edogaldo » Sat Nov 04, 2017 6:26 am
I found the issue was due to the allocated stack size.
If I set:
the code breaks and Windows can't even recognize the Maple Serial USB.
If instead I set:
xTaskCreate( vTaskFunction, "Task 1", 100, (void*)pcTextForTask1, 1, NULL );
xTaskCreate( vTaskFunction, "Task 2", 100, (void*)pcTextForTask2, 2, NULL );
the code is working fine.
So it seems a memory allocation conflict issue..
Just wondering why this does not happen also to you as we are using almost the same mcu (I'm using a Maple mini in truth).
Another question: which upload method are you using?
I'm using the maple bootloader 2.0
Post by Pito » Sat Nov 04, 2017 9:04 am
There is FreeRtos 9.00 in the repository available..
edogaldo
Post by edogaldo » Sat Nov 04, 2017 9:27 am
Same problem also with v 9.0
Post by Pito » Sat Nov 04, 2017 9:38 am
The stack sizes 1000 cannot be the problem, I guess..
Post by victor_pv » Sat Nov 04, 2017 12:54 pm
I'm with Pito that there must be more to it than the stack size, I have used larger stack sizes with both.
The defult config is kind of limited in the number of tasks, number of priorities, minimum stack size, etc. Have a look at the config file to see if there some config value that may be affecting you.
