ArduinoStreaming
ArduinoStreaming
Post by stevestrong » Tue Nov 14, 2017 11:22 am
https://github.com/geneReeves/ArduinoStreaming
I recently started to use it, it allows very nice logging:
uint16_t counter;
Serial << ("counter: ") << counter << (", hex: ") << _HEX(counter) << endl;
Maybe we could add it to our F1/F4 libraries (as single file Streaming.h), and extend it if needed.
zoomx
Re: ArduinoStreaming
Post by zoomx » Tue Nov 14, 2017 11:42 am
Post by stevestrong » Tue Nov 14, 2017 11:52 am
Which is less then the lib.
And is easier to include a header file than insert something which you don't undertand what is doing ;)
Post by mrburnette » Tue Nov 14, 2017 1:21 pm
Mikal Hart demonstrated this over 4 years ago, I've used it nearly that long in many of my Arduino examples.
See the Rob Tillaart response for some rather neat time formatting, reproduced below:
Hi Mikal,
Looks good! A small trick to get a leading zero (e.g. in a time string)
int h = 14;
int m = 6
Serial << ((h<10)?"0":"") << h << ":" << ((m<10)?"0":"") << m << endl;
it would be nice to have something parametrised like
Serial << ZERO(hour,2) << ":" << ZERO(minute,2) << endl;
Serial << ZERO(money, 4) << endl;
Post by fpiSTM » Tue Nov 14, 2017 1:22 pm
Nice.
Thanks to share.
Note that the link from zoomx refers to the one made by Mikal Hart which is the original based code for the one from stevestrong ;)
zoomx
Post by zoomx » Tue Nov 14, 2017 1:27 pm
It doesn't works like the library
Taking the STM32_TonePlayer I got an error
TimerTone.cpp:54: error: 'endl' was not declared in this scope
so you have to change endl with "/n", I suppose!, or add a definition for endl.
Or simply add streaming.h
Stevestrong library is a little different, at the top is witten
/* 12-05-2015 GgR
    added _FILL and _TIME classes from web page
Post by mrburnette » Tue Nov 14, 2017 2:18 pm
If you inspect the header file, you will see it is implemented as a macro. Therefore, no additional memory is required whatsoever to use the Arduiniana version.
