(presumed) inheritance issue when wrtting a library [FIXED]
logd32
Post by logd32 » Mon Dec 04, 2017 2:55 pm
I am facing a weird issue when writing a library, i suspect it is related to inheritence but i am not sure, does anyone know what the problem could be?
it is declared as follow:
DriverHal device( &callbacks );
An throws this error
error : variable 'DriverHal device' has initializer but incomplete type
//in main.cpp
void OnActionDone( void );
DeviceCallbacks_t callbacks ={
    &OnActionDone,
  //device.Init( );
//in driver_hal.cpp
DriverHal::DriverHal(DeviceCallbacks_t *callbacks):Driver( callbacks ){
//in driver_hal.h
class DriverHal : public Driver
public:
    DriverHal(DeviceCallbacks_t *callbacks);
    virtual ~DriverHal( void );
//in driver.cpp
void Driver::Init( void ) // not relevant for the issue
//in driver.h
class Driver : public Device
public:
    Driver( DeviceCallbacks_t *callbacks ): Device( callbacks )
    virtual ~Driver( )
    void Init( void );
//in device.h
typedef struct
    void ( *OnActionDone )( void );
}DeviceCallbacks_t;
class Device
protected:
public:
    Device( DeviceCallbacks_t *callbacks )
        this->OnActionDone = callbacks->OnActionDone;
    virtual ~Device( void ){ };
The ready to run test sketch is attached
INHERITANCE_ISSUE.zip
(2.03 KiB) Downloaded 7 times
lacklustrlabs
Re: (presumed) inheritance issue when wrtting a library
Post by lacklustrlabs » Mon Dec 04, 2017 9:15 pm
First line in INHERITANCE_ISSUE.ino should read:
#include "driver_hal.h"
An include guard in device.h would not hurt. I tend to use "#pragma once" more and more in my sketches..
Good luck!
logd32
Post by logd32 » Tue Dec 05, 2017 4:48 pm
Well spoteed, the problem was indeed the missing include of driver_hal.h in the sketch, thank you!
