Stm32f103C8 External Dac
stm32user
Post by stm32user » Mon Jan 15, 2018 12:54 pm
Hello there
I want to use an external DAC in Stm32f103c8.
How can I get a value of 0-255 as 8 logic output.
thax :roll:
Re: Stm32f103C8 External Dac
Post by Pito » Mon Jan 15, 2018 1:02 pm
Which external DAC, give us the link..
stm32user
Post by stm32user » Mon Jan 15, 2018 1:11 pm
I do not have any schematics.
For example PA0 PA1 PA2 PA3 PA4 PA5 PA6 I can get 8 outputs with for 0-255 data.
or if the outputs are different
PA0, PA1, PB2, PB5 etc.
Post by Pito » Mon Jan 15, 2018 1:52 pm
With 103C8 you may use
analogWrite(pin, value);  // value 0 - 255
analogWrite(PA7, 189);
or
pwmWrite(pin value); // value 0 - 65535
Works on specific pins.
You need a low-pass filter to get an analog value, however.
There is none hw DAC in 103C8.
Post by dannyf » Mon Jan 15, 2018 1:58 pm
generally you write a piece of code, as per the datasheet of your external DAC, to communicate with it.
that works 100% of the time with 100% of the devices, DAC or not.
Post by Pito » Mon Jan 15, 2018 2:06 pm
Be more specific, what external DAC you want to use (if any)?
There are R2R DACs, 1-2-4-8..R DACs, I2C DACs, SPI DACs, parallel DACs, PWM DACs, etc..
stm32user
Post by stm32user » Mon Jan 15, 2018 2:14 pm
can we do it like the picture?
Post by Pito » Mon Jan 15, 2018 2:16 pm
That is the R2R DAC.
Yes you can do it, sure. You may wire it to a port, ie. PortA or PortB, PA0-PA7 or PB0-PB7, and then send the DAC value to the PortA or PortB in a single write.
Mind the stm32 is a 3.3Volt device, thus the R2R output will be 0..3.28V max.
stm32user
Post by stm32user » Mon Jan 15, 2018 2:34 pm
Thanks for the answer, if I want to use different pins?
PA0, PA1, PA2, PB12, PB13, PB14, PA3, etc.
There is a method
Post by Pito » Mon Jan 15, 2018 2:48 pm
You may set the bits individually. First set the individual pins to outputs, then write the DACvalue:
pinMode(PA0, OUTPUT);
pinMode(PB12, OUTPUT);
// write the DACvalue 0-255, 8bit
digitalWrite(PA4, (DACvalue & 0x80));  // the highest DACvalue bit7
digitalWrite(PA3, (DACvalue & 0x40));
digitalWrite(PB14, (DACvalue & 0x20));
digitalWrite(PB13, (DACvalue & 0x10));
digitalWrite(PB12, (DACvalue & 0x08));
digitalWrite(PA2, (DACvalue & 0x04));
digitalWrite(PA1, (DACvalue & 0x02));
digitalWrite(PA0, (DACvalue & 0x01));  // the lowest DACvalue bit0
