Gameduino2/3 some help porting please.
Nutsy
Post by Nutsy » Mon Feb 05, 2018 7:38 pm
So im going to have a go at trying to port the latest build of the library...
A simple port just to get it working...
I know Lightcalama had done one but its a bit outdated to the main library now missing some of the functions.
I do need a little help though, has the hardware SPI been finished? I know roger did a hack fix a long time ago. But was it ever finished?
Also what is the board define for the baite maple and f4 cores?
Is it really just a case of defining the board and setting what SPI port to use? and the rest just carries on as it should? or are all the ways the SPI calls done needing to be changed?
If anyone can let me know...
thanks
Re: Gameduino2/3 some help porting please.
Post by mrburnette » Mon Feb 05, 2018 9:37 pm
From the Kickstarter...
In 2011 the original Gameduino brought vintage gaming to the Arduino.
In 2013 Gameduino 2 set a new standard in hand-held open-source gaming.
Now Gameduino 3 raises the bar again. Even more processing power for your games and applications - plus real video playback, all using a regular Arduino.
Hardware SPI works.
I have no idea what "board defines" means. Is the info here not satisfactory?
http://wiki.stm32duino.com/index.php?title=Boards
You can also use this
http://wiki.stm32duino.com/index.php?ti ... roductList
to compare resources.
Maple Mini
Red Pill
Blue Pill
Black Pill
You can always look in the *.txt files here for specifics
https://github.com/rogerclarkmelbourne/ ... er/STM32F1
Beyond that, sounds Nutsy to me :shock:
Nutsy
Post by Nutsy » Mon Feb 05, 2018 10:47 pm
i mean the define names that libraries use to determine what version of code to run depending on what the mcu is...
Post by mrburnette » Mon Feb 05, 2018 10:51 pm
The "environmentals" are passed from the 2 .txt files I previously linked. You just need to pull 'em up, find what board section you are interested in, and then do some paper & pencil work.
lightcalamar
Post by lightcalamar » Thu Feb 08, 2018 8:46 am
Hi, Nutsy.
Currently GD2UB library work very well with families STM32F1xxx and STM32F4xxx. This library will be based on Gameduino2 with all its functions and microSD reader.
We are working hard to update the new features of Gameduino3, for example playback videos. This already work for example in other MCUs type ESP8266 and export to STM32Fx
The first thing is to understand how to work library in AVR if you understand then you have to work for STM32. As you well know, it is not easy because of testing issues and some errors that are being solved.
An example for informative purposes and to be in the intermediate period.
[youtube]https://youtu.be/n0S3gbZhX_A[/youtube]
As well know all the information and advances will be announced in this forum and alternatively in https://foro.ft81xmania.com
The current repository will be https://github.com/FT81xMania/GD2UB
Regards.
