ENC28J60 +php crash on stm32f103ve
ramgc
Post by ramgc » Wed Feb 14, 2018 12:49 pm
Hello, i am design a circuit with stm32f103ve, and just connect enc28j60 for internet. I have a server with xampp and work properly with apps in android, i am using Serasidis_EtherCard_STM library, when http get to my php server dont receive nothing good, if put other web equal.
code is webClient for arduino in this library
#include <SPI.h>
#include <EtherCard_STM.h>
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[700];
static uint32_t timer;
const char website[] PROGMEM = "82.221.41.158";
// called when the client request is complete
static void my_callback (byte status, uint16_t off, uint16_t len) {
  Serial.println(">>>");
  Ethernet::buffer[off+300] = 0;
  Serial.print((const char*) Ethernet::buffer + off);
  Serial.println("...");
void setup () {
  Serial.begin(57600);
  Serial.println(F("\n[webClient]"));
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println(F("Failed to access Ethernet controller"));
  if (!ether.dhcpSetup())
    Serial.println(F("DHCP failed"));
  ether.printIp("IP:  ", ether.myip);
  ether.printIp("GW:  ", ether.gwip);
  ether.printIp("DNS: ", ether.dnsip);
  if (!ether.dnsLookup(website))
    Serial.println("DNS failed");
  ether.printIp("SRV: ", ether.hisip);
void loop () {
  ether.packetLoop(ether.packetReceive());
  if (millis() > timer) {
    timer = millis() + 5000;
    Serial.println();
    Serial.print("<<< REQ ");
    ether.browseUrl(PSTR("/comprueba_maq_ON.php?maquina="), "1", website, my_callback);  }
php have to return '1' but return many characters wrong. Serial print is off in my design, if put this ''http://www.gonzalogalvan.es/arduino/sav ... ?consumo=5'' of other developer just equal...
i am very lost in this, only need read return server...
thanks, i am learning in this forum each day
Re: ENC28J60 +php crash on stm32f103ve
Post by stevestrong » Wed Feb 14, 2018 2:02 pm
I can only recommend to use W5500 (Wiznet) modules instead of ENC28J60 modules.
The Wiznet chip is much more reliable (my experience) and the lib for that is better supported.
The W5500 module prices are also competitive with those of ENC module: https://www.aliexpress.com/item/Replace ... 56354.html
Vassilis
Post by Vassilis » Wed Feb 14, 2018 3:16 pm
@ramgc The IP in your sketch (82.221.41.158) is not functional (at least to me). Please provide us with a sketch that uses a valid public IP or public domain name.
ramgc
Post by ramgc » Wed Feb 14, 2018 3:21 pm
ok, thanks
#include <SPI.h>
const char website[] PROGMEM = "82.223.11.159";
void setup () {
void loop () {
    Serial.println();
my server is 82.223.11.159
Vassilis
Post by Vassilis » Wed Feb 14, 2018 4:04 pm
Pinging 82.223.11.159 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 82.223.11.159:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
ramgc
Post by ramgc » Wed Feb 14, 2018 4:15 pm
Request timed out.
Request timed out.
Request timed out.
Request timed out.
i just see that dont ping... but php work properly
put http://82.223.11.159/comprueba_maq_ON.php?maquina=1 and return 1 or 0
i dont know that happen
Post by fpiSTM » Wed Feb 14, 2018 4:25 pm
For ENC28J60, I've used this lib which now support stm32 boards since version 2.0.5:
https://github.com/UIPEthernet/UIPEthernet
Vassilis
Post by Vassilis » Wed Feb 14, 2018 5:52 pm
#include <SPI.h>
static byte  server_ip[] = { 82,223,11,159};
void setup () {
  if (ether.begin(sizeof Ethernet::buffer, mymac, PA4) == 0)
  //if (!ether.dnsLookup(website))
  //  Serial.println("DNS failed");
  ether.copyIp(ether.hisip,  server_ip);
void loop () {
    Serial.println();
[webClient]
<<< REQ >>>
HTTP/1.1 200 OK
Date: Wed, 14 Feb 2018 17:44:52 GMT
Server: Apache
X-Powered-By: PHP/7.0.23
X-Frame-Options: SAMEORIGIN
X-Mod-Pagespeed: 1.9.32.14-0
Cache-Control: max-age=0, no-cache
Content-Length: 2
Connection: close
Content-Type: text/html; charset=UTF-8
0 ...
The library that is suggested by fpiSTM is compatible with the Arduino Ethernet library (big advantage !) but it produces larger .bin files. It's excellent library though. I have used both of these two libraries.
ramgc
Post by ramgc » Thu Feb 15, 2018 3:41 pm
#include <SPI.h>
void setup () {
void loop () {
    Serial.println();
[webClient]
<<< REQ >>>
HTTP/1.1 200 OK
Server: Apache
Content-Length: 2
Connection: close
0 ...
I dont know that happen, but receive bad characters:
i have a lcd:
lcd.setCursor(0, 0);
lcd.print((int) Ethernet::buffer[0]);
lcd.setCursor(3, 0);
lcd.print((int) Ethernet::buffer[1]);
lcd.setCursor(6, 0);
lcd.print((int) Ethernet::buffer[2]);
just received t - i - i
ramgc
Post by ramgc » Sun Feb 18, 2018 8:09 am
it is crazy...dont work this code for me, i try all but nothing, anything is read bad in my code, i dont know where :(
