STM32F103C8 & TFT (ili9325)
stm32user
Post by stm32user » Thu Nov 26, 2015 1:07 pm
Stm32f103c8 Mini Board
ili9325 2.4'' TFT (arduino uno compotible)
HI
How do I program with these two products arduino ide
thanks!
madias
Post by madias » Thu Nov 26, 2015 11:41 pm
I'm sure you can use the UTFT library for the ili9325, please search the forum for a STM32duino port of UTFT.
But you have to put your hands on the lib (I assume it's 8-bit parallel driven).
stm32user
Post by stm32user » Fri Nov 27, 2015 2:03 pm
Hi
Stm32F103C Board Pin -> TFT pin wiring diagram
This connection type is correct
It also does not display a pin LCD_CD
LCD_RS same with LCD CD?
I think there's a problem
Post by zmemw16 » Fri Nov 27, 2015 5:35 pm
swap the column headers?
look at an 8080 type interface for the control pins and use
stm32user
Post by stm32user » Fri Nov 27, 2015 7:06 pm
Can someone please link me how I wrote and which could use the library
iwalpola
Post by iwalpola » Tue Jun 21, 2016 1:24 pm
Correction:
Working library: https://github.com/iwalpola/Adafruit_ILI9341_8bit_STM/
JoaoLopes's library supports ILI9341, and this one probably is an ILI9341. I checked the SPFD5408 datasheet, and Joao's library definitely isn't for SPFD5408. I wonder why he named it so.
I'm in this exact same situation. Are you sure that the TFT driver IC is ILI9325?
I have seen working Arduino Uno libraries for this shield from several sources, including https://github.com/JoaoLopesF/SPFD5408. And they say that the IC is "SPFD5408".
Joao Lopes's library above uses a modified version of the Adafruit TFT library for the hardware layer. The Adafruit TFT library was originally for controlling ILIxxxx series of IC, but this guy modified it for the 8 bit interface of SPFD508.
Now, I've seen working code examples for STM32 for the ILIxxxx on Andy's Workshop blog http://andybrown.me.uk/2012/01/01/stm32 ... ft-driver/. So I'm tracking where Joao changed the Adafruit library to try and figure out how to modify an STM32 driver for this TFT.
iwalpola
Post by iwalpola » Tue Jun 21, 2016 2:18 pm
Correction: The SPFD408 is compatible with ILI9341, and also in Joao's library, there are some changes in pin_magic.h as well.
Okay, I did a git diff on the SPFD5408 library and the Adafruit TFTLCD (for ILI9325 in 8 bit mode) library. Only one thing has been changed, and that is the readID function (it reads a register to identify the chip) which isn't a big change at all. So I think an STM32 8 bit interface library for ILI9325 should work for the SPFD5408 as well. I'll look for one or modify andy's workshop code.
martinayotte
Post by martinayotte » Tue Jun 21, 2016 2:38 pm
I have an 3.5" LCD from MCUFriend which looks almost the same as the one above, and I used some parallel 8bits code which use ILI9327 commands.
Post by RogerClark » Tue Jun 21, 2016 11:00 pm
does anywhere on ebay or aliexpress sell these at reasonable prices ?
Post by ahull » Wed Jun 22, 2016 12:34 pm
RogerClark wrote:does anywhere on ebay or aliexpress sell these at reasonable prices ?
Depends what you call reasonable, and how accurately you define "these"... :D
http://www.ebay.co.uk/itm/2-4-inch-TFT- ... Sw6btXTQzU
http://www.ebay.co.uk/itm/New-3-5-Inch- ... SwcvdXPDXn
