Red / Blue Pill Eagle Library
aster
Re: Red / Blue Pill Eagle Library
Post by aster » Wed May 10, 2017 10:37 pm
hello
i made a black pill schematics and board for eagle, I DIDN'T CHECK IT so before making a pcb test it
really it is my personal eagle library so you will find other stuff like some imu, sd adapter and gps, you will find them usefull
edit i made a library with all f103 (maple, black and blue) using simonf already made boards (as you could immagine it is the file called stm32duino boards)
edit2: this was a fast hack when i will get my black pill i will modify the library and add the baite clone since in these boards there isn't av+ and av- and add the differents pin funcionality
EDIT3: see above
RogerClark
Post by RogerClark » Thu May 11, 2017 1:32 am
aster
Post by aster » Thu May 11, 2017 3:17 pm
You are welcome, when i will make the changes i will write here again :D
aster
Post by aster » Wed May 17, 2017 10:23 pm
All our f103 boards together
Black Pill - Blue Pill
Maple Mini from Baite - LeafLab
stm32duino boards.rar
(3.57 KiB) Downloaded 196 times
pablomuro
Post by pablomuro » Tue Sep 19, 2017 8:28 pm
Sorry, I had not seen your answer
STM32BluePill.zip
(2.24 KiB) Downloaded 99 times
