Real quicky, Which timer is safe to use?
Mangy_Dog
Post by Mangy_Dog »
I need a timer to trigger very regular DMA transfers for a softPWM implementation...
Which timer is safe to use, and wont conflict with other core components?
Re: Real quicky, Which timer is safe to use?
I think timer 2,3,5 are 'normal' ones, and Timer 1 is the 'advanced' one. They work pretty much the same though.
Timer 2,3,5 as I find are 'adequate'. If you aren't using any of them for any particular purpose, you could even just use Timer1
For STM core, messing with dma may take messing with registers or HAL, just my guess.
Mangy_Dog
Post by Mangy_Dog »
Not quite working yet... but written this so far. the //digitalWrite(PB5, HIGH); is just for quick dirty checking to see where its getting to in the code.
Its getting into send DMA but im not seeing any led fading effect yet.
#include "softPwm.h"
#include <libmaple/dma.h>
#define stepDutyCount 100
uint16_t dataA[stepDutyCount];
uint16_t dataB[stepDutyCount];
//uint16_t dataC[stepDutyCount];
uint8_t step = 0;
static HardwareTimer TimerPWM(1);
void sendDMA()
    dma_setup_transfer(DMA1, DMA_CH0, &GPIOA->regs->ODR, DMA_SIZE_16BITS, &dataA[step], DMA_SIZE_16BITS, DMA_FROM_MEM);
    dma_setup_transfer(DMA1, DMA_CH1, &GPIOB->regs->ODR, DMA_SIZE_16BITS, &dataB[step], DMA_SIZE_16BITS, DMA_FROM_MEM);
  //  dma_setup_transfer(DMA1, DMA_CH2, &GPIOC->regs->ODR, DMA_SIZE_16BITS, &dataC[step], DMA_SIZE_16BITS, DMA_FROM_MEM);
    dma_set_priority(DMA1, DMA_CH1, DMA_PRIORITY_VERY_HIGH);
    dma_set_priority(DMA1, DMA_CH2, DMA_PRIORITY_VERY_HIGH);
    //dma_set_priority(DMA1, DMA_CH3, DMA_PRIORITY_VERY_HIGH);
    dma_enable(DMA1, DMA_CH0);
    dma_enable(DMA1, DMA_CH1);
   // dma_enable(DMA1, DMA_CH2);
    step++;
    if (step >= stepDutyCount)
	step = 0;
void initPWM()
    TimerPWM.setPrescaleFactor(100);
    TimerPWM.setOverflow(480);
    TimerPWM.attachInterrupt(1, sendDMA);
    TimerPWM.resume();
    dma_init(DMA1);
void setSoftPWM(uint8 p, uint8_t value)
    for(int i = 0 ; i<100 ; i ++)
	if(i<value)
	    if(p<16)
	    dataA[i] |= 1UL << p ;
	    if(p>=16 && p < 32)
	    dataB[i] |= 1UL << (p-16) ;
	else
	    if(p<16)
	    dataA[i] &= ~(1UL << p);
	    if(p>=16 && p < 32)
	    dataB[i] &= ~(1UL << p-16);
I've tried some timer and DMA stuff
(yet another) SUMP compatible logic analyzer board for STM32duino (steve's libmaple core) - stm32f401cc pill board
viewtopic.php?f=10&t=116
https://github.com/ag88/SumpSTM32F401cc
unfortunately, it is for libmaple - roger's or more correctly steve's core. on stm32f401
steeve's core with dma on stm32f401 is very fast
https://www.youtube.com/watch?v=7Ey1U36YtY0
^ note delays is inserted in this video so that you can see each test, otherwise it is simply a blur and it probably can stream videos on ILI9341
i've not really 'get hands dirty' working dma in stm core. I'd guess HAL etc is probably a way to go.
Mangy_Dog
Post by Mangy_Dog »
I dont think my DMA is actually DMAing...
Am i triggering it wrong?
Bakisha
Answers: 5
Post by Bakisha »
I was experiment with DMA to ODR, but with official core, and directly with registers.
From what i understand, on bluepill, you can only use DMA1 to send either PortA or PortB, not both.
In your example,
bottom line will set DMA to use DMA_CH1, and use dataB[] as source. Simply because it is after first line (where you setup DMA_CH0 and dataA[]).
And, in you example, interrupt is triggered in same time as DMA is sending dataB[0] (since they are on same timer), and you keep resetting to again send dataB[0] again.
IMHO, as i don't think bluepill have DMA2, just use interrupt on any timer. It is not time critical (since interrupt is every 666.67 microseconds) and use GPIOA->regs->ODR and GPIOB->regs->ODR inside of it.
Mangy_Dog
Post by Mangy_Dog »
I should point out its not a blue pill. A custom f103C6 board.
Bakisha
Answers: 5
Post by Bakisha »
Almoust as bluepill. Your board just don't have Timer4 compared to bluepill. But RM0008 apply to your board too.
I am not familiar wirh Roger's core DMA syntax, but i'm pritty sure there must some command to set lenght of DMA transfers ( for CNDTR register).
