STM32F1 - calibrating LSI
Anything not related to STM32
I was quite impressed with W801's feature to automatically calibrate its 32,768Hz RC oscillator - see here: https://dannyelectronics.wordpress.com/ ... libration/
This reminds me of the LSI on STM32F1 chips: a nominal frequency of 40Khz but a range of 30Khz - 60Khz. Thanks, ST :)
Here is my attempt at calibrating it: https://dannyelectronics.wordpress.com/ ... g-the-lsi/
in the end, I measured the LSI to be around 37Khz and brought down the error rate to < 100ppm.
the basic code isn't directly portable to STM32duino but the basic concept is. Hope it helps.
Re: STM32F1 - calibrating LSI
one of those things which i may have misunderstood is that VBAT is mainly for LSE and to retain the few backup registers.
And if I'm right that VBAT works in conjunction with LSE + registers rather than LSI?
Hence, sometimes if VBAT, LSE, RTC + backup registers break, it kind of spoil the soup for me. Apparently, this bundle works as a subsystem.
Then there are lousy 32k crystals which drifts.
So I've this little 'RTC adjustment' piece (in roger's core)
that kind of allows one to compensate drifts in the 32k crystals
while i'd not claim ppm accuracy, after all that 'compensation', i've seen errors of less than a minute in a month (not terribly accurate, but decent).
i used to have a 5c 32k crystal that drifts so much that it is off by minutes the next day. All that 'adjustments' brought that 'less than a minute a month' performance.
not sure. need to check against the datasheet.
that's quite good: 1 minute / month =~20ppm. Most of those crystals are spec'd within that. But in reality they are often much better than that, typically in the 5-10ppm range.
there are watches that are good for 1 second / year = 30ppb. That's impressive.
When I get some time, I will build a TCXO of my own: using the mcu to measure temperature and then adjust pwm output to drive a varicap, in order to compensate for the crystal's tempco. that + running the crystla in a hot bubble (controlled by the mcu) could reach high stability.
Return to “Off topic”
