Hello, Everyone.
I'm working on a project that requires the STM32F401CCU6 to generate truly random numbers.
Is there a way to do it in the Arduino IDE? And if there is, please give me a code that does it.
I tried to use the code from the STM32F407VET6 for that purpose, but it won't even compile.
How to generate truly random numbers on STM32F401CCU6 in Arduino IDE?
Re: How to generate truly random numbers on STM32F401CCU6 in Arduino IDE?
Probably the same as for F407:
viewtopic.php?p=12993#p12993
I've tried that.
And I got the following error:
Arduino: 1.8.19 (Windows 10), Board: "Generic STM32F4 series, Generic F401CC, STM32CubeProgrammer (DFU), Enabled (generic 'Serial'), CDC (generic 'Serial' supersede U(S)ART), Low/Full Speed, Smallest (-Os default), Newlib Nano (default)"
STM32F407VET6_RNG:26:1: error: 'RNG_HandleTypeDef' does not name a type; did you mean 'RTC_HandleTypeDef'?
26 | RNG_HandleTypeDef hrng;
| RTC_HandleTypeDef
STM32F407VET6_RNG:34:34: error: variable or field 'HAL_RNG_MspInit' declared void
34 | extern "C" void HAL_RNG_MspInit(RNG_HandleTypeDef* hrng) {
STM32F407VET6_RNG:34:34: error: 'RNG_HandleTypeDef' was not declared in this scope; did you mean 'RTC_HandleTypeDef'?
| RTC_HandleTypeDef
STM32F407VET6_RNG:34:53: error: 'hrng' was not declared in this scope
STM32F407VET6_RNG:45:36: error: variable or field 'HAL_RNG_MspDeInit' declared void
45 | extern "C" void HAL_RNG_MspDeInit(RNG_HandleTypeDef* hrng) {
STM32F407VET6_RNG:45:36: error: 'RNG_HandleTypeDef' was not declared in this scope; did you mean 'RTC_HandleTypeDef'?
| RTC_HandleTypeDef
STM32F407VET6_RNG:45:55: error: 'hrng' was not declared in this scope
STM32F407VET6_RNG:34:33: error: variable or field 'HAL_RNG_MspInit' declared void
STM32F407VET6_RNG:34:33: error: 'RNG_HandleTypeDef' was not declared in this scope; did you mean 'RTC_HandleTypeDef'?
| RTC_HandleTypeDef
STM32F407VET6_RNG:34:52: error: 'hrng' was not declared in this scope
STM32F407VET6_RNG:45:35: error: variable or field 'HAL_RNG_MspDeInit' declared void
STM32F407VET6_RNG:45:35: error: 'RNG_HandleTypeDef' was not declared in this scope; did you mean 'RTC_HandleTypeDef'?
| RTC_HandleTypeDef
STM32F407VET6_RNG:45:54: error: 'hrng' was not declared in this scope
C:\STM32F407VET6_RNG\STM32F407VET6_RNG.ino: In function 'void setup()':
STM32F407VET6_RNG:60:3: error: 'hrng' was not declared in this scope
60 | hrng.Instance = RNG;
STM32F407VET6_RNG:60:19: error: 'RNG' was not declared in this scope
STM32F407VET6_RNG:61:7: error: 'HAL_RNG_Init' was not declared in this scope; did you mean 'HAL_RTC_Init'?
61 | if (HAL_RNG_Init(&hrng) != HAL_OK) {
| HAL_RTC_Init
C:\STM32F407VET6_RNG\STM32F407VET6_RNG.ino: In function 'void loop()':
STM32F407VET6_RNG:68:37: error: 'hrng' was not declared in this scope
68 | if (HAL_RNG_GenerateRandomNumber(&hrng, &aRandom32bit) != HAL_OK) {
STM32F407VET6_RNG:68:7: error: 'HAL_RNG_GenerateRandomNumber' was not declared in this scope
exit status 1
| RTC_HandleTypeDef
| RTC_HandleTypeDef
| RTC_HandleTypeDef
| RTC_HandleTypeDef
| RTC_HandleTypeDef
| HAL_RTC_Init
exit status 1
rm0368 stm32f401 reference manual
stm32f401 apparently don't have hardware RNG and crypto
hence, your options are PRNG
https://en.wikipedia.org/wiki/List_of_r ... rs_(PRNGs)
f4xx has an FPU hence, you can even use those PRNG that is based on floating point values
to seed that, you can try things like to run the RTC and seed that with RTC time each time the user manually resets.
Or place a wire like at least 10s of cm long and read the analog pin, it may pick up random radio waves and perhaps you can use a random radio wave value to seed the PRNG
Got it. Thank you.
