Convert Arduino cod from stm
Lopinhos
Post by Lopinhos »
Hi... I'm new to programming.
I have a program made and working on Arduino Nano, but due to the processing capacity I had to change to STM, but when doing the conversion I get some errors.
I would like to know if anyone can help me.
I'm using the Arduino IDE to program the stm32 black pill
Before defining the ports, this error occurs.
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino:195:5: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino: In function 'void setup()':
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino:180:3: error: 'SPCR' was not declared in this scope
In file included from C:\Users\M�rio\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.7.0\cores\arduino/wiring.h:34,
from C:\Users\M�rio\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.7.0\cores\arduino/Arduino.h:36,
from C:\Users\M�rio\AppData\Local\Temp\arduino\sketches\EFC234BFF5C4FF183FB9F91B82B7A4DC\sketch\Ficheiro_fan.ino.cpp:1:
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino:180:15: error: 'SPE' was not declared in this scope
C:\Users\M�rio\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.7.0\cores\arduino/wiring_constants.h:99:27: note: in definition of macro '_BV'
99 | #define _BV(bit) (1 << (bit))
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino:181:15: error: 'SPIE' was not declared in this scope; did you mean 'SPI1'?
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino:182:15: error: 'CPHA' was not declared in this scope
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino: In function 'void cableselect()':
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino:188:3: error: 'SPCR' was not declared in this scope
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino:188:16: error: 'SPIE' was not declared in this scope; did you mean 'SPI1'?
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino:189:3: error: 'SPDR' was not declared in this scope
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino: At global scope:
C:\Users\Mário\Desktop\Fanatec\Ficheiro_fan\Ficheiro_fan.ino:195:4: error: expected constructor, destructor, or type conversion before '(' token
exit status 1
Compilation error: expected constructor, destructor, or type conversion before '(' token
After defining the ports I have these.
exit status 1
Compilation error: unterminated argument list invoking macro "_BV"[/size]
Code:
#include "pins_arduino.h"
#include <avr/pgmspace.h>
#define HAS_TM1637_DISPLAY // comment out if you're not using a TM1637 4 digits 7 segment display
#ifdef HAS_TM1637_DISPLAY
#include <TM1637Display.h>
#define TM_CLKPIN 3
#define TM_DIOPIN 4
#define TM_BRIGHTNESS 5 // (0..7), sets the brightness of the display. 0=min, 7=max
TM1637Display display = TM1637Display(TM_CLKPIN, TM_DIOPIN);
uint8_t TM_data[] = { 0x00, 0x00, 0x00, 0x00 };
const uint8_t TM_race[] = { 0x38, 0x3f, 0x73, 0x00 };
const uint8_t TM_crc[] = { 0x39, 0x50, 0x39 };
#define DISPLAY_CRC8_MATCH_ON_SERIAL // keep this and the next line uncommented, until you get many more "crc8 match" lines on the serial port, than crc8 mismatch lines. (I am mostly getting somewhere between 10 to 200 "match" lines before a single "mismatch" line)
#define DISPLAY_CRC8_MISMATCH_ON_SERIAL // once you know the SPI port is mostly receiving data correctly, you can comment out both lines (or use them for easy debugging)
//#define DISPLAY_CRC8_MISMATCH_ON_ALPHANUMERIC // use this if you'd like to get a 'CrC' message displayed on the alphanumeric display, each time there's a crc8 mismatch, which means bad SPI communication with the wheelbase. My advice: always keep this commented. If you do have some SPI communication issues, this might help you to know when communication is faulty without looking at the serial monitor.
//#define DISPLAY_ALPHANUMERIC_DATA_WHEN_MISMATCH_ON_SERIAL // When getting some (likely broken) alphanumeric text on a packet with mismatched crc8, you might want to view the text on the serial monitor. In that case uncomment this line. (keep this commented to tidy things up)
#define HAS_ANALOG_DPAD
//#define DEBUG_ANALOG_DPAD // print the DPAD value on the alphanumeric display. Only relevant if you have an analog dpad, and only when trying to get the DPAD working. once it's working - uncomment this. (Dpad value is always sent to serial monitor)
#ifdef HAS_ANALOG_DPAD
#define DPADPIN A0
int prevDpadVal = 0;
#define dataLength 33
#define CS_ISR 2 // connect SPI Cable Select pin to Arduino's D2 & D10. (See schematics)
#define PRINTBIN(Num) \
for (uint32_t t = (1UL << (sizeof(Num) * 8) - 1); t; t >>= 1) Serial.write(Num& t ? '1' : '0'); // Prints a binary number with leading zeros (Automatic Handling)
#define HASBUTTONS // use digital and analog pins for steering wheel buttons. Note: Pins A7 and A6 do not have an internal pullup resistor. Serial data pins: D0, D1. SPI pins: D2, D10, D11, D12, D13. Display Pins: D3, D4. The rest of digital and analog pins can be used for buttons. (also AFAIK A6 and A7 can only be used for analogRead() )
#ifdef HASBUTTONS
#define buttonsnum 10 // how many buttons are you using?
uint8_t buttonsPins[] = {
A5,
A4,
A3,
A2,
8,
9,
A1,
5,
6,
7,
}; // what arduino pins are you using?
uint8_t buttonsBits[] = { 8, 5, 13, 11, 9, 12, 22, 6, 7, 8 }; // what bits do you want each button to affect? use the last comment in this file as reference.
//A
//1 D-pad Up
//2 D-pad Left
//3 D-pad Right
//4 D-pad Down
//5 Button 11
//6 Button 3
//7 Button 6
//8 Button 4
//B
//9(1) Right Paddle
//10(2) Button 2 (top left, right one)
//11(3) Button 8 (bottom left, lower)
//12(4) Left paddle
//13(5) Button 1 (top left, left one)
//14(6) Button 5 (bottom left, higher)
//15(7) Button 9 (3 buttons in triangle, left)
//16(8) Button 10 (3 buttons in triangle, right)
//17(1) Button 21 in contentmanager. Does not show up in fanatec's driver
//18(2) D-pad Button
//19(3) Joystick Button
//20(4) Button 7 (3 buttons in triangle, top)
//21(5) Button 27 in contentmanager. Does not show up in fanatec's driver
//22(6) Menu button. Button 28 in contentmanager. Does not show up in fanatec's driver)
//23(7)
//24(8)
uint8_t mosiBuf[dataLength]; // buffer for the incoming data on the mosi line.
volatile unsigned long lastPrintMillis = 0;
int selectedButtonByte = 2; // button bytes are 3rd to 5th. initialize to 1st relevant byte.
uint8_t incByte, prevPrintedByte, prevAlphaDisp[3];
volatile uint8_t isrIndex = 0;
unsigned long delayMillis = 400; // wait at least the delay time since last spi communication before printing out whatever came in.
// CRC lookup table with polynomial of 0x131
PROGMEM const unsigned char _crc8_table[256] = {
0, 94, 188, 226, 97, 63, 221, 131,
194, 156, 126, 32, 163, 253, 31, 65,
157, 195, 33, 127, 252, 162, 64, 30,
95, 1, 227, 189, 62, 96, 130, 220,
35, 125, 159, 193, 66, 28, 254, 160,
225, 191, 93, 3, 128, 222, 60, 98,
190, 224, 2, 92, 223, 129, 99, 61,
124, 34, 192, 158, 29, 67, 161, 255,
70, 24, 250, 164, 39, 121, 155, 197,
132, 218, 56, 102, 229, 187, 89, 7,
219, 133, 103, 57, 186, 228, 6, 88,
25, 71, 165, 251, 120, 38, 196, 154,
101, 59, 217, 135, 4, 90, 184, 230,
167, 249, 27, 69, 198, 152, 122, 36,
248, 166, 68, 26, 153, 199, 37, 123,
58, 100, 134, 216, 91, 5, 231, 185,
140, 210, 48, 110, 237, 179, 81, 15,
78, 16, 242, 172, 47, 113, 147, 205,
17, 79, 173, 243, 112, 46, 204, 146,
211, 141, 111, 49, 178, 236, 14, 80,
175, 241, 19, 77, 206, 144, 114, 44,
109, 51, 209, 143, 12, 82, 176, 238,
50, 108, 142, 208, 83, 13, 239, 177,
240, 174, 76, 18, 145, 207, 45, 115,
202, 148, 118, 40, 171, 245, 23, 73,
8, 86, 180, 234, 105, 55, 213, 139,
87, 9, 235, 181, 54, 104, 138, 212,
149, 203, 41, 119, 244, 170, 72, 22,
233, 183, 85, 11, 136, 214, 52, 106,
43, 117, 151, 201, 74, 20, 246, 168,
116, 42, 200, 150, 21, 75, 169, 247,
182, 232, 10, 84, 215, 137, 107, 53
// Uni hub packet (change to other steering wheels in setup() )
uint8_t returnData[dataLength] = { 0xA5, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xfc };
// return CRC8 from buf
uint8_t crc8(const uint8_t* buf, uint8_t length) {
uint8_t crc = 0xff;
while (length) {
crc = pgm_read_byte_near(_crc8_table + (*buf ^ crc));
buf++;
length--;
return crc;
pinMode(MISO, OUTPUT); // usually when using SPI, arduino will automatically define MISO as output, but not when doing SPI slave.
pinMode(SCK, INPUT);
pinMode(MOSI, INPUT);
pinMode(CS_ISR, INPUT); // connecting CS_ISR pin (D2) to the SS pin (D10) is crucial. See the schematics.
pinMode(SS, INPUT);
#ifdef HASBUTTONS
for (int i = 0; i < buttonsnum; i++) {
pinMode(buttonsPins, INPUT_PULLUP);
returnData[1] = { 0x02 }; // for ClubSport Porshe 918 RSR - This is the only option that I'm implementing right now.
// {0x01} for BMW M3 GT2, {0x02} for ClubSport FORMULA, (0x04) for Uni hub
Serial.begin(250000);
pinMode(DPADPIN, INPUT);
display.clear();
display.setBrightness(TM_BRIGHTNESS);
display.setSegments(TM_race);
display.clear();
attachInterrupt(digitalPinToInterrupt(CS_ISR), cableselect, RISING);
// SPCR BYTE should be: 11000100 note to self: by raw_capture.ino and fanatec.cpp spi settings, of btClubSportWheel by Darknao, SPI settings are SPI_Mode0 & MSBFIRST. but with logic scope I see that CPHA 1 (falling!) is used by wheel base, which means SPI_MODE1. (and MSBFIRST)
// (Mode 1 - clock is normally low (CPOL = 0), and the data is sampled on the transition from high to low (trailing edge) (CPHA = 1))
SPCR |= _BV(SPE); // turn on SPI
SPCR |= _BV(SPIE); // turn on interrupts
SPCR |= _BV(CPHA); //turns on CPHA. as I found the CSW wheelbase to use it, with logic scope.
Serial.print("SPCR byte (binary):");
Serial.println(SPCR, BIN); //prints byte as binary
void cableselect() { // When CS line goes high - the rim should get ready to transmit the next returnData buffer, right from the begining. (so that the first byte (0xA5) will be sent out on the first Clock cycle (and after CS line went Low)
SPCR &= ~_BV(SPIE); // turn OFF interrupts
SPDR = returnData[0]; // load first byte into SPDR single-byte's buffer
isrIndex = 0; // on next SPI interrupt(SPI_STC_vect), load the 2nd byte
// SPI interrupt routine
ISR(SPI_STC_vect) // Note: this routine takes 6 us, and happens once 8 bits are recieved through SPI.
byte c = SPDR;
mosiBuf[isrIndex] = c;
isrIndex++;
if (isrIndex >= dataLength) {
isrIndex = 0;
SPDR = returnData[isrIndex];
readSerial();
readButtons();
calcOutgoingCrc();
printButtonByteToSerial();
bool crc8Stat = checkIncomingCrc();
refreshAlphanumericDisplays(crc8Stat);
void readButtons() {
#ifdef HASBUTTONS
if (!digitalRead(buttonsPins)) { // if this input is low the button is pressed. Reverse logic: all button inputs use the internal input pullup, and pressing the button completes the path to ground)
buttonBitChange(buttonsBits, true); // raise the correct button bit, as defined in buttonsBits[]
} else {
buttonBitChange(buttonsBits, false); // drop bit
VALUE MIDPOINT BUTTON DpadVal
1023 933.5 nothing 0
844 763 right 1
682 639.5 left 2
597 505.5 left+right (calibrate center) 3
414 299 down 4
184 164.5 up 5
145 72.5 up+down (menu) 6
0 0 Dpad button 7
//In case you've used different resistors to what I used, uncomment the serial print command here to find your analog read values:
//Serial.println(analogRead(DPADPIN));
int DpadRead = analogRead(DPADPIN);
int DpadVal = 0;
if (DpadRead > 933) DpadVal = 0;
else if (DpadRead > 763) DpadVal = 1;
else if (DpadRead > 639) DpadVal = 2;
else if (DpadRead > 505) DpadVal = 3;
else if (DpadRead > 299) DpadVal = 4;
else if (DpadRead > 164) DpadVal = 5;
else
DpadVal = 7;
if (DpadVal != prevDpadVal) { // only if button has changed, do something
Serial.print("Dpad button:");
Serial.println(DpadVal);
#if defined HAS_ANALOG_DPAD && defined HAS_TM1637_DISPLAY && defined DEBUG_ANALOG_DPAD
display.showNumberDec(DpadVal, false, 1, 3); // print the dpad value on the lcd screen
dPadBitChange(prevDpadVal, false); // turn the previous Dpad button bit off.
dPadBitChange(DpadVal, true); // turn the current Dpad button bit on.
prevDpadVal = DpadVal;
void dPadBitChange(uint8_t dPadVal, bool bitOn) {
// sets (raises or lowers) the correct button bits according to the Dpad button that was pressed or released
switch (dPadVal) {
case 0: break;
case 1: // right
buttonBitChange(3, bitOn);
break;
case 2: // left
buttonBitChange(2, bitOn);
break;
case 3: // left+right (calibrate wheel center point)
buttonBitChange(18, bitOn); // Dpad button
buttonBitChange(19, bitOn);
break; // Joystick button
case 4: // down
buttonBitChange(4, bitOn);
break;
case 5: // up
buttonBitChange(1, bitOn);
break;
case 7: // Dpad button
break;
void buttonBitChange(uint8_t buttonBit, bool bitOn) {
// changes a selected bit in one of the 3 button bytes to either on (1) or off (0). Valid values for buttonBit is 1 to 24. See buttons list in last comment.
if (bitOn) {
returnData[2 + ((buttonBit - 1) / 8)] |= (1 << (((buttonBit - 1) % 8)));
} else {
returnData[2 + ((buttonBit - 1) / 8)] &= ~(1 << (((buttonBit - 1) % 8)));
void readSerial()
// reads user inputs from serial connection. i = print mosI data, o = print misO data, d = view what is displayed on the rim's alphanumeric display. letters (A,B,C) = selects corresponding button byte (first second or third), numbers (1..7) = changes bits inside the selected byte. So user can send button presses to the wheelbase without having any physical buttons attached.
if (Serial.available() > 0) {
incByte = Serial.read();
Serial.println((char)incByte);
if (incByte == 'i')
printmosibuf();
if (incByte == 'o')
printmisobuf();
if (incByte == 'd')
refreshAlphanumericDisplays(true);
if ((incByte >= 'A') && (incByte <= 'J')) { // send A,B,C to choose 1st, 2nd, 3rd button byte
selectedButtonByte = (incByte - 'A' + 2); // first button byte is 3rd in array, or cell no 2 to cell no 4 in array
Serial.print("Selected button byte:");
Serial.println(selectedButtonByte);
PRINTBIN(returnData[selectedButtonByte]);
Serial.print(" ");
printHex(returnData[selectedButtonByte], 2);
Serial.println();
if ((incByte >= '1') && (incByte <= '8')) {
returnData[selectedButtonByte] ^= (1 << (incByte - '1')); // toggles bit correcsponding to number read by serial print
printmisobuf();
void printHex(int num, int precision) {
char tmp[16];
char format[128];
sprintf(format, "0x%%.%dX", precision);
sprintf(tmp, format, num);
Serial.print(tmp);
void refreshAlphanumericDisplays(bool crc8Stat) {
// display current alphanumeric information through serial port / TM1637 display
bool displaychanged = false;
for (int i = 2; i <= 4; i++) { // cells 2 to 4 in miso data is alphanumeric data
if (mosiBuf != prevAlphaDisp) { // if anything on the display changed, reprint
displaychanged = true;
break;
#ifdef DISPLAY_ALPHANUMERIC_DATA_WHEN_MISMATCH_ON_SERIAL // print to serial in any case (even if packet has bad crc8). (only print to alphanumeric display if it has good crc8)
if (displaychanged) {
#else // prints to serial monitor and alphanumeric display only if packet has good crc8
if (crc8Stat && displaychanged) {
uint8_t p = mosiBuf & 0x7F; // remove the . (dot) bit
switch (p) {
case 0x3f: Serial.print("0"); break;
case 0x6: Serial.print("1"); break;
case 0x5b: Serial.print("2"); break;
case 0x4f: Serial.print("3"); break;
case 0x66: Serial.print("4"); break;
case 0x6d: Serial.print("S"); break;
case 0x7d: Serial.print("6"); break;
case 0x7: Serial.print("7"); break;
case 0x7f: Serial.print("8"); break;
case 0x6f: Serial.print("9"); break;
case 0x39: Serial.print("C"); break;
case 0x38: Serial.print("L"); break;
case 0x8: Serial.print("_"); break;
case 0x79: Serial.print("E"); break;
case 0x54: Serial.print("n"); break;
case 0x71: Serial.print("F"); break;
case 0x76: Serial.print("H"); break;
case 0x5c: Serial.print("o"); break;
case 0x77: Serial.print("A"); break;
case 0x7c: Serial.print("b"); break;
case 0x5e: Serial.print("d"); break;
case 0x50: Serial.print("r"); break;
case 0x30: Serial.print("I"); break;
case 0x73: Serial.print("P"); break;
case 0x78: Serial.print("t"); break;
case 0x40: Serial.print("-"); break;
case 0x3e: Serial.print("u"); break;
case 0x2A: Serial.print("*"); break; // this should really be a floating 'o' (displayed on the top square) but I couldn't find an ascii character for that
default: printHex(p, 2); break;
if (mosiBuf & 0x80) // select only the . (dot) bit
Serial.print(". ");
else
Serial.print(" ");
if (crc8Stat)
prevAlphaDisp = mosiBuf; // only update the previous display array if current packet has good crc8. (If not doing this test, text will not print out to alphanumeric display properly)
if (!crc8Stat)
Serial.println(" [crc8 mismatch]");
else
Serial.println();
if (crc8Stat) { // Only refresh the alphanumeric display if the current packet is intact (has proper crc8 attached to it) {
TM_data[i - 2] = mosiBuf[i];
display.setSegments(TM_data);
void printButtonByteToSerial() {
// Prints the selected button byte to Serial, if it was changed. The button byte can be selected by sending either A,B or C through the serial monitor. The bits in the selected button byte can either be changed by the serial monitor (sending 1 to 7 raises / lowers a specific bit,) or by pressing one of the physical buttons, if you have any attached.
if (millis() > lastPrintMillis + delayMillis) {
if (prevPrintedByte != returnData[selectedButtonByte]) {
Serial.print(" ");
Serial.println();
prevPrintedByte = returnData[selectedButtonByte];
lastPrintMillis = millis();
void printmosibuf() {
Serial.print("MOSI:");
for (int i = 0; i < dataLength; i++) {
printHex(mosiBuf[i], 2);
//Serial.print(mosiBuf[i],HEX);
Serial.print(" ");
Serial.println();
void printmisobuf() {
Serial.print("MISO:");
printHex(returnData[i], 2);
//Serial.print(returnData[i], HEX);
Serial.print(" ");
Serial.println();
void calcOutgoingCrc() {
returnData[dataLength - 1] = crc8(returnData, dataLength - 1); // calculates crc8 for outgoing packet
bool checkIncomingCrc() { // crc check for incoming data. returns true if correct crc8 is found in the incoming data
uint8_t crc = crc8(mosiBuf, dataLength - 1); //Serial.print("calc crc"); //Serial.println(crc,HEX);
if (crc != mosiBuf[dataLength - 1]) {
#ifdef DISPLAY_CRC8_MISMATCH_ON_SERIAL
Serial.println("_____________incoming data crc8 mismatch!________");
printmosibuf();
#ifdef DISPLAY_CRC8_MISMATCH_ON_ALPHANUMERIC
display.setSegments(TM_crc);
return false;
} else
#ifdef DISPLAY_CRC8_MATCH_ON_SERIAL
Serial.println("crc8 match!");
return true;
Clubsport wheel buttons, by bit, from 3rd byte on miso array to 5th byte.
The buttons numbers appear in the fanatec driver (mouse settings tab), and also in the 'clubsport Porsche 911 buttons.png' file.
A
1 D-pad Up
2 D-pad Left
3 D-pad Right
4 D-pad Down
5 Button 11
6 Button 3
7 Button 6
8 Button 4
B
9(1) Right Paddle
12(4) Left paddle
C
18(2) D-pad Button
23(7)
24(8)
example: button 8 on fanatec's driver, number 11 on this list, is controlled by 3rd bit on the 2nd byte, of the 3 bytes that control buttons.
C6 - enters menu
B8C6 - enters shifter calibration mode
To calibrate wheel center,
A. Using the serial monitor, send:
C6 6 23 23 6 6. (each space here means: hit return)
B. Using the Dpad:
Enter the menu by pressing both up+down bubttons on the Dpad,
S_1 will appear on the serial monitor and on the alphanumeric display,
Press both left+right buttons on the Dpad to calibrate wheel center,
Press both up+down on the Dpad to exit menu.
Re: Convert Arduino cod from stm
Codes like SPCR, SPIE, CPHA are likely registers and definitions relevant to other mcus (e.g. ATmega, etc).
It would be necessary to review the functionalities / ref manuals for both the different processors e.g. ATmega and say an STM32 (a particular processor e.g. stm32f401) to understand how to translate between them.
for beginners (in stm32duino), if you prefer an API that is closer to the Arduino API
use the 'official' STM core
in particular start with the Wiki
and use a board that has an MCU like STM32F401, STM32F411 (due ot more sram and flash and (much) faster processors + FPU) or some stm32f4xx
e.g. Nucleo boards
https://github.com/stm32duino/Arduino_C ... -64-boards
some offerings from Adafruit
some offerings from Micropython
https://store.micropython.org/product/PYBLITEv1.0
some offerings from Olimex (get original STM32 for beginners to avoid possible incompatibilities)
some offerings from Aliexpress, Amazon, Ebay e.g. WeAct studio etc
for documents review the wiki e.g. the API section, review some of the codes that is relevant e.g. the examples
and keep the reference manuals e.g. for stm32f401 handy while working on it
stm32 mcus are feature rich (often too rich), and it is harder to learn than simplier processors.
but they offer features that some processors may not have e.g. DMA, which can make things much faster than the simplier processors.
ozcar
Answers: 5
Post by ozcar »
I lifted up you code (which would have been easier if you had made proper use of code tags) and tried to compile it using the "official" STM32DUINO core, and yes, there are several references to AVR registers like SPDR that will need attention, and also definition of an ISR routine.
However, I see other things there that do not make sense to me. For example, there is this in the in the setup() routine:
#ifdef HASBUTTONS
I can see what the intention there is, but "something" has mangled it. Maybe that is also due to not using code tag though, as I can't see that compiling as it is for any other flavour of Arduino.
