WeAct Studio STM32F411CEU6 BlackPill v3.1 crystal is 8 MHz
Fziegler_076
Re: WeAct Studio STM32F411CEU6 BlackPill v3.1 crystal is 8 MHz
Post by Fziegler_076 »
Hello friends !
Hi fpiSTM and ag123 !!!
Today I checked through ST-LINK
I checked through the hal_conf_extra.h file with the setting #define HSE_VALUE 8000000U
Now the LED is blinking!!!
Fziegler_076
Friends, I checked several times today
1.Everything is stitched and working through ST-LINK!
2.Everything is flashed via USB (DFU), but it doesn't work!
How can I deal with firmware via USB (DFU)?
Do I need to write to the Weact Studio engineers about this problem?
Fziegler_076
Some more of my experiments:
1.I'm flashing it through ST-LINK
2.I select "USB CDC Serial"
the test program
Variant №1
I do not make any changes or additions, everything is by default
When connected, the Error - USB device is not connected (the device descriptor request fails) and the LED lights up very slowly - every 3 seconds
Variant №2
Only the hal_conf_extra file is connected.h with the string #define HSE_VALUE 8000000U
When connected, the Error - USB device is not connected (the device descriptor request fails) and the LED lights тnormal - every 1 seconds
Variant №3
I only make changes to the file variant_BLACKPILL_F411CE.cpp
RCC_OscInitStruct.PLL.PLLN = 192;
RCC_OscInitStruct.PLL.PLLQ = 4;
The COM port appears in the Windows Device Manager and the LED lights up very slowly - every 3 seconds
Variant №4
and
The COM port appears in the Windows Device Manager and the LED lights normal - every 1 seconds
The exchange with the serial port is normal, data is sent to the serial monitor (Serial.println("Test");)
Is there any way to optimize variant №4?
among the things to try, after successfully flashing through st-link, try with DFU again, maybe make some changes so as to tell that that is installed from DFU.
it is quite possible the flash could be write protected. But that with st-link, there is a special means connect under reset which can override the write protection.
if you can work with @fpiSTM to do a commit for a new variant for 8 Mhz (by means of a PR pull request)
do help to test that.
the files that are needed to be updated are a copy of that variant file with a new name,
and maybe some other source files (i'm not sure but you'd need to check), e.g. the include header file for the board, I'm not sure if 2 variant cpp files can share the same board include file.
then look in boards.txt to copy and update relevant entries for the variant
and i'm not sure if platform.txt needs any updates, normally that can be left alone without changes
Fziegler_076
Yes, I'll check it out tomorrow morning.
Of course, I'm ready to do everything.
What is it? How do I do this?
Fziegler_076 wrote: Mon Apr 22, 2024 7:55 am
to make a PR, first first click [fork] to make a copy of stm32duino repository
then do a git clone from your fork (copy) of the repository
https://gitforwindows.org/
then locally on your PC:
on your pc you can then edit codes and test locally, it may take copying files to/from the local git folder if your ide (e.g. arduino folders) if it don't directly support that.
next few items need to be done from your local git folder:
to see the list of changed files do a 'git status', to add the files type 'git add *'
when done, then do a 'git commit', type in your git comment e.g. 'new variant stm32f411ce 8mhz ... etc'
and 'git push' to get the changes into your repository in github
then back to github:
then you can follow the instructions on github e.g. click compare and pull request
https://docs.github.com/en/pull-request ... rom-a-fork
the steps from the edits, followed by 'git status', 'git add *', 'git commit', 'git push' can be iterative e.g. you can make the changes several time repeating these steps.
and that should generate a pull request
I would recommend to simply declare the new boards entry and add it to the existing variant for the blackPill F411CE.
Like it is done for the *PillF103:
https://github.com/stm32duino/Arduino_C ... pp#L13-L14
Example add it with name:
 BLACKPILL_F411CE_8MHZ
Then simply duplicate entry in boards.txt with the new name, reference it in the README.md.
Finally add the new define in the cpp: variant_BLACKPILL_F411CE.cpp:
#if defined(ARDUINO_BLACKPILL_F411CE) || defined(ARDUINO_BLACKPILL_F411CE_8MHZ)
And add the new config SystemClock_Config under swith:
#if defined(ARDUINO_BLACKPILL_F411CE_8MHZ)
// new config
#else
// standard
Finally in the variant_BLACKPILL_F411CE, defined the correct HSE_VALUE thanks the define
#ifndef HSE_VALUE
#else
  #define HSE_VALUE             25000000U
Fziegler_076
Hi !
I checked it out.
The firmware is being flashed, but unfortunately it does not work (
The program works only with firmware via ST-LINK.
Dear @fpiSTM!
I kind of did as you wrote to me, but my lack of experience didn't give me any results.
In the menu in the Arduino IDE, the choice of a board with 8 MHz HSE does not appear.
Can you, as a professional, look at and correct my mistakes?
I'm attaching what I changed in the files
Blackpill_F411CE_8.zip
(70.31 KiB) Downloaded 11 times
Arduino IDE 2 have/had issue with menu update. On older version of the IDE (prio 2.3.x), the menu is not refresh at startup.
This could explain your issue.
