‘MCU basic current’ increases after PWM operation. help me.
myksj1105
Post by myksj1105 »
- core: https://github.com/rogerclarkmelbourne/Arduino_STM32
1. If there is no operation, the total current of 0.07A flows.
2. Turn on PWM
- (source code)pinMode(PA6, PWM); pwmWrite(PA6, 5000);
3. Turn off PWM
- (source code)pinMode(PA6, PWM); pwmWrite(PA6, 0);
4. The total current has increased.
- A total current of 0.22A flows.
- MCU power consumption has increased.
5. I wanted to restore it to its original state through soft reset, but the current remains the same.
- (source code) nvic_sys_reset();
- Total current 0.22A
6. If you turn off the entire power and turn it back on,
- Total current 0.07A
The conclusion is that after using 'pwmWrite', the power consumption of the MCU increases (increases).
Even if the pwm is turned off, the ‘MCU power consumption’ remains increased.
Moreover, even with ‘software power reset’, ‘MCU power consumption’ has increased.
Q1. I don't know why.
Q2. I want to solve it.
- I think it needs to be powered down and then turned on again. Is there a way?
video
https://drive.google.com/file/d/1O5L-9e ... sp=sharing
help me.
Re: ‘MCU basic current’ increases after PWM operation. help me.
myksj1105
Post by myksj1105 »
In the actual code, three PWMs are used.
const int PWM_P[] = {PB0, PA6, PA8};
for (int i=0; i<3; i++){ pinMode(PWM_P ,PWM); }
Timer1.pause(); Timer2.pause(); Timer3.pause(); Timer1.setChannel1Mode(TIMER_PWM); Timer2.setChannel2Mode(TIMER_PWM); Timer3.setChannel3Mode(TIMER_PWM);
Timer1.setPeriod(2000); Timer2.setPeriod(2000); Timer3.setPeriod(2000);
Timer1.resume(); Timer2.resume(); Timer3.resume();
https://drive.google.com/file/d/1Zzc4RW ... Ei0S8/view
1. The video was filmed in detail.
2. to be more precise,
The summed current is the corresponding power consumption because it is two regulators and an MCU. So, the video is not wrong. The entire 0.22A is not the MCU increase. However, as the MCU current increased, the regulator current also increased.
(The regulator is 5V, 3.3V.)
Now, the reason the current is reduced compared to the previous video is because the input voltage of the regulator is lowered.
- And, the actual MCU is very hot.
- So, I installed a heat sink.
3. When I tested it,
pwmWrite(PA6, 3500); If you use , the MCU seems to get hot. What does it feel like?
1) Basic mode
2) Acceleration mode
It operates in acceleration mode.
However, what is interesting is that the ‘acceleration mode’ does not change by reinstalling the firmware or resetting the software. It only operates in 'default mode' when the power is turned on again.
My assumptions are as follows:
1. As pwmWrite is used, the current in the ‘MCU’ increases.
- in terms
1) Basic mode
Let’s say there are two modes.
- When pwmWrite is used, it enters Acceleration mode.
- Even if pwmWrite is set to '0', it goes into Acceleration mode.
- As a result, the MCU current increases.
2. Through ‘firmware upload’ or ‘software reset’
You cannot escape ‘Acceleration mode’.
Here's what I feel right now:
