Changing the PWM frequency
Answers: 8
Re: Changing the PWM frequency
Is the desired frequency 10kHz?
How do you know that is not correct? How did you measure it?
The problem is that when you set the period, you don't know which value your overflow register will get.
When you call pwmWrite the compare register will be set but the relationship between the overflow register and compare register is still not determined.
Instead, try following code:
#define t Timer1 // Timer 1 already declared in the core files so you do not have to declare another instance of it
#define MY_FREQ  10000 // in Hz
#define MY_PERIOD  ((1000000/MY_FREQ) - 1) // in µsec
  pinMode(pwmOutPin, PWM);
  t.pause(): // stop the timer
  t.setCount(0); // reset counter
  t.setMode(TIMER_CH1, TIMER_OUTPUT_COMPARE); // adapt for your channel
  t.setPrescaleFactor(72); // input clock 1 MHz
  t.setOverflow(MY_PERIOD);  // 100µsec, period 10 kHz
  t.setCompare(TIMER_CH1, (MY_PERIOD/2));   // adapt for your channel
  t.refresh();
  t.resume();
Her you can see which channel is used by the selected pin (4th value):
https://github.com/rogerclarkmelbourne/ ... pp#L58-L94
Answers: 8
Please use this piece of code
int psc = t.getPrescaleFactor();
int ovfl = t.getOverflow();
while(!Serial); delay(10);
Serial.print("psc="); Serial.println(psc);
Serial.print("ovfl="); Serial.println(ovfl);
after you set the timer and post here the result of psc and ovfl.
You will get the good output frequency if you use
#define MY_PERIOD ((1000000/MY_FREQ) - 1) // subtraction is needed
in my code posted above.
fredbox
Post by fredbox »
Here is a snippet from one of my projects with a 60khz square wave output on PA6;
// set timer 3 to 60KHZ square wave on PA6 - T3C1
HardwareTimer pwmtimer(3);
  pinMode(PA6, PWM);
  pwmtimer.pause();
  pwmtimer.setPrescaleFactor(1);
  pwmtimer.setOverflow(1200 - 1); // 72MHZ / 1200 = 60KHZ
  pwmtimer.setCompare(TIMER_CH1, 600);  // 50% duty cycle
  pwmtimer.refresh();
  pwmtimer.resume();
To change the duty cycle, use pwmtimer.setCompare(TIMER_CH1, n) where n varies from 1 to 1198.
