USB reset issue in the Bootloader and libmaple core
Information on the latest releases
fra
Re: USB reset issue in the Bootloader and libmaple core
Post by fra » Thu Dec 01, 2016 9:48 pm
Hi guys, I may have found a workaround on this.
Two symptoms:
1) after a sketch upload I have to wait 15-20 seconds before I can open the USB Serial, otherwise I get the error message
Error opening serial port '/dev/ttyACM0'. (Port busy)
2) In between two uploads I have to push the reset button (see http://www.stm32duino.com/viewtopic.php?t=475)
I have a Maple-Mini Baite clone
I am using Ubuntu 16.04 LTS (probably the bug is on their side as the same board works fine with Windows)
I noticed that the reset code was hanging exactly in the same way as the IDE when switching back to Serial USB.
upload_reset /dev/ttyACM0 750
I also noticed that running dmesg after each reset command I could find the following error:
cdc_acm 2-3:1.0: failed to set dtr/rts
Looking into this article https://bugs.launchpad.net/ubuntu/+sour ... ug/1473246 I found that the symptoms would be due to a bug of the Ubuntu ModemManager that recognizes the board as a modem.
As suggested the workaround is to blacklist the device adding the following snippet into the corresponding rule:
ENV{ID_MM_DEVICE_IGNORE}="1"
So in my case the file called "45-maple.rules" would look like this:
ATTRS{idProduct}=="1001", ATTRS{idVendor}=="0110", MODE="664", GROUP="plugdev"
ATTRS{idProduct}=="1002", ATTRS{idVendor}=="0110", MODE="664", GROUP="plugdev"
ATTRS{idProduct}=="0003", ATTRS{idVendor}=="1eaf", MODE="664", GROUP="plugdev" SYMLINK+="maple", ENV{ID_MM_DEVICE_IGNORE}="1"
ATTRS{idProduct}=="0004", ATTRS{idVendor}=="1eaf", MODE="664", GROUP="plugdev" SYMLINK+="maple", ENV{ID_MM_DEVICE_IGNORE}="1"
Rerun the install.sh and the two symptoms above disappear...
Hope this helps.
RogerClark
Post by RogerClark » Thu Dec 01, 2016 10:38 pm
fra wrote:Hi guys, I may have found a workaround on this.
Two symptoms:
Hope this helps.
Very interesting.
If some other linux users can test this on their installations (e.g. Linux mint etc), I would be happy to update the repo with this change.
BTW. Windows users have similar issues, because the IDE doesnt seem to close the serial terminal before upload, and if you leave it open, then you get a load of Java errors in the iDE when the Serial USB re-appears (and you still can't use the terminal without resetting the board)
ahull
Post by ahull » Thu Dec 01, 2016 11:26 pm
:D I just flashed the tiny-o-scope code I was working on earlier to my test board. Five uploads one after the other, no problems... usb serial worked every time too... so far so good.
- Andy Hull -
RogerClark
Post by RogerClark » Thu Dec 01, 2016 11:32 pm
Thanks guys
I've updated the repo
SukkoPera
Post by SukkoPera » Wed Apr 19, 2017 9:37 am
Sorry for the delay. I've just come to the same conclusion, i.e.: the cr*ppy ModemManager interferes with my ttyACM* ports :evil:.
The udev rules change seems to fix the issue, at least partly: if I upload while the serial monitor is open, the upload succeeds, but then I get the usual "Port busy" error. Anyway now I can just close and reopen the serial monitor and it will connect as expected. So, well done! ;)
Just one minor thing: you only applied the changes to the 45-maple.rules file under the linux directory. You should replicate the changes under the linux64 directory as well. There's also another copy of that file under STM32F1/system/support/scripts/45-maple.rules so that should be fixed as well, or maybe removed altogether?
Bingo600
Post by Bingo600 » Wed Apr 19, 2017 5:16 pm
Maybe try this one , modem-mgr blacklist
viewtopic.php?f=22&t=1892#p25160
/Bingo
Who is online
Users browsing this forum: No registered users and 2 guests
