Getting Blinky to work on STM32 Value line Discovery board STM32F100RB
Any other STM32 based boards
ProudPagan
Post by ProudPagan » Thu Feb 16, 2017 5:16 am
Hi All,
I have used the Arduino framework+IDE for AVR and ESP8266, but can't get a blinky to work on the STM32 Value Line Discovery board STM32F100RB.
I have 2017.1.20 version of STM32F1xx Core installed. I see the code correctly compiled, linked and uploaded to the board:
STM32 ST-LINK CLI v2.1.0
STM32 ST-LINK Command Line Interface
ST-LINK SN : ST-Link/V1 on E:
ST-LINK Firmware version : V1J11S0 (Need Update)
Old ST-LINK firmware detected!
Please upgrade it from ST-LINK->'Firmware update' menu.
Connected via SWD.
Connection mode : Normal.
Device ID:0x420
Device flash Size : 128 Kbytes
Device family :STM32F100xx Low/Medium density Value Line
Loading file...
Flash Programming:
  File : C:\Temp\arduino_build_193593\sketch_feb14a.ino.bin
  Address : 0x08000000
Flash memory programming...
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0%
 0%ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 45%ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 90%ÛÛÛÛÛ 100%
Flash memory programmed in 1s and 388ms.
Programming Complete.
MCU Reset.
Application started.
But I don't see the LED flashing. I am using the on board LED connected to GPIO port PC9.
This is the code:
const int MYPIN = PC9;
  pinMode(MYPIN, OUTPUT);
  digitalWrite(MYPIN  , HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1500);                       // wait for a second
  digitalWrite(MYPIN, LOW);    // turn the LED off by making the voltage LOW
Any help would be greatly appreciated!
PP
Pito
Re: Getting Blinky to work on STM32 Value line Discovery board STM32F100RB
Post by Pito » Sat Feb 18, 2017 8:24 pm
Did you compile for "Upload method STLink" ?
zmemw16
Post by zmemw16 » Sun Feb 19, 2017 12:36 am
tongue in cheek, maybe use the classic G Brown STM32 book for guidance.
i do know his sources and the SPL do compile and work on Linux. nod nod ;) ;)
stephen
ProudPagan
Post by ProudPagan » Tue Feb 21, 2017 8:29 am
Pito wrote:Did you compile for "Upload method STLink" ?
Yes, I see only STLink as the upload method -- and I used that. I see lights on the board flashing for a few seconds, so I think upload
is done correctly.
Thanks for all help.
--PP
nikosx
Post by nikosx » Sun May 07, 2017 4:52 pm
Did you get the LEDS blink ? Had the same problem....
Post by dannyf » Sun Jun 04, 2017 10:59 am
step through your code and see what changes to the gpio registers. pay particular attention to CR1/CR2.
Who is online
Users browsing this forum: No registered users and 0 guests
