Improving pinMode
What could be included in further releases, or for the forum.
aster
Improving pinMode
Post by aster » Tue Apr 11, 2017 8:38 am
Maybe i missed something (i am new here) but am i wrong or i can t use some of the nice features of the stm32 like the pulldown input?
I would like to add this: pinMode(pin, INPUT_PULLDOWN)
Another function i would like to add is to choose the speed of gpio for example pinMode(pin, OUTPUT, LOWSPEED)
Maybe more experienced people than me tried and it is not simple,so i thought to write here before trying it
Tell me and i will try then i post the code here :)
racemaniac
Re: Improving pinMode
Post by racemaniac » Tue Apr 11, 2017 8:50 am
aster wrote:Hello,
INPUT_PULLDOWN should already work
http://wiki.stm32duino.com/index.php?ti ... #Pin_Modes
and about the speed, what would be the advantage in being able to define that? atm it defaults to the highest speed i think, is there any reason we would want it differently?
Post by stevestrong » Tue Apr 11, 2017 8:57 am
You cannot activate only the built-in pull-down resistor separately from the pull-up resistor.
See available modes in RM0008 chapters 9.2.1, 9.2.2:
CNFy[1:0]: Port x configuration bits (y= 0 .. 7)
These bits are written by software to configure the corresponding I/O port.
Refer to Table 20: Port bit configuration table.
In input mode (MODE[1:0]=00):
00: Analog mode
01: Floating input (reset state)
10: Input with pull-up / pull-down
11: Reserved
Regarding the IO speed, there is no reason to set the pins to lower speed, default is max 50MHz.
In general, one want to squeeze out the maximum from the device...
aster
Post by aster » Tue Apr 11, 2017 9:08 am
I tried it yesterday and it didn t worked, for sure i wrote it wrong :cry:
Yep about the speed it is not so usefull except for power saving application (not my case)
Post by stevestrong » Tue Apr 11, 2017 9:55 am
OK, I have to reformulate: The F103 does not have any INPUT_PULLDOWN mode.
The wiki should be corrected as well.
aster
Post by aster » Tue Apr 11, 2017 10:33 am
Mmm what about adding it? In this way the wiki will be correct :roll:
edogaldo
Post by edogaldo » Tue Apr 11, 2017 10:39 am
aster wrote:Mmm what about adding it? In this way the wiki will be correct :roll:
You should propose it to STM as it them that produce the chip.. ;)
Sorry, double checking the RM, it's possible, I need to better study GPIOs..
danieleff
Post by danieleff » Tue Apr 11, 2017 10:43 am
stevestrong wrote:OK, I have to reformulate: The F103 does not have any INPUT_PULLDOWN mode.
But it has, and is here: https://github.com/rogerclarkmelbourne/ ... e/io.h#L84
Post by stevestrong » Tue Apr 11, 2017 11:21 am
Maybe the software has it but the hardware definitely not:
stevestrong wrote:You cannot activate only the built-in pull-down resistor separately from the pull-up resistor.
00: Analog mode
11: Reserved
edogaldo
Post by edogaldo » Tue Apr 11, 2017 11:52 am
stevestrong wrote:Maybe the software has it but the hardware definitely not:
00: Analog mode
11: Reserved
RM0008, table 20 @ page 160: it has and seems correctly configured in the core.. ;)
