Working library for SSD1306
What are you developing?
dev
Post by dev » Wed May 17, 2017 5:28 pm
HI,
I searched in the forum and i got many threads on the same topic. which create some confusion in my mind.
Then i took example from STM32 library examples. After compliation i got error. Following are the error.
In file included from C:\Users\ajink\Documents\Arduino\my\oled\oled\oled.ino:1:0:
C:\Users\ajink\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_SSD1306/Adafruit_SSD1306_STM32.h:38:26: fatal error: Adafruit_GFX.h: No such file or directory
 #include <Adafruit_GFX.h>
compilation terminated.
exit status 1
Error compiling for board Generic STM32F103C series.
how to add these library?
Is it hardaware I2C or bit bang?
zmemw16
Re: Working library for SSD1306
Post by zmemw16 » Wed May 17, 2017 5:36 pm
Post by stevestrong » Wed May 17, 2017 5:38 pm
You should download the Adafruit GFX library from here: https://github.com/adafruit/Adafruit-GFX-Library
and extract the zip to the STM32F1/libraries folder.
dev
Post by dev » Wed May 17, 2017 6:11 pm
Thanks.
@stevestrong, I copied the library to \STM32F1\libraries\Adafruit_SSD1306 path but still getting error.
C:\Users\ajink\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_SSD1306\Adafruit_SSD1306_STM32.cpp: In member function 'virtual void Adafruit_SSD1306::drawPixel(int16_t, int16_t, uint16_t)':
C:\Users\ajink\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_SSD1306\Adafruit_SSD1306_STM32.cpp:115:14: error: 'swap' was not declared in this scope
     swap(x, y);
C:\Users\ajink\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_SSD1306\Adafruit_SSD1306_STM32.cpp: In member function 'virtual void Adafruit_SSD1306::drawFastHLine(int16_t, int16_t, int16_t, uint16_t)':
C:\Users\ajink\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_SSD1306\Adafruit_SSD1306_STM32.cpp:571:16: error: 'swap' was not declared in this scope
       swap(x, y);
C:\Users\ajink\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_SSD1306\Adafruit_SSD1306_STM32.cpp: In member function 'virtual void Adafruit_SSD1306::drawFastVLine(int16_t, int16_t, int16_t, uint16_t)':
C:\Users\ajink\Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_SSD1306\Adafruit_SSD1306_STM32.cpp:639:16: error: 'swap' was not declared in this scope
       swap(x, y);
exit status 1
I took example from \STM32F1\libraries\Adafruit_SSD1306\examples\ssd1306_128x64_i2c_STM32\ssd1306_128x64_i2c_STM32.ino
Is it correct?
Post by stevestrong » Wed May 17, 2017 8:12 pm
Search the repo for swap and add the definition to the header file.
dev
Post by dev » Thu May 18, 2017 6:00 pm
But, Is there working library and example?
Because i was trying to correct the error before posting here.
zmemw16
Post by zmemw16 » Thu May 18, 2017 9:13 pm
have you configured the 1306 header file for the display type and size ?
srp
dev
Post by dev » Fri May 26, 2017 5:38 pm
yes, i have define LCD type and size of lcd as well in Adafruit_SSD1306_STM32.h
found the solution. Defined
#define swap(a, b) { int16_t t = a; a = b; b = t; }
and it compiled. Soon i will checking on hardware.
dev
Post by dev » Sun May 28, 2017 12:43 pm
I checked on hardware but its not working. I have connected oled to
pb10 scl
pb11 sda
Is it correct?
I am using it as per written in comment in the file header.
dev
Post by dev » Mon May 29, 2017 6:06 pm
When i flashed the code then processor not at all going in loop function.
No Backlight on oled display.
i thinking getting stuck in setup only.
