ADAFRUIT SSD1331 SPI OLED DISPLAY
LEONARDOMS
Post by LEONARDOMS » Fri Jul 14, 2017 6:28 pm
Hello Guys. I´m new to STM32 boards. I´m using the Blue Pill STM2 board. I´m currently trying to develop some car gauge applications with the a color OLED display with the SSD1331 controller. I´m having lots of problems making a compilable code . I´ve compiled the ssd1306 with adafruit_gfx_as libs, successfully. I tried to make some modifications on the ssd1331 LIB , but no success. Any advice?
zmemw16
Re: ADAFRUIT SSD1331 SPI OLED DISPLAY
Post by zmemw16 » Sat Jul 15, 2017 12:06 am
much like google, github is your friend
https://github.com/search?utf8=%E2%9C%9 ... 1331&type=
stephen
LEONARDOMS
Post by LEONARDOMS » Sat Jul 15, 2017 11:20 am
zmemw16, thank you very much. I took a look at the libs and none seem to be for the stm32. Have you tried any of them? The SSD13xx compiles, but I can not find where to configure the SPI pins.
zmemw16
Post by zmemw16 » Sat Jul 15, 2017 12:49 pm
nope, surprisingly for me i haven't got one. :o
which one did you use ? link is ?
try a search on the forum about porting libraries.
look closely for conditionals about the architecture,
if (avr) sort of thing, probably it will be lose.
if(teensy) is one that is code possibly worth keeping, well not deleting it immediately.
timers will be interesting as would interrupt code.
there are libraries already 'ported', try reading thought the originals and compare to see what's been done.
spi - look at the constructors and at their implementation, usually they'll have some defaults set up and then the constructor will change them. they are pretty much all the same :)
there are actually very few square wheels that haven't had the corners knocked off. :)
stephen
LEONARDOMS
Post by LEONARDOMS » Sat Jul 15, 2017 8:35 pm
Hello. I modified the SSD1331 and now is compiling. But the display remains black.
Could someone please check if my test code is missing something?
#define sclk PB3
#define mosi PB5
#define cs   PA10
#define rst  PA8
#define dc   PA9
// Color definitions
#define	BLACK           0x0000
#define	BLUE            0x001F
#define	RED             0xF800
#define	GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
#include <Adafruit_GFX_AS.h>
#include <Adafruit_SSD1331.h>
#include <SPI.h>
// Option 1: use any pins but a little slower
Adafruit_SSD1331 display = Adafruit_SSD1331(cs, dc, mosi, sclk, rst);
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
//Adafruit_SSD1331 display = Adafruit_SSD1331(cs, dc, rst);
float p = 3.1415926;
void setup(void) {
  display.begin();
  SPI.setDataMode(SPI_MODE0); //Set the  SPI data mode 0
  SPI.setClockDivider(SPI_CLOCK_DIV32); // 2.25  MHz
  uint16_t time = millis();
  display.fillScreen(BLACK);
  time = millis() - time;
  lcdTestPattern();
  display.setCursor(0,0);
  display.print("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa");
  // tft print function!
  tftPrintTest();
  delay(2000);
  //a single pixel
  display.drawPixel(display.width()/2, display.height()/2, GREEN);
  delay(500);
  // line draw test
  testlines(YELLOW);
  delay(500);
  // optimized lines
  testfastlines(RED, BLUE);
  delay(500);
  testdrawrects(GREEN);
  testfillrects(YELLOW, MAGENTA);
  testfillcircles(10, BLUE);
  testdrawcircles(10, WHITE);
  testroundrects();
  delay(500);
  testtriangles();
  delay(500);
  Serial.println("done");
void testlines(uint16_t color) {
   for (int16_t x=0; x < display.width()-1; x+=6) {
     display.drawLine(0, 0, x, display.height()-1, color);
   for (int16_t y=0; y < display.height()-1; y+=6) {
     display.drawLine(0, 0, display.width()-1, y, color);
     display.drawLine(display.width()-1, 0, x, display.height()-1, color);
     display.drawLine(display.width()-1, 0, 0, y, color);
     display.drawLine(0, display.height()-1, x, 0, color);
     display.drawLine(0, display.height()-1, display.width()-1, y, color);
     display.drawLine(display.width()-1, display.height()-1, x, 0, color);
     display.drawLine(display.width()-1, display.height()-1, 0, y, color);
void testdrawtext(char *text, uint16_t color) {
  display.setTextSize(1);
  display.setTextColor(WHITE);
  for (uint8_t i=0; i < 168; i++) {
    if (i == '\n') continue;
    display.write(i);
    if ((i > 0) && (i % 21 == 0))
      display.println();
void testfastlines(uint16_t color1, uint16_t color2) {
   for (int16_t y=0; y < display.height()-1; y+=5) {
     display.drawFastHLine(0, y, display.width()-1, color1);
   for (int16_t x=0; x < display.width()-1; x+=5) {
     display.drawFastVLine(x, 0, display.height()-1, color2);
void testdrawrects(uint16_t color) {
 for (int16_t x=0; x < display.height()-1; x+=6) {
   display.drawRect((display.width()-1)/2 -x/2, (display.height()-1)/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
 for (int16_t x=display.height()-1; x > 6; x-=6) {
   display.fillRect((display.width()-1)/2 -x/2, (display.height()-1)/2 -x/2 , x, x, color1);
   display.drawRect((display.width()-1)/2 -x/2, (display.height()-1)/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (uint8_t x=radius; x < display.width()-1; x+=radius*2) {
    for (uint8_t y=radius; y < display.height()-1; y+=radius*2) {
      display.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=0; x < display.width()-1+radius; x+=radius*2) {
    for (int16_t y=0; y < display.height()-1+radius; y+=radius*2) {
      display.drawCircle(x, y, radius, color);
void testtriangles() {
  int color = 0xF800;
  int t;
  int w = display.width()/2;
  int x = display.height();
  int y = 0;
  int z = display.width();
  for(t = 0 ; t <= 15; t+=1) {
    display.drawTriangle(w, y, y, x, z, x, color);
    x-=4;
    y+=4;
    z-=4;
    color+=100;
void testroundrects() {
  int color = 100;
  int i;
  int t;
  for(t = 0 ; t <= 4; t+=1) {
  int x = 0;
  int y = 0;
  int w = display.width();
  int h = display.height();
    for(i = 0 ; i <= 24; i+=1) {
    display.drawRoundRect(x, y, w, h, 5, color);
    x+=2;
    y+=3;
    w-=4;
    h-=6;
    color+=1100;
  color+=100;
void tftPrintTest() {
  display.setCursor(0, 5);
  display.setTextColor(RED);
  display.println("Hello World!");
  display.setTextColor(YELLOW, GREEN);
  display.setTextSize(2);
  display.print("Hello Wo");
  display.setTextColor(BLUE);
  display.setTextSize(3);
  display.print(1234.567);
  delay(1500);
  display.setTextSize(0);
  display.setTextColor(GREEN);
  display.print(p, 5);
  display.println(" Want pi?");
  display.print(8675309, HEX); // print 8,675,309 out in HEX!
  display.print(" Print HEX");
  display.println("Sketch has been");
  display.println("running for: ");
  display.setTextColor(MAGENTA);
  display.print(millis() / 1000);
  display.print(" seconds.");
void mediabuttons() {
 // play
  display.fillRoundRect(25, 10, 78, 60, 8, WHITE);
  display.fillTriangle(42, 20, 42, 60, 90, 40, RED);
  delay(500);
  // pause
  display.fillRoundRect(25, 90, 78, 60, 8, WHITE);
  display.fillRoundRect(39, 98, 20, 45, 5, GREEN);
  display.fillRoundRect(69, 98, 20, 45, 5, GREEN);
  delay(500);
  // play color
  display.fillTriangle(42, 20, 42, 60, 90, 40, BLUE);
  delay(50);
  // pause color
  display.fillRoundRect(39, 98, 20, 45, 5, RED);
  display.fillRoundRect(69, 98, 20, 45, 5, RED);
  // play color
  display.fillTriangle(42, 20, 42, 60, 90, 40, GREEN);
    @brief  Renders a simple test pattern on the LCD
void lcdTestPattern(void)
  uint32_t i,j;
  display.goTo(0, 0);
  for(i=0;i<64;i++)
    for(j=0;j<96;j++)
      if(i>55){display.writeData(WHITE>>8);display.writeData(WHITE);}
      else if(i>47){display.writeData(BLUE>>8);display.writeData(BLUE);}
      else if(i>39){display.writeData(GREEN>>8);display.writeData(GREEN);}
      else if(i>31){display.writeData(CYAN>>8);display.writeData(CYAN);}
      else if(i>23){display.writeData(RED>>8);display.writeData(RED);}
      else if(i>15){display.writeData(MAGENTA>>8);display.writeData(MAGENTA);}
      else if(i>7){display.writeData(YELLOW>>8);display.writeData(YELLOW);}
      else {display.writeData(BLACK>>8);display.writeData(BLACK);}
LEONARDOMS
Post by LEONARDOMS » Sat Jul 15, 2017 8:57 pm
Adafruit_GFX_AS.h
#ifndef _ADAFRUIT_GFX_H
#define _ADAFRUIT_GFX_H
#include "Load_fonts.h"
#if ARDUINO >= 100
 #include "Arduino.h"
 #include "Print.h"
#else
 #include "WProgram.h"
#define swap(a, b) { int16_t t = a; a = b; b = t; }
class Adafruit_GFX : public Print {
 public:
  Adafruit_GFX(int16 w, int16 h); // Constructor
  // This MUST be defined by the subclass:
  virtual void drawPixel(int16 x, int16 y, uint16 color) = 0;
  // These MAY be overridden by the subclass to provide device-specific
  // optimized code.  Otherwise 'generic' versions are used.
  virtual void
    drawLine(int16 x0, int16 y0, int16 x1, int16 y1, uint16 color),
    drawFastVLine(int16 x, int16 y, int16 h, uint16 color),
    drawFastHLine(int16 x, int16 y, int16 w, uint16 color),
    drawRect(int16 x, int16 y, int16 w, int16 h, uint16 color),
    fillRect(int16 x, int16 y, int16 w, int16 h, uint16 color),
    fillScreen(uint16 color),
    invertDisplay(boolean i);
  // These exist only with Adafruit_GFX (no subclass overrides)
  void
    drawCircle(int16 x0, int16 y0, int16 r, uint16 color),
    drawCircleHelper(int16 x0, int16 y0, int16 r, uint8_t cornername,
      uint16 color),
    fillCircle(int16 x0, int16 y0, int16 r, uint16 color),
    fillCircleHelper(int16 x0, int16 y0, int16 r, uint8_t cornername,
      int16 delta, uint16 color),
    drawTriangle(int16 x0, int16 y0, int16 x1, int16 y1,
      int16 x2, int16 y2, uint16 color),
    fillTriangle(int16 x0, int16 y0, int16 x1, int16 y1,
    drawRoundRect(int16 x0, int16 y0, int16 w, int16 h,
      int16 radius, uint16 color),
    fillRoundRect(int16 x0, int16 y0, int16 w, int16 h,
    drawBitmap(int16 x, int16 y, const uint8_t *bitmap,
    drawChar(int16 x, int16 y, unsigned char c, uint16 color,
      uint16 bg, uint8_t size),
    setCursor(int16 x, int16 y),
    setTextColor(uint16 c),
    setTextColor(uint16 c, uint16 bg),
    setTextSize(uint8 s),
    setTextWrap(boolean w),
    setRotation(uint8 r);
    int16 drawUnicode(uint16 uniCode, int16 x, int16 y, int16 size);
    int16 drawNumber(long long_num,int16 poX, int16 poY, int16 size);
    int16 drawChar(char c, int16 x, int16 y, int16 size);
    int16 drawString(char *string, int16 poX, int16 poY, int16 size);
    int16 drawCentreString(char *string, int16 dX, int16 poY, int16 size);
    int16 drawRightString(char *string, int16 dX, int16 poY, int16 size);
    int16 drawFloat(float floatNumber,int16 decimal,int16 poX, int16 poY, int16 size);
#if ARDUINO >= 100
  virtual size_t write(uint8);
#else
  virtual void   write(uint8);
  int16
    height(void),
    width(void);
  uint8 getRotation(void);
 protected:
  const int16
    WIDTH, HEIGHT;   // This is the 'raw' display w/h - never changes
  int16
    _width, _height, // Display w/h as modified by current rotation
    cursor_x, cursor_y;
  uint16
    textcolor, textbgcolor;
  uint8
    textsize,
    rotation;
  boolean
    wrap; // If set, 'wrap' text at right edge of display
#endif // _ADAFRUIT_GFX_H
LEONARDOMS
Post by LEONARDOMS » Sat Jul 15, 2017 8:59 pm
Adafruit_GFX_AS.cpp
This is the core graphics library for all our displays, providing a common
set of graphics primitives (points, lines, circles, etc.).  It needs to be
paired with a hardware-specific library for each display device we carry
(to handle the lower-level functions).
Adafruit invests time and resources providing this open source code, please
support Adafruit & open-source hardware by purchasing products from Adafruit!
Copyright (c) 2013 Adafruit Industries.  All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
- Redistributions of source code must retain the above copyright notice,
  this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice,
  this list of conditions and the following disclaimer in the documentation
  and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
#include "Adafruit_GFX_AS.h"
#ifdef LOAD_GLCD
  #include "glcdfont.c"
#ifdef LOAD_FONT2
  #include "Font16.h"
#ifdef LOAD_FONT4
#include "Font32.h"
#ifdef LOAD_FONT6
#include "Font64.h"
#ifdef LOAD_FONT7
  #include "Font7s.h"
#ifdef __AVR__
 #include <avr/pgmspace.h>
#else
 #define pgm_read_byte(addr) (*(const unsigned char *)(addr))
Adafruit_GFX::Adafruit_GFX(int16_t w, int16_t h):
  WIDTH(w), HEIGHT(h)
  _width    = WIDTH;
  _height   = HEIGHT;
  rotation  = 0;
  cursor_y  = cursor_x    = 0;
  textsize  = 1;
  textcolor = textbgcolor = 0xFFFF;
  wrap      = true;
// Draw a circle outline
void Adafruit_GFX::drawCircle(int16_t x0, int16_t y0, int16_t r,
    uint16_t color) {
  int16_t f = 1 - r;
  int16_t ddF_x = 1;
  int16_t ddF_y = -2 * r;
  int16_t x = 0;
  int16_t y = r;
  drawPixel(x0  , y0+r, color);
  drawPixel(x0  , y0-r, color);
  drawPixel(x0+r, y0  , color);
  drawPixel(x0-r, y0  , color);
  while (x<y) {
    if (f >= 0) {
      y--;
      ddF_y += 2;
      f += ddF_y;
    x++;
    ddF_x += 2;
    f += ddF_x;
    drawPixel(x0 + x, y0 + y, color);
    drawPixel(x0 - x, y0 + y, color);
    drawPixel(x0 + x, y0 - y, color);
    drawPixel(x0 - x, y0 - y, color);
    drawPixel(x0 + y, y0 + x, color);
    drawPixel(x0 - y, y0 + x, color);
    drawPixel(x0 + y, y0 - x, color);
    drawPixel(x0 - y, y0 - x, color);
void Adafruit_GFX::drawCircleHelper( int16_t x0, int16_t y0,
               int16_t r, uint8_t cornername, uint16_t color) {
  int16_t f     = 1 - r;
  int16_t ddF_x = 1;
  int16_t x     = 0;
  int16_t y     = r;
  while (x<y) {
    if (f >= 0) {
      y--;
      ddF_y += 2;
      f     += ddF_y;
    x++;
    ddF_x += 2;
    f     += ddF_x;
    if (cornername & 0x4) {
    if (cornername & 0x2) {
    if (cornername & 0x8) {
    if (cornername & 0x1) {
void Adafruit_GFX::fillCircle(int16_t x0, int16_t y0, int16_t r,
               uint16_t color) {
  drawFastVLine(x0, y0-r, 2*r+1, color);
  fillCircleHelper(x0, y0, r, 3, 0, color);
// Used to do circles and roundrects
void Adafruit_GFX::fillCircleHelper(int16_t x0, int16_t y0, int16_t r,
    uint8_t cornername, int16_t delta, uint16_t color) {
  int16_t f     = 1 - r;
  int16_t ddF_x = 1;
  int16_t x     = 0;
  int16_t y     = r;
  while (x<y) {
    if (f >= 0) {
      y--;
      ddF_y += 2;
      f     += ddF_y;
    x++;
    ddF_x += 2;
    f     += ddF_x;
      drawFastVLine(x0+x, y0-y, 2*y+1+delta, color);
      drawFastVLine(x0+y, y0-x, 2*x+1+delta, color);
      drawFastVLine(x0-x, y0-y, 2*y+1+delta, color);
      drawFastVLine(x0-y, y0-x, 2*x+1+delta, color);
// Bresenham's algorithm - thx wikpedia
void Adafruit_GFX::drawLine(int16_t x0, int16_t y0,
             int16_t x1, int16_t y1,
             uint16_t color) {
  int16_t steep = abs(y1 - y0) > abs(x1 - x0);
  if (steep) {
    swap(x0, y0);
    swap(x1, y1);
  if (x0 > x1) {
    swap(x0, x1);
    swap(y0, y1);
  int16_t dx, dy;
  dx = x1 - x0;
  dy = abs(y1 - y0);
  int16_t err = dx / 2;
  int16_t ystep;
  if (y0 < y1) {
    ystep = 1;
  } else {
    ystep = -1;
  for (; x0<=x1; x0++) {
    if (steep) {
      drawPixel(y0, x0, color);
    } else {
      drawPixel(x0, y0, color);
    err -= dy;
    if (err < 0) {
      y0 += ystep;
      err += dx;
// Draw a rectangle
void Adafruit_GFX::drawRect(int16_t x, int16_t y,
             int16_t w, int16_t h,
             uint16_t color) {
  drawFastHLine(x, y, w, color);
  drawFastHLine(x, y+h-1, w, color);
  drawFastVLine(x, y, h, color);
  drawFastVLine(x+w-1, y, h, color);
void Adafruit_GFX::drawFastVLine(int16_t x, int16_t y,
             int16_t h, uint16_t color) {
  // Update in subclasses if desired!
  drawLine(x, y, x, y+h-1, color);
void Adafruit_GFX::drawFastHLine(int16_t x, int16_t y,
             int16_t w, uint16_t color) {
  drawLine(x, y, x+w-1, y, color);
void Adafruit_GFX::fillRect(int16_t x, int16_t y, int16_t w, int16_t h,
             uint16_t color) {
  for (int16_t i=x; i<x+w; i++) {
    drawFastVLine(i, y, h, color);
void Adafruit_GFX::fillScreen(uint16_t color) {
  fillRect(0, 0, _width, _height, color);
// Draw a rounded rectangle
void Adafruit_GFX::drawRoundRect(int16_t x, int16_t y, int16_t w,
  int16_t h, int16_t r, uint16_t color) {
  // smarter version
  drawFastHLine(x+r  , y    , w-2*r, color); // Top
  drawFastHLine(x+r  , y+h-1, w-2*r, color); // Bottom
  drawFastVLine(x    , y+r  , h-2*r, color); // Left
  drawFastVLine(x+w-1, y+r  , h-2*r, color); // Right
  // draw four corners
  drawCircleHelper(x+r    , y+r    , r, 1, color);
  drawCircleHelper(x+w-r-1, y+r    , r, 2, color);
  drawCircleHelper(x+w-r-1, y+h-r-1, r, 4, color);
  drawCircleHelper(x+r    , y+h-r-1, r, 8, color);
// Fill a rounded rectangle
void Adafruit_GFX::fillRoundRect(int16_t x, int16_t y, int16_t w,
  // smarter version
  fillRect(x+r, y, w-2*r, h, color);
  fillCircleHelper(x+w-r-1, y+r, r, 1, h-2*r-1, color);
  fillCircleHelper(x+r    , y+r, r, 2, h-2*r-1, color);
// Draw a triangle
void Adafruit_GFX::drawTriangle(int16_t x0, int16_t y0,
            int16_t x2, int16_t y2, uint16_t color) {
  drawLine(x0, y0, x1, y1, color);
  drawLine(x1, y1, x2, y2, color);
  drawLine(x2, y2, x0, y0, color);
// Fill a triangle
void Adafruit_GFX::fillTriangle ( int16_t x0, int16_t y0,
  int16_t a, b, y, last;
  // Sort coordinates by Y order (y2 >= y1 >= y0)
  if (y0 > y1) {
    swap(y0, y1); swap(x0, x1);
  if (y1 > y2) {
    swap(y2, y1); swap(x2, x1);
  if (y0 > y1) {
  if(y0 == y2) { // Handle awkward all-on-same-line case as its own thing
    a = b = x0;
    if(x1 < a)      a = x1;
    else if(x1 > b) b = x1;
    if(x2 < a)      a = x2;
    else if(x2 > b) b = x2;
    drawFastHLine(a, y0, b-a+1, color);
    return;
  int16_t
    dx01 = x1 - x0,
    dy01 = y1 - y0,
    dx02 = x2 - x0,
    dy02 = y2 - y0,
    dx12 = x2 - x1,
    dy12 = y2 - y1,
    sa   = 0,
    sb   = 0;
  // For upper part of triangle, find scanline crossings for segments
  // 0-1 and 0-2.  If y1=y2 (flat-bottomed triangle), the scanline y1
  // is included here (and second loop will be skipped, avoiding a /0
  // error there), otherwise scanline y1 is skipped here and handled
  // in the second loop...which also avoids a /0 error here if y0=y1
  // (flat-topped triangle).
  if(y1 == y2) last = y1;   // Include y1 scanline
  else         last = y1-1; // Skip it
  for(y=y0; y<=last; y++) {
    a   = x0 + sa / dy01;
    b   = x0 + sb / dy02;
    sa += dx01;
    sb += dx02;
    /* longhand:
    a = x0 + (x1 - x0) * (y - y0) / (y1 - y0);
    b = x0 + (x2 - x0) * (y - y0) / (y2 - y0);
    if(a > b) swap(a,b);
    drawFastHLine(a, y, b-a+1, color);
  // For lower part of triangle, find scanline crossings for segments
  // 0-2 and 1-2.  This loop is skipped if y1=y2.
  sa = dx12 * (y - y1);
  sb = dx02 * (y - y0);
  for(; y<=y2; y++) {
    a   = x1 + sa / dy12;
    b   = x0 + sb / dy02;
    sa += dx12;
    sb += dx02;
    /* longhand:
    a = x1 + (x2 - x1) * (y - y1) / (y2 - y1);
void Adafruit_GFX::drawBitmap(int16_t x, int16_t y,
               const uint8_t *bitmap, int16_t w, int16_t h,
               uint16_t color) {
  int16_t i, j, byteWidth = (w + 7) / 8;
  for(j=0; j<h; j++) {
    for(i=0; i<w; i++ ) {
      if(pgm_read_byte(bitmap + j * byteWidth + i / 8) & (128 >> (i & 7))) {
   drawPixel(x+i, y+j, color);
//#if ARDUINO >= 100
size_t Adafruit_GFX::write(uint8_t c) {
//#else
//void Adafruit_GFX::write(uint8_t c) {
//#endif
  if (c == '\n') {
    cursor_y += textsize*8;
    cursor_x  = 0;
  } else if (c == '\r') {
    // skip em
  } else {
    drawChar(cursor_x, cursor_y, c, textcolor, textbgcolor, textsize);
    cursor_x += textsize*6;
    if (wrap && (cursor_x > (_width - textsize*6))) {
      cursor_x = 0;
  return 1;
//#endif
// Draw a character
void Adafruit_GFX::drawChar(int16_t x, int16_t y, unsigned char c,
             uint16_t color, uint16_t bg, uint8_t size) {
#ifdef LOAD_GLCD
  if((x >= _width)            || // Clip right
     (y >= _height)           || // Clip bottom
     ((x + 6 * size - 1) < 0) || // Clip left
     ((y + 8 * size - 1) < 0))   // Clip top
    return;
  for (int8_t i=0; i<6; i++ ) {
    uint8_t line;
    if (i == 5)
      line = 0x0;
    else
      line = pgm_read_byte(font+(c*5)+i);
    for (int8_t j = 0; j<8; j++) {
      if (line & 0x1) {
        if (size == 1) // default size
        else {  // big size
          fillRect(x+(i*size), y+(j*size), size, size, color);
      } else if (bg != color) {
          drawPixel(x+i, y+j, bg);
        else {  // big size
          fillRect(x+i*size, y+j*size, size, size, bg);
      line >>= 1;
void Adafruit_GFX::setCursor(int16_t x, int16_t y) {
  cursor_x = x;
  cursor_y = y;
void Adafruit_GFX::setTextSize(uint8_t s) {
  textsize = (s > 0) ? s : 1;
void Adafruit_GFX::setTextColor(uint16_t c) {
  // For 'transparent' background, we'll set the bg
  // to the same as fg instead of using a flag
  textcolor = textbgcolor = c;
void Adafruit_GFX::setTextColor(uint16_t c, uint16_t b) {
  textcolor   = c;
  textbgcolor = b;
void Adafruit_GFX::setTextWrap(boolean w) {
  wrap = w;
uint8_t Adafruit_GFX::getRotation(void) {
  return rotation;
void Adafruit_GFX::setRotation(uint8_t x) {
  rotation = (x & 3);
  switch(rotation) {
   case 0:
   case 2:
    _width  = WIDTH;
    _height = HEIGHT;
    break;
   case 1:
   case 3:
    _width  = HEIGHT;
    _height = WIDTH;
    break;
// Return the size of the display (per current rotation)
int16_t Adafruit_GFX::width(void) {
  return _width;
int16_t Adafruit_GFX::height(void) {
  return _height;
void Adafruit_GFX::invertDisplay(boolean i) {
  // Do nothing, must be subclassed if supported
** Function name:           drawUnicode
** Descriptions:            draw a unicode
int16_t Adafruit_GFX::drawUnicode(uint16_t uniCode, int16_t x, int16_t y, int16_t size)
   if (size) uniCode -= 32;
   uint16_t width = 0;
   uint16_t height = 0;
   uint32_t flash_address = 0;
   int16_t gap = 0;
//   if (size == 1) {
//     flash_address = pgm_read_dword(&chrtbl_f8[uniCode]);
//     width = pgm_read_byte(widtbl_f8+uniCode);
//     height = chr_hgt_f8;
//     gap = 1;
#ifdef LOAD_FONT2
   if (size == 2) {
     flash_address = pgm_read_dword(&chrtbl_f16[uniCode]);
     width = pgm_read_byte(widtbl_f16+uniCode);
     height = chr_hgt_f16;
     gap = 1;
//   if (size == 3) {
//     flash_address = pgm_read_dword(&chrtbl_f24[uniCode]);
//     width = pgm_read_byte(widtbl_f24+uniCode);
//     height = chr_hgt_f24;
//     gap = 0;
#ifdef LOAD_FONT4
   if (size == 4) {
     flash_address = pgm_read_dword(&chrtbl_f32[uniCode]);
     width = pgm_read_byte(widtbl_f32+uniCode);
     height = chr_hgt_f32;
     gap = -3;
//   if (size == 5) {
//     flash_address = pgm_read_dword(&chrtbl_f48[uniCode]);
//     width = pgm_read_byte(widtbl_f48+uniCode);
//     height = chr_hgt_f48;
//     gap = -3;
#ifdef LOAD_FONT6
   if (size == 6) {
     flash_address = pgm_read_dword(&chrtbl_f64[uniCode]);
     width = pgm_read_byte(widtbl_f64+uniCode);
     height = chr_hgt_f64;
     gap = -3;
#ifdef LOAD_FONT7
   if (size == 7) {
     flash_address = pgm_read_dword(&chrtbl_f7s[uniCode]);
     width = pgm_read_byte(widtbl_f7s+uniCode);
     height = chr_hgt_f7s;
     gap = 2;
int16_t w = (width+7)/8;
int16_t pX      = 0;
int16_t pY      = y;
int16_t color   = 0;
byte line = 0;
//fillRect(x,pY,width+gap,height,textbgcolor);
for(int16_t i=0; i<height; i++)
  if (textcolor != textbgcolor) {
    if (textsize == 1) drawFastHLine(x, pY, width+gap, textbgcolor);
    else fillRect(x, pY, (width+gap)*textsize, textsize, textbgcolor);
  for (int16_t k = 0;k < w; k++)
    line = pgm_read_byte(flash_address+w*i+k);
    if(line) {
      if (textsize==1){
        pX = x + k*8;
        if(line & 0x80) drawPixel(pX, pY, textcolor);
        if(line & 0x40) drawPixel(pX+1, pY, textcolor);
        if(line & 0x20) drawPixel(pX+2, pY, textcolor);
        if(line & 0x10) drawPixel(pX+3, pY, textcolor);
        if(line & 0x8) drawPixel(pX+4, pY, textcolor);
        if(line & 0x4) drawPixel(pX+5, pY, textcolor);
        if(line & 0x2) drawPixel(pX+6, pY, textcolor);
        if(line & 0x1) drawPixel(pX+7, pY, textcolor);
       else {
        pX = x + k*8*textsize;
        if(line & 0x80) fillRect(pX, pY, textsize, textsize, textcolor);
        if(line & 0x40) fillRect(pX+textsize, pY, textsize, textsize, textcolor);
        if(line & 0x20) fillRect(pX+2*textsize, pY, textsize, textsize, textcolor);
        if(line & 0x10) fillRect(pX+3*textsize, pY, textsize, textsize, textcolor);
        if(line & 0x8) fillRect(pX+4*textsize, pY, textsize, textsize, textcolor);
        if(line & 0x4) fillRect(pX+5*textsize, pY, textsize, textsize, textcolor);
        if(line & 0x2) fillRect(pX+6*textsize, pY, textsize, textsize, textcolor);
        if(line & 0x1) fillRect(pX+7*textsize, pY, textsize, textsize, textcolor);
  pY+=textsize;
return (width+gap)*textsize;        // x +
** Function name:           drawNumber unsigned with size
** Descriptions:            drawNumber
int16_t Adafruit_GFX::drawNumber(long long_num,int16_t poX, int16_t poY, int16_t size)
    char tmp[10];
    if (long_num < 0) sprintf(tmp, "%li", long_num);
    else sprintf(tmp, "%lu", long_num);
    return drawString(tmp, poX, poY, size);
** Function name:           drawChar
** Descriptions:            draw char
int16_t Adafruit_GFX::drawChar(char c, int16_t x, int16_t y, int16_t size)
    return drawUnicode(c, x, y, size);
** Function name:           drawString
** Descriptions:            draw string
int16_t Adafruit_GFX::drawString(char *string, int16_t poX, int16_t poY, int16_t size)
    int16_t sumX = 0;
    while(*string)
        int16_t xPlus = drawChar(*string, poX, poY, size);
        sumX += xPlus;
        *string++;
        poX += xPlus;                            /* Move cursor right       */
    return sumX;
** Function name:           drawCentreString
** Descriptions:            draw string across centre
int16_t Adafruit_GFX::drawCentreString(char *string, int16_t dX, int16_t poY, int16_t size)
    int16_t sumX = 0;
    int16_t len = 0;
    char *pointer = string;
    char ascii;
    while(*pointer)
        ascii = *pointer;
        //if (size==0)len += 1+pgm_read_byte(widtbl_log+ascii);
        //if (size==1)len += 1+pgm_read_byte(widtbl_f8+ascii-32);
#ifdef LOAD_FONT2
        if (size==2)len += 1+pgm_read_byte(widtbl_f16+ascii-32);
        //if (size==3)len += 1+pgm_read_byte(widtbl_f48+ascii-32)/2;
#ifdef LOAD_FONT4
        if (size==4)len += pgm_read_byte(widtbl_f32+ascii-32)-3;
        //if (size==5) len += pgm_read_byte(widtbl_f48+ascii-32)-3;
#ifdef LOAD_FONT6
        if (size==6) len += pgm_read_byte(widtbl_f64+ascii-32)-3;
#ifdef LOAD_FONT7
        if (size==7) len += pgm_read_byte(widtbl_f7s+ascii-32)+2;
        *pointer++;
    len = len*textsize;
    int16_t poX = dX - len/2;
    if (poX < 0) poX = 0;
    while(*string)
        sumX += xPlus;
        *string++;
    return sumX;
** Function name:           drawRightString
** Descriptions:            draw string right justified
int16_t Adafruit_GFX::drawRightString(char *string, int16_t dX, int16_t poY, int16_t size)
    int16_t sumX = 0;
    int16_t len = 0;
    char ascii;
    while(*pointer)
        ascii = *pointer;
#ifdef LOAD_FONT2
#ifdef LOAD_FONT4
        //if (size==4)len += pgm_read_byte(widtbl_f32+ascii-32)-3;
      if (size==4)len += pgm_read_byte(widtbl_f32+ascii-32);
#ifdef LOAD_FONT6
#ifdef LOAD_FONT7
        *pointer++;
    len = len*textsize;
    int16_t poX = dX - len;
    while(*string)
        sumX += xPlus;
        *string++;
    return sumX;
** Function name:           drawFloat
** Descriptions:            drawFloat
int16_t Adafruit_GFX::drawFloat(float floatNumber, int16_t decimal, int16_t poX, int16_t poY, int16_t size)
    unsigned long temp=0;
    float decy=0.0;
    float rounding = 0.5;
    float eep = 0.000001;
    int16_t sumX    = 0;
    int16_t xPlus   = 0;
    if(floatNumber-0.0 < eep)       // floatNumber < 0
        xPlus = drawChar('-',poX, poY, size);
        floatNumber = -floatNumber;
        poX  += xPlus;
        sumX += xPlus;
    for (unsigned char i=0; i<decimal; ++i)
        rounding /= 10.0;
    floatNumber += rounding;
    temp = (long)floatNumber;
    xPlus = drawNumber(temp,poX, poY, size);
    poX  += xPlus;
    sumX += xPlus;
    if(decimal>0)
        xPlus = drawChar('.',poX, poY, size);
        sumX += xPlus;
    else
        return sumX;
    decy = floatNumber - temp;
    for(unsigned char i=0; i<decimal; i++)
        decy *= 10;                                /* for the next decimal         */
        temp = decy;                               /* get the decimal              */
        sumX += xPlus;
        decy -= temp;
    return sumX;
LEONARDOMS
Post by LEONARDOMS » Sat Jul 15, 2017 9:46 pm
SOLVED IT!!
:D
#define sclk PA5
#define mosi PA7
#define cs   PA2
#define rst  PA4
#define dc   PA3
LEONARDOMS
Post by LEONARDOMS » Sun Jul 16, 2017 5:13 pm
Hello to all. Since I´m still a NOOB for ARM architecture, I might be still doing something wrong. The display is working fine, but the refresh rate seems to be the same for the 8 bit AVR boards, it´s still very slow. Any advice? I went to the Documents\Arduino\hardware\Arduino_STM32-master\STM32F1\variants\generic_stm32f103c to check the PLL settings.
#include <boards.h>
#include <usb_serial.h>
// Allow boards to provide a PLL multiplier. This is useful for
// e.g. STM32F100 value line MCUs, which use slower multipliers.
// (We're leaving the default to RCC_PLLMUL_9 for now, since that
// works for F103 performance line MCUs, which is all that LeafLabs
// currently officially supports).
#ifndef BOARD_RCC_PLLMUL
  #if F_CPU==72000000
   #define BOARD_RCC_PLLMUL RCC_PLLMUL_9
  #elif F_CPU==48000000
   #define BOARD_RCC_PLLMUL RCC_PLLMUL_6
namespace wirish {
    namespace priv {
        static stm32f1_rcc_pll_data pll_data = {BOARD_RCC_PLLMUL};
        __weak rcc_pll_cfg w_board_pll_cfg = {RCC_PLLSRC_HSE, &pll_data};
        __weak adc_prescaler w_adc_pre = ADC_PRE_PCLK2_DIV_6;
        __weak adc_smp_rate w_adc_smp = ADC_SMPR_55_5;
        __weak void board_reset_pll(void) {
            // TODO
        __weak void board_setup_clock_prescalers(void) {
            rcc_set_prescaler(RCC_PRESCALER_AHB, RCC_AHB_SYSCLK_DIV_1);
            rcc_set_prescaler(RCC_PRESCALER_APB1, RCC_APB1_HCLK_DIV_2);
            rcc_set_prescaler(RCC_PRESCALER_APB2, RCC_APB2_HCLK_DIV_1);
         rcc_clk_disable(RCC_USB);
         #if F_CPU == 72000000
         rcc_set_prescaler(RCC_PRESCALER_USB, RCC_USB_SYSCLK_DIV_1_5);
         #elif F_CPU == 48000000
         rcc_set_prescaler(RCC_PRESCALER_USB, RCC_USB_SYSCLK_DIV_1);
        __weak void board_setup_gpio(void) {
            gpio_init_all();
        __weak void board_setup_usb(void) {
#ifdef SERIAL_USB
#ifdef GENERIC_BOOTLOADER
         //Reset the USB interface on generic boards - developed by Victor PV
         gpio_set_mode(PIN_MAP[PA12].gpio_device, PIN_MAP[PA12].gpio_bit, GPIO_OUTPUT_PP);
         gpio_write_bit(PIN_MAP[PA12].gpio_device, PIN_MAP[PA12].gpio_bit,0);
         for(volatile unsigned int i=0;i<512;i++);// Only small delay seems to be needed, and USB pins will get configured in Serial.begin
         gpio_set_mode(PIN_MAP[PA12].gpio_device, PIN_MAP[PA12].gpio_bit, GPIO_INPUT_FLOATING);
         Serial.begin();// Roger Clark. Changed SerialUSB to Serial for Arduino sketch compatibility
        __weak void series_init(void) {
            // Initialize AFIO here, too, so peripheral remaps and external
            // interrupts work out of the box.
            afio_init();
Where do I change?
Thank you.
Post by stevestrong » Mon Jul 17, 2017 8:42 am
