[STM32GENERIC/HAL] SerialUSB TX/RX speed problem
Discussions about the STM32generic core
Pito
Post by Pito » Mon Jul 17, 2017 8:15 am
This is a short sketch to demonstrate the problem, fixed by steve's patch in libmaple:
// USBSERIAL TX PROBLEM DEMONSTRATION
// Pito 7/2017
#include "Arduino.h"
  delay(3000);
#define TXCHARS 1000000
  uint32_t i;
  uint8_t x = 85;
  uint32_t elapsed = micros();
  for (i = 0; i < TXCHARS; i++) {
    Serial.write(x);
  elapsed = micros() - elapsed;
  Serial.println("***");
  Serial.print("USB TX speed = ");
  Serial.print((1000.0 * TXCHARS) / elapsed, 2);
  Serial.println(" KBytes/sec");
With F103ZE @72MHz:
Current STM32Generic:
USB TX speed = 1.00 KBytes/sec
Fixed libmaple by Steve:
USB TX speed = 213.34 KBytes/sec
It seems the current version sends 1byte per USB packet (1ms packet period).
The previous libmaple gave the same number.
As Victor has demonstrated the F103 can receive 300-500kB/sec the question is whether the TX speed cannot
be even higher than 213kB/sec..
Re: [STM32GENERIC] SerialUSB TX speed problem
Post by stevestrong » Mon Jul 17, 2017 8:31 am
Fixed libmaple:
... the question is whether the TX speed cannot be even higher than 213kB/sec..
Of course it can, but for that you should use:
Serial.write(buf,nr_bytes);
danieleff
Re: [STM32GENERIC/HAL] SerialUSB TX speed problem
Post by danieleff » Mon Jul 17, 2017 3:08 pm
A few weeks back I also added buffered USB TX, https://github.com/danieleff/STM32GENER ... 8154715833, https://github.com/danieleff/STM32GENER ... b86394c84e
Your code gives me:
USB TX speed = 308.41 KBytes/sec
Pito
Post by Pito » Wed Jul 19, 2017 11:10 am
Great! I will try, I updated my local on 24.6. so maybe I miss your patch..
BTW, I've compiled the test for Black F407 @168MHz under my old libmaple (patched manually with steve's patch) and I get 1013-1064kB/sec..
Pito
Post by Pito » Wed Jul 19, 2017 11:25 am
I've replaced the cores and the system with your latest and I get (Black F407ZE @168MHz)
USB TX speed = 64.87 KBytes/sec
Blue F013ZE @72MHz
USB TX speed = 64.45 KBytes/sec
Update: with newest libmaple from RG repo, F103ZE @72MHz
USB TX speed = 224.12 KBytes/sec
Update1: with newest libmaple from RG repo, F407 @168MHz
USB TX speed = 208.22 KBytes/sec
Pito
Post by Pito » Fri Jul 21, 2017 7:47 am
@Daniel: what compiler version do you use? Even with your vanilla repo I cannot get more than 64kB..
danieleff
Post by danieleff » Fri Jul 21, 2017 8:12 am
I think it is 6-2017-q1-update from https://developer.arm.com/open-source/g ... /downloads, newest is 6-2017-q2-update
Also CDC_SERIAL_BUFFER_SIZE is still 128 in STM32/cores/arduino/usb/cdc/usbd_cdc_if.h , upping that might help.
Pito
Post by Pito » Fri Jul 21, 2017 9:25 am
Ok, with CDC_SERIAL_BUFFER_SIZE 512 I get now with F407
DELETED
The standard compiler.
With CDC_SERIAL_BUFFER_SIZE 2048 I get with F407 730-994KB/sec.
DELETED
Update: with maybe more realistic scenario - with 1mil chars sent to TeraTerm terminal (Win7)
I get with F407ZE @168MHz
DELETED
And for F103ZE @72MHz
DELETED
Pito
Post by Pito » Sun Jul 23, 2017 12:13 pm
The bigger buffers are fast, but TX looses the data :(
While running the Tek demo against TeraTerm Tek emulator
http://www.stm32duino.com/viewtopic.php ... =20#p31835
the buffer sizes larger than 256 bytes show corruptions in the picture..
The libmaple usb works, not sure on the buffer size there.
It could be the TeraTerm is causing that as well..
Pito
Post by Pito » Sun Jul 23, 2017 6:31 pm
It seems my above results (the tables with speeds) were wrong.. :evil:
The Teraterm does not receive all 1mil chars with larger cdc buffer, but a fraction of it.
The larger the buffer in CDC the smaller amount of data I get.
Therefore the total time for TX was smaller and the TX speed was higher.
I've checked that by logging the incoming bytes into a file.
I get 1mil chars received ONLY with CDC_SERIAL_BUFFER_SIZE=128 (that is TX speed = 64kB/sec).
I've deleted the tables.
PS: with libmaple latest and its stock cdc settings I get 1mil chars with TX speed 120-170kB/sec.
Who is online
