[Libmaple] pinMode() disables timer even if no PWM mode involved
LibMaple (The core that Roger's repo uses)
RogerClark
Re: pinMode() disables timer even if no PWM mode involved
Post by RogerClark » Mon Jul 31, 2017 4:05 am
Do we have a decision on this ?
victor_pv
Post by victor_pv » Mon Jul 31, 2017 1:00 pm
edogaldo wrote:
Fri May 26, 2017 7:41 am
stevestrong wrote:edogaldo, can you please detail which things exactly get broken with this PR?
Hi Steve, I'm in doubt with this part:
        } else {  // disable channel output in non pwm-Mode
            timer_cc_disable(PIN_MAP[pin].timer_device,
                            PIN_MAP[pin].timer_channel);
A question as I'm not that expert with timers: can't we have any valid combination (also in a possible future variant) in which 2 pins can map to the same couple {timer, channel}?
Roger, I think we haven't gone past this.
Edogaldo, to answer this question, it is not possible to have 2 different pins output the same timer&channel at the same time as far as I can remember.
Post by stevestrong » Mon Jul 31, 2017 1:08 pm
I don't know any application which would get broken by this commit.
If in the future some problem arise, then we could still analyze the situation and, if necessary, revert it.
So I am in favor of this commit.
RogerClark
Post by RogerClark » Mon Jul 31, 2017 9:27 pm
I will need to check if the PR got updated, as I thought someone posted an improvement to the PR.
( but perhaps the improvement didnt work)
victor_pv
Post by victor_pv » Mon Aug 21, 2017 5:03 pm
This thread seems to be focused on the libmaple based core, so I am moving it to that forums.
RogerClark
Re: [Libmaple] pinMode() disables timer even if no PWM mode involved
Post by RogerClark » Mon Aug 21, 2017 9:10 pm
We probably need a LibMaple Core section. I will log in as super admin and create it
