Board loses program after boot
RogerClark
Re: Board loses program after boot
Post by RogerClark » Fri Jan 12, 2018 9:42 pm
Its no solved.
I gave up using the board which had the problem, I suspected it was faulty.
You could try posting to STM's own community forum as this is a general question about their processors not the Arduino core
(Or you could try compiling using something completely different e.g. Atollic TrueStudio and see if you get the same problem
Pito
Post by Pito » Sat Jan 13, 2018 12:06 am
Do we have schematics?
Provided you messed the boot0/1 wiring such you set both 1 somehow, you set the start/boot from sram, which is empty after power off/on.. :)
