analogWrite changes HardwareTimer settings
Eldi4
Post by Eldi4 »
Hello there,
I have some problem related to HardwareTimer, when i call analogWrite(PB8,x) on blue pill it somehow changes the TIM4 settings, I set the timer interrupt firing frequency of 200Hz, but when i called analogWrite(PB8,x) the interrupt fire at 1kHz, that's not what i want, does anyone know what is the problem?.
I use STM32F103C8 (Blue Pill), STM32Core, PB8 is T4C3.
by fpiSTM » Sun Jan 05, 2020 11:18 am
That is normal. Analogwrite uses the HardwareTimer and set it to get 1kHz.
To change the freq of the PWM signal use the analogWriteFrequency() before call the analogWrite
Answers: 92
Re: analogWrite changes HardwareTimer settings
Eldi4
Post by Eldi4 »
Ah i see, thank you, so i just need to analogWriteFrequency(timer.getOverflow(HERTZ_FORMAT));
Answers: 92
analogWriteFrequency(200);
Then the timer will be properly configured.
Eldi4
Post by Eldi4 »
My timer overflow value acually is variative, so it needs to adapt to it, if i explicitly call it like that, then it will unsynchronized once the overflow value changed.
Answers: 92
If you use Timer4 for another stuff, then you should not use the Arduino API analogWrite which reconfigure it.
You can check those examples to configure the PWM as desired:
https://github.com/stm32duino/STM32Exam ... dwareTimer
