[Solved] I need to return a single value from incoming serial data...
LORDHADES
Re: I need to return a single value from incoming serial data...
Post by LORDHADES »
Long live @stevestrong
I changed
#define NR_BYTES 7
to
#define NR_BYTES 10
and
 if ((m-rxTime)>50)
to
 if ((m-rxTime)>80)
I've got output like :
000.120
000.120
000.120
000.120
000.120
But the output starts printing immediately after uploading, and doesn't respond to my button press, and again, gets printed more than once.. :o :o :o
Answers: 8
Yes, because that was the version which utputs data as soon as received.
This is the version with outputs data when button pressed, and also the number of received bytes:
#define NR_BYTES 10
uint8 inBytes[NR_BYTES], inCnt, rxBytes;
uint32 rxTime;
  if (Serial2.available()>0) // serial data available?
    uint32 m = millis();
    if ((m-rxTime)>80)
      rxBytes = inCnt;
      inCnt = 0
    rxTime = m;
    if (inCnt>=NR_BYTES)
      inCnt = 0;
    inBytes[inCnt++] = Serial2.read();
  if (is_button_press==LOW && !digitalRead(buttonPin)) // button pressed?
    is_button_press = HIGH;
    digitalWrite(ledPin, LOW); // turn LED on
    Serial.print("Received bytes: "); Serial.println(rxBytes);
    for (int i=0; i<rxBytes; i++)
      Serial.write(inBytes[i]);
    delay(debounce_delay);
  if (is_button_press==HIGH && digitalRead(buttonPin)) // button released?
    is_button_press = LOW;
    digitalWrite(ledPin, HIGH); // turn LED off
LORDHADES
Post by LORDHADES »
Long Long Live Mr.@stevestrong
Thanks a lot sir... It's finally working... :D :D :D
I was working out on that issue.. But you solved the issue quickly... :)
Because of you only, I am completing my first ever Arduino-STM32 project.
Thanks a lot for being kind, gentle to this novice kid.
You're really a great great great person, Sir. Again, loads of thanks to you... :P :P :P
LORDHADES
Re: [Solved] I need to return a single value from incoming serial data...
Post by LORDHADES »
I thank all, for helping a lot in my problem, especially, Mr.@stevestrong .
Now I'm trying to write the weight data to STM32's emulated EEPROM. Before that, I was testing a test program influenced by inbuilt EEPROM example to write and read data. But while compiling, I get some error. Link to that post : "viewtopic.php?f=63&t=806"
Thanks,
Hades
Answers: 8
Please open a new post for this issue, and delete it from here.
Also, insert all your code into code tags.
LORDHADES
Post by LORDHADES »
stevestrong wrote: Sat Nov 28, 2020 1:46 pm
#define NR_BYTES 10
uint32 rxTime;
    if ((m-rxTime)>80)
      rxBytes = inCnt;
      inCnt = 0
    rxTime = m;
      inCnt = 0;
Sir, could you please integrate this code with this:
#include <RTClock.h>
#define buttonPin PA10
RTClock rtclock (RTCSEL_LSE); // initialise
int timezone = 8;      // change to your timezone
time_t tt, tt1;
tm_t mtt;
uint8_t dateread[11];
bool dispflag = true;
const char * weekdays[] = {"Mon", "Tue", "Wed", "Thu", "Fri", "Sat", "Sun"};
const char * months[] = {"Dummy", "Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec" };
uint8_t str2month(const char * d)
    uint8_t i = 13;
    while ( (--i) && strcmp(months[i], d)!=0 );
    return i;
const char * delim = " :";
char s[128]; // for sprintf
void ParseBuildTimestamp(tm_t & mt)
    // Timestamp format: "Dec  8 2017, 22:57:54"
    sprintf(s, "Time: %s, %s\n", __DATE__, __TIME__);
    //Serial.print(s);
    char * token = strtok(s, delim); // get first token
    // walk through tokens
    while( token != NULL ) {
        uint8_t m = str2month((const char*)token);
        if ( m>0 ) {
            mt.month = m;
            //Serial.print(" month: "); Serial.println(mt.month);
            token = strtok(NULL, delim); // get next token
            mt.day = atoi(token);
            //Serial.print(" day: "); Serial.println(mt.day);
            mt.year = atoi(token) - 1970;
            //Serial.print(" year: "); Serial.println(mt.year);
            mt.hour = atoi(token);
            //Serial.print(" hour: "); Serial.println(mt.hour);
            mt.minute = atoi(token);
            //Serial.print(" minute: "); Serial.println(mt.minute);
            mt.second = atoi(token);
            //Serial.print(" second: "); Serial.println(mt.second);
void SecondCount ()
  tt++;
  ParseBuildTimestamp(mtt);  // get the Unix epoch Time counted from 00:00:00 1 Jan 1970
  tt = rtclock.makeTime(mtt) + 25; // additional seconds to compensate build and upload delay
  rtclock.setTime(tt);
  tt1 = tt;
  rtclock.attachSecondsInterrupt(SecondCount);// Call SecondCount
  if ( Serial.available()>10 )
    for (uint8_t i = 0; i<11; i++)
     dateread[i] = Serial.read();
    Serial.flush();
    tt = atol((char*)dateread);
    rtclock.setTime(rtclock.TimeZone(tt, timezone)); //adjust to your local date
 if (tt1 != tt && dispflag == true && is_button_press == LOW && !digitalRead(buttonPin))
    tt1 = tt;
    rtclock.breakTime(rtclock.now(), mtt);
    sprintf(s, "Time: %s %u %u, %s, %02u:%02u:%02u\n",
    months[mtt.month], mtt.day, mtt.year+1970, weekdays[mtt.weekday], mtt.hour, mtt.minute, mtt.second);
    Serial.print(s);
To make it display weight data along with RTC date on button press.... Please sir.....
LORDHADES wrote: Thu Dec 10, 2020 1:13 pm Sir, could you please integrate this code with this:
time_t tt, tt1;
tm_t mtt;
    uint8_t i = 13;
    return i;
    //Serial.print(s);
        if ( m>0 ) {
            mt.month = m;
void SecondCount ()
  tt++;
  tt1 = tt;
    Serial.flush();
    tt1 = tt;
    Serial.print(s);
It won't work with F103 as RTC does not have calendar and it does not store time in unix format.
It only stores time when it was set and counts seconds since then.
LORDHADES
Post by LORDHADES »
Thanks for your reply man!!!
