SPI working on STM32F401, not on STM32F405
mrguen
Post by mrguen »
I am working on an application that uses SPI=SPI1 with alternate pins (MOSI=PB5, MISO not used, SCK=PB3) to communicate with a TFT screen and another SPI (SPI2) to communicate with an ADC.
I tested ok with STM32F401. I thought it would run the same on STM32F405. Unfortunately I was not able to have these SPI work.
The pins are working since I can have the TFT work when using the software SPI constructor of the TFT object. But then, the other SPI (SPI2) does not seem to work neither. The data line from the ADC seems to remain high. I haven't investigated more this other issue (it migh have another reason like the clocking of the ADC) since anyway I can't have the TFT work over SPI.
Here is the essential parts of the code concerning only SPI1 to test the TFT
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <SPI.h>
To define the pins and alternate pins for SPI1:
  #define TFT_CS PB4
  #define TFT_RST PB9
  #define TFT_DC PB8
// Redefining the SPI pin mapping to use alternate pins PB3/PB5
const PinMap PinMap_SPI_MOSI[] = {
  {PB_5,  SPI1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_SPI1)},
  {NC,    NP,    0}
const PinMap PinMap_SPI_SCLK[] = {
  {PB_3,  SPI1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_SPI1)},
  {NC,    NP,    0}
Creating the TFT object
// For 1.44" and 1.8" TFT with ST7735 use:
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
Starting SPI and initializing the TFT inside setup()
  void setup(void) {
  SPI.setSCLK(PB_3);  // Not certain it is necessary given the pins were defined above
  SPI.setMOSI(PB_5); 		// I tried both syntax PB_3 / PB_5 and  PB3 / PB5
  SPI.setClockDivider(SPI_CLOCK_DIV16); // tried DIV4, DIV8 etc
  SPI.begin();
  __HAL_RCC_I2C1_CLK_DISABLE(); // don't remember why. it was interacting with SPI1 - might be that another peripheral interacts with SPI. On STM32F405 there is CAN that uses PB5, but is not enabled by default and I tried to disable it anyway but the SPI still not working
  tft.initR(INITR_GREENTAB);      // Init ST7735S chip, black tab
  tft.fillScreen(ST77XX_BLACK);
I am using Arduino IDE 1.8.13 and tried both Arduino Core STM32 1.9.0 and 2.0.0
I suspect
1) a peripheral conflict (CAN)
2) a possible clock issue since I had to redefine the clockConfig to have the USB work. But I tried different prescalers to no avail.
by mrguen » Tue May 11, 2021 2:34 pm
I finally got it working, after adding some Serial.println lines... so I suppose "things were going too fast !!!" :evil:
Indeed the graphic test is extremely fast. Here is the full code:
#include <SPI.h>
#define TFT_CS PB_4
#define TFT_RST PB_9
#define TFT_DC PB_8
#define TFT_MOSI PB_5
#define TFT_SCLK PB_3
// Redefinition des pins pour activer SPI1 alternate pin PB3/PB5
  {TFT_MOSI,  SPI1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_SPI1)},
  {NC,    NP,    0}
  {TFT_SCLK,  SPI1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_SPI1)},
  {NC,    NP,    0}
// CLOCK CONFIG FOR STM32F405 WITH HSE 16 MHz
// ISSUE TO BE SOLVED. NOT NECESSARY FOR STM32F401
  /**Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.PLL.PLLN = 168;
    Error_Handler();
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK) {
    Error_Handler();
  /* Ensure CCM RAM clock is enabled */
  __HAL_RCC_CCMDATARAMEN_CLK_ENABLE();
void setup(void) {
  while(!Serial);
  Serial.println(F("Hello! ST7735 TFT Test"));
  // Essai utilisation SPI1 alternate
  SPI.setSCLK(TFT_SCLK);
  SPI.setMOSI(TFT_MOSI);
  SPI.begin(); // A garder voir
  Serial.println(F("After starting SPI"));
  Serial.println(F("Initialized"));
  uint16_t time = millis();
  time = millis() - time;
  Serial.println(time, DEC);
  delay(500);
  // large block of text
  testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST77XX_WHITE);
  // tft print function!
  tftPrintTest();
  delay(4000);
  // a single pixel
  tft.drawPixel(tft.width()/2, tft.height()/2, ST77XX_GREEN);
  delay(500);
  // line draw test
  testlines(ST77XX_YELLOW);
  delay(500);
  // optimized lines
  testfastlines(ST77XX_RED, ST77XX_BLUE);
  delay(500);
  testdrawrects(ST77XX_GREEN);
  delay(500);
  testfillrects(ST77XX_YELLOW, ST77XX_MAGENTA);
  delay(500);
  testfillcircles(10, ST77XX_BLUE);
  testdrawcircles(10, ST77XX_WHITE);
  delay(500);
  testroundrects();
  delay(500);
  testtriangles();
  delay(500);
  mediabuttons();
  delay(500);
  Serial.println("Setup done");
void testlines(uint16_t color) {
  for (int16_t x=0; x < tft.width(); x+=6) {
    tft.drawLine(0, 0, x, tft.height()-1, color);
    delay(0);
  for (int16_t y=0; y < tft.height(); y+=6) {
    tft.drawLine(0, 0, tft.width()-1, y, color);
    delay(0);
    tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
    delay(0);
    tft.drawLine(tft.width()-1, 0, 0, y, color);
    delay(0);
    tft.drawLine(0, tft.height()-1, x, 0, color);
    delay(0);
    tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
    delay(0);
    tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
    delay(0);
    tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
    delay(0);
void testdrawtext(char *text, uint16_t color) {
  tft.setCursor(0, 0);
  tft.setTextColor(color);
  tft.setTextWrap(true);
  tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
  for (int16_t y=0; y < tft.height(); y+=5) {
    tft.drawFastHLine(0, y, tft.width(), color1);
  for (int16_t x=0; x < tft.width(); x+=5) {
    tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
    tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
  for (int16_t x=tft.width()-1; x > 6; x-=6) {
    tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
    tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=radius; x < tft.width(); x+=radius*2) {
    for (int16_t y=radius; y < tft.height(); y+=radius*2) {
      tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=0; x < tft.width()+radius; x+=radius*2) {
    for (int16_t y=0; y < tft.height()+radius; y+=radius*2) {
      tft.drawCircle(x, y, radius, color);
void testtriangles() {
  uint16_t color = 0xF800;
  int t;
  int w = tft.width()/2;
  int x = tft.height()-1;
  int y = 0;
  int z = tft.width();
  for(t = 0 ; t <= 15; t++) {
    tft.drawTriangle(w, y, y, x, z, x, color);
    x-=4;
    y+=4;
    z-=4;
    color+=100;
void testroundrects() {
  uint16_t color = 100;
  int i;
  int t;
  for(t = 0 ; t <= 4; t+=1) {
    int x = 0;
    int y = 0;
    int w = tft.width()-2;
    int h = tft.height()-2;
    for(i = 0 ; i <= 16; i+=1) {
      tft.drawRoundRect(x, y, w, h, 5, color);
      x+=2;
      y+=3;
      w-=4;
      h-=6;
      color+=1100;
    color+=100;
void tftPrintTest() {
  tft.setTextWrap(false);
  tft.setCursor(0, 30);
  tft.setTextColor(ST77XX_RED);
  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ST77XX_YELLOW);
  tft.setTextSize(2);
  tft.setTextColor(ST77XX_GREEN);
  tft.setTextSize(3);
  tft.setTextColor(ST77XX_BLUE);
  tft.setTextSize(4);
  tft.print(1234.567);
  delay(1500);
  tft.setTextColor(ST77XX_WHITE);
  tft.setTextSize(0);
  tft.setTextSize(1);
  tft.print(8675309, HEX); // print 8,675,309 out in HEX!
  tft.println(" Print HEX!");
  tft.println(" ");
  tft.println("Sketch has been");
  tft.println("running for: ");
  tft.setTextColor(ST77XX_MAGENTA);
  tft.print(millis() / 1000);
  tft.print(" seconds.");
void mediabuttons() {
  // play
  tft.fillRoundRect(25, 10, 78, 60, 8, ST77XX_WHITE);
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_RED);
  delay(500);
  // pause
  tft.fillRoundRect(25, 90, 78, 60, 8, ST77XX_WHITE);
  tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_GREEN);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_GREEN);
  delay(500);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_BLUE);
  delay(50);
  // pause color
  tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_RED);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_RED);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_GREEN);
Re: SPI working on STM32F401, not on STM32F405
Review your clock config to see if Peripheral clock are correct.
CAN is never enabled by the core so...
__HAL_RCC_I2C1_CLK_DISABLE is not needed for your use case...
Read the errata sheet they differs btw each MCU...
mrguen
Post by mrguen »
I use an external 16 MHz crystal. 16 / 8 * 168 / 2 = 168 MHz. The mcu is working and I can have a program run the Sketch also uses Serial that is displaying on the Serial Monitor.
Here is the clock config that I use in the sketch:
    Error_Handler();
    Error_Handler();
I don't see any peripheral clock to activate to have the SPI work... As far as I know it uses the PLLCLK (168) divided by the prescaler (here /16 = 10.5 MHz should be ok)?
Interesting... If HSE is 16 MHz I assume you have redefined the HSE_VALUE ?
By default for F4 it is:
  * @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
  *        This value is used by the RCC HAL module to compute the system frequency
  *        (when HSE is used as system clock source, directly or through the PLL).
#if !defined  (HSE_VALUE)
#define HSE_VALUE              8000000U /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
For SPI speed it is fairly dependent of your device...
mrguen
Post by mrguen »
Yes, I added build_opt.h with -DHSE_VALUE=16000000
Bakisha
Answers: 5
Post by Bakisha »
When using
  {NC,    NP,    0}
why there is no
  {PB_15,     SPI2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_SPI2)},
  {PC_3,      SPI2, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_SPI2)},
Original function from PeripheralPins.c (in variant subfolder, for example Feather) is
WEAK const PinMap PinMap_SPI_MOSI[] = {
  {PA_7,      SPI1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_SPI1)},
  {PB_5_ALT1, SPI1, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF5_SPI1)},
  {PB_5,      SPI3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF6_SPI3)},
  // {PC_12,     SPI3, STM_PIN_DATA(STM_MODE_AF_PP, GPIO_PULLUP, GPIO_AF6_SPI3)},
  {NC,        NP,   0}
Also, is PinMap_SPI_MISO remaped or is it on PA6?
mrguen
Post by mrguen »
@Bakisha I did not define anything more than the needed pins. I don't think it hurts. It was working like that on the STM32F401.
mrguen
Post by mrguen »
Also I noticed that the microcontroller is not going out of the bootloader mode after downloading. I have to change BOOT0 from 1 to 0 and reset to enumerat the COM port and run the program (different from generic STM32F401RG)
mrguen
Post by mrguen »
#include <SPI.h>
#define TFT_CS PB_4
#define TFT_DC PB_8
  {NC,    NP,    0}
  {NC,    NP,    0}
    Error_Handler();
    Error_Handler();
void setup(void) {
  while(!Serial);
  delay(500);
  tftPrintTest();
  delay(4000);
  // a single pixel
  delay(500);
  // line draw test
  delay(500);
  // optimized lines
  delay(500);
  delay(500);
  delay(500);
  delay(500);
  testroundrects();
  delay(500);
  testtriangles();
  delay(500);
  mediabuttons();
  delay(500);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
    delay(0);
  tft.print(text);
  int t;
  int y = 0;
    x-=4;
    y+=4;
    z-=4;
    color+=100;
  int i;
  int t;
    int x = 0;
    int y = 0;
      x+=2;
      y+=3;
      w-=4;
      h-=6;
      color+=1100;
    color+=100;
  tft.setTextSize(1);
  tft.setTextSize(2);
  tft.setTextSize(3);
  tft.setTextSize(4);
  delay(1500);
  tft.setTextSize(0);
  tft.setTextSize(1);
  tft.println(" ");
  // play
  delay(500);
  // pause
  delay(500);
  // play color
  delay(50);
  // pause color
  // play color
mrguen wrote: Tue May 11, 2021 2:21 pm Also I noticed that the microcontroller is not going out of the bootloader mode after downloading. I have to change BOOT0 from 1 to 0 and reset to enumerat the COM port and run the program (different from generic STM32F401RG)
If USB cable is present that is normal if you kept Boot0 at 1 then you always restart in Bootloader mode when the board is reset. See
https://www.google.com/url?sa=t&rct=j&q ... PpgQX1P-ho
About the speed, as stated before the SPI speed have to be coherent with SPI slave devices.
Anyway fine you found your issue.
