Cannot compile with core 2.0.0 and Sloeber
Re: Cannot compile with core 2.0.0 and Sloeber
I think issue is relared to '(' and ')' i the path.you should try to protect it with one or two '\'.
I ran into the same problem. Has there been a solution found in the meantime ?
You should check if issue has been reported:
https://github.com/Sloeber/arduino-ecli ... gin/issues
Some issue has already been closed:
https://github.com/Sloeber/arduino-ecli ... ssues/1369
https://github.com/Sloeber/arduino-ecli ... ssues/1378
Sorry, late answer.
If it can help you, the manual workaround is in that way: add < and > around the concerned value. The action has to be done in Eclipse, under the project properties.
- Capture.JPG (37.72 KiB) Viewed 2477 times
