No timer output on pin in F4 core
Re: No timer output on pin in F4 core
thanks would try this as well
- Contact:
Can you please post your complete working code? I am still unable to make it work
void initTesttimer(void) {
Timer2.init();
Timer2.pause();
//enable preload
TIMER2->regs.gen->CR1 |= TIMER_CR1_ARPE;
timer_set_mode(TIMER2, TIMER_CH2, TIMER_PWM);
//timer_oc_set_mode(TIMER2,TIMER_CH2,TIMER_OC_MODE_PWM_1,TIMER_OC_PE);
//timer_cc_enable(TIMER2, TIMER_CH2);
Timer2.setPeriod(1000); // 1khz
Timer2.setCompare(TIMER_CH2,Timer2.getOverflow()/2);
//Timer 2 Channel 2 timer output is on PA1
//setup pin PA1 for alt function output
gpio_set_mode(PA1, GPIO_AF_OUTPUT_PP);
//gpio_set_mode(PA1, (gpio_pin_mode) (GPIO_MODE_AF | GPIO_OTYPE_PP | GPIO_OSPEED_50MHZ));
GPIOA->regs->AFR[0] |= GPIO_AFMODE_TIM1_2 << 4;
//Timer2.attachInterrupt(TIMER_CH2, timer_trig);
// start the timer
Timer2.refresh();
TIMER2->regs.gen->SR = 0; //clear interrupt flags
Timer2.resume();
i think
leaving for now
- Contact:
I managed to get it work.
Important is to set pinMode() when the timer is initialized and paused.
Your code can be more elegantly written this way:
Btw, why do you want to stick anyway to timer 2?
void Timer_init()
Timer5.init(); // this will also pause the timer
pinMode(PA1, PWM);
// Timer5.setPrescaleFactor(84); // 1µsec, optional if you use setPeriod()
Timer5.setPeriod(1000);
Timer5.setCompare(TIMER_CH2, Timer5.getOverflow()/2);
Timer5.refresh();
Timer5.resume();
thanks! would tidy up codes as i go along
well TIM2 and TIM5 are pretty much the 'same' thing, i just happened to be using TIM1 to drive the ADC sampling and TIM2 is the 1khz test signal.
just a quick question though, do we want to go about updatingstevestrong wrote: ↑Sun May 10, 2020 9:04 am The mode GPIO_AF_OUTPUT_PP for the timer is wrong, this will activate the AF mode 0 which is plain GPIO.
https://github.com/stevstrong/Arduino_S ... #L235-L253
typedef enum {
GPIO_AFMODE_SYSTEM = 0,
GPIO_AFMODE_TIM1_2 = 1,
GPIO_AFMODE_TIM3_5 = 2,
} gpio_af_mode;
typedef enum {
GPIO_AFMODE_AF0 = 0,
GPIO_AFMODE_AF1 = 1,
GPIO_AFMODE_AF2 = 2,
} gpio_af_mode;
it seemed a little 'unnecessary' but that the AFx definitions are after all different for each pin.
it could help in a sense that codes that uses them would be less affected by changes going forward rather than if those use GPIO_AFMODE_TIM1_2 etc.
e.g. if that goes into libraries / shared sketches etc, it would create a lot of dependencies if they still remain as GPIO_AFMODE_TIM1_2 etc
- Contact:
The AF definitions do not depend on the pin.
As you already checked, PA1 can be used as TIM2 as well as TIM5 output, but the AF mode of the same pin differs in these cases.
On the other hand, if you have two pins supporting the same AF, then the same AF mode shall apply for both of them. Hence you cannot say that the Af definitions are different or each pin.
So I would not change the definitions.
thanks steve! i think you are correct about it !
well as i got a little curious i did a review of the stm32f40x datasheet (this table is found immediately after the pinouts and pin description tables pages of the datasheet. incidentally, i found that stm32f103 has a different afio register map design (but for this we'd just discuss F4)
each of those gpio (e.g. PAxx) pins has slightly different AFxx AF mode assignments for the AFR register.
but in each of the AFxx 'columns' are for specific peripherals. e.g. AF1 are for TIM1 / TIM2, AF2 TIM3 / TIM4 / TIM5 .... AF4 I2C, AF5 SPI, AF7 UART ...
the main difference being the specific function of the AFIO pinout e.g.for timers it is the different channels, for SPI the different functions e.g. MOSI / MISO, / SCK, for UART TX / RX / CK / RTS / CTS and the different pheriperials.
apparently the definitions are already matching the column headings
gpio_def.h
hence there is no need to change anything, the existing definitions are appropriate.
gpio_def.h
typedef enum {
GPIO_AFMODE_TIM8_11 = 3,
GPIO_AFMODE_I2C1_3 = 4,
GPIO_AFMODE_SPI1_4 = 5,
GPIO_AFMODE_SPI3_5 = 6,
GPIO_AFMODE_USART1_3 = 7,
GPIO_AFMODE_USART4_6 = 8,
GPIO_AFMODE_CAN1_2 = 9,
GPIO_AFMODE_TIM12_14 = 9,
GPIO_AFMODE_OTG_FS = 10,
GPIO_AFMODE_ETH = 11,
GPIO_AFMODE_FSMC = 12,
GPIO_AFMODE_SDIO = 12,
GPIO_AFMODE_OTG_HS = 12,
GPIO_AFMODE_DCMI = 13,
GPIO_AFMODE_14 = 14,
GPIO_AFMODE_EVENTOUT = 15,
} gpio_af_mode;
- stm32 f40x afio map
- afio_map.png (90.46 KiB) Viewed 4938 times
- Contact:
well it is my goof, initially i read that as timer1 channel2 it isn't it is timer 1 or 2, these definitions are good
