Examples
stan
Re: Examples
Post by stan »
I have this.
list 5.png (61.4 KiB) Viewed 8799 times
I need this.
list18 25%.png (29.99 KiB) Viewed 8799 times
Answers: 92
Re: Examples
@stan
@GonzoG give you the answer:
GonzoG wrote: Mon Jan 25, 2021 2:10 am Roger's Clark core wiki:
https://github.com/rogerclarkmelbourne/ ... STM32/wiki
Install roger's core and then you will have those entries....
stan
Re: Examples
Post by stan »
I followed that link and this is what I have
master 2.png (11.28 KiB) Viewed 8794 times
stan
Re: Examples
Post by stan »
master 3.png (20.58 KiB) Viewed 8784 times
and on the end zip files ?
master 4.png (46.52 KiB) Viewed 8792 times
stan
Re: Examples
Post by stan »
When I tried add as zip library I got this error.
Specified folder/zip file does not contain valid library
Re: Examples
either git clone the repository or download the zip
then look inside the folder
Arduino_STM32/STM32F1/libraries/A_STM32_Examples/
https://github.com/rogerclarkmelbourne/ ... 2_Examples
it may not be on the graphical menu, you can view them as text files
stan
Re: Examples
Post by stan »
I followed the links and the results are as in previous post.
Screen Shot 2021-01-25 at 3.34.37 PM.png (22.96 KiB) Viewed 8781 times
This what is missed and I can't fix that.
stan
Re: Examples
Post by stan »
I have only this option
Screen Shot 2021-01-25 at 3.54.55 PM.png (5.26 KiB) Viewed 8781 times
Re: Examples
stan wrote: Mon Jan 25, 2021 8:54 pm I followed the links and the results are as in previous post.
... That is a heading ... it is not bolded, that is why you cannot select it (the red separator is a heading separator.)
Maple Mini is the 1st board selection under the STM32 Boards (Stm32duino.com) heading.
A single core can have one or many individual boards selections. The Arduino IDE parses the selections from the boards.txt file.
The IDE builds the Boards menu dynamically from installed (or /Arduino/hardware) cores. Dynamically means each time the IDE is opened by the host OS. The Menu will also refresh when new cores are installed through the Installation menu.
The Examples that get installed with the IDE may look like:
https://www.arduino.cc/en/Tutorial/BuiltInExamples
I say "may" because the IDE changes quicker than the documentation. I do not wish to be rude, but the IDE is ever-changing and there is even a pre-release people can install. Add to that even though it is JAVA based, there are numerous ways it gets installed. Bottom line, there is no absolute guarantee that anyone will get two identical installations, but generally the same features that matter will appear between recent installations on OS-X, Linux, and Windows.
stan
Re: Examples
Post by stan »
this is from old PC ( I have problem to download 100 KB picture ) and zoom in.
list18 25%.png (29.99 KiB) Viewed 8766 times
Screen Shot 2021-01-25 at 3.34.37 PM.png (22.96 KiB) Viewed 8766 times
this is on new PC
list 5.png (61.4 KiB) Viewed 8766 times
Return to “IDE's”
