2.5 inch tft display with touch
madhavan
Post by madhavan »
hi, there is many examples but nothing is working . everything is giving compiling error .
i am trying to connect in SPI Mode 2.4 inch tft with blue pill .
please suggest correction version and library or example link .
Arduino: 1.8.13 (Windows 10), Board: "Generic STM32F103C series, STM32F103C8 (20k RAM. 64k Flash), STM32duino bootloader, 72Mhz (Normal), Smallest (default)"
C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Adafruit_GFX_AS\Adafruit_GFX_AS.cpp: In member function 'int16_t Adafruit_GFX_AS::drawUnicode(uint16_t, int16_t, int16_t, int16_t)':
C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Adafruit_GFX_AS\Adafruit_GFX_AS.cpp:142:9: error: 'textsize' was not declared in this scope
     if (textsize == 1) drawFastHLine(x, pY, width+gap, textbgcolor);
C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Adafruit_GFX_AS\Adafruit_GFX_AS.cpp:149:11: error: 'textsize' was not declared in this scope
       if (textsize==1){
C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Adafruit_GFX_AS\Adafruit_GFX_AS.cpp:173:7: error: 'textsize' was not declared in this scope
   pY+=textsize;
C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Adafruit_GFX_AS\Adafruit_GFX_AS.cpp:175:20: error: 'textsize' was not declared in this scope
 return (width+gap)*textsize;        // x +
C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Adafruit_GFX_AS\Adafruit_GFX_AS.cpp: In member function 'int16_t Adafruit_GFX_AS::drawCentreString(char*, int16_t, int16_t, int16_t)':
C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Adafruit_GFX_AS\Adafruit_GFX_AS.cpp:249:15: error: 'textsize' was not declared in this scope
     len = len*textsize;
C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Adafruit_GFX_AS\Adafruit_GFX_AS.cpp: In member function 'int16_t Adafruit_GFX_AS::drawRightString(char*, int16_t, int16_t, int16_t)':
C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Adafruit_GFX_AS\Adafruit_GFX_AS.cpp:300:15: error: 'textsize' was not declared in this scope
     len = len*textsize;
Multiple libraries were found for "Wire.h"
 Used: C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\Wire
 Not used: C:\Users\ELCOT\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2021.3.18\libraries\WireSlave
exit status 1
Error compiling for board Generic STM32F103C series.
Answers: 25
Re: 2.5 inch tft display with touch
i made a fork of Adafruit ILI9341 SPI LCD library here
note this is for ILI9341 SPI LCD, you did not mention your LCD soc and its interface
viewtopic.php?f=39&t=896
Answers: 8
You better use the original Adafruit library, the Arduino_STM32 version of that is not up to date.
