this is my second topic about these 2 components. A few months back I managed to get my little project working, but I want to rebuild it and it does not seem to work anymore.
I wrote my connections down and I didn't change my code. But after a few days now of trying I can't get it to work again.
I am using a STM32F103C8T6 "Bluepill" with a ST7735s 128x60 tft display. The display has these connections: GND, VCC, SCL, SDA, RES, DC, CS and BL.
My current setup is this:
GND - GND
VCC - 5V
SCL - PA5
SDA - I wrote down PA6 but I think I ment PA7 but I tried both
RES - PA0
DC - PA1
CS - PA2
BL - N/C (sometimes on 3.3V, I dont use it)
This is the code I used:
#include <Adafruit_GFX.h>
#include <Adafruit_ST7735.h>
#include <SPI.h>
#define TFT_CS PA2
#define TFT_DC PA1
#define TFT_RST PA0
// For 1.44" and 1.8" TFT with ST7735 use:
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
float p = 3.1415926;
void setup(void) {
Serial.println("Hello!");
tft.initR(INITR_GREENTAB); //with offset
//tft.initR(INITR_BLACKTAB); //without offset
tft.fillScreen(ST77XX_BLACK);
Serial.println("Initialized");
uint16_t time = millis();
time = millis() - time;
// large block of text
testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST77XX_WHITE);
// tft print function!
tftPrintTest();
delay(4000);
// a single pixel
tft.drawPixel(tft.width() / 2, tft.height() / 2, ST77XX_GREEN);
delay(500);
// line draw test
testlines(ST77XX_YELLOW);
delay(500);
// optimized lines
testfastlines(ST77XX_RED, ST77XX_BLUE);
delay(500);
testdrawrects(ST77XX_GREEN);
delay(500);
testfillrects(ST77XX_YELLOW, ST77XX_MAGENTA);
delay(500);
testfillcircles(10, ST77XX_BLUE);
testdrawcircles(10, ST77XX_WHITE);
delay(500);
testroundrects();
delay(500);
testtriangles();
delay(500);
mediabuttons();
delay(500);
void testlines(uint16_t color) {
for (int16_t x = 0; x < tft.width(); x += 6) {
tft.drawLine(0, 0, x, tft.height() - 1, color);
delay(0);
for (int16_t y = 0; y < tft.height(); y += 6) {
tft.drawLine(0, 0, tft.width() - 1, y, color);
delay(0);
tft.drawLine(tft.width() - 1, 0, x, tft.height() - 1, color);
delay(0);
tft.drawLine(tft.width() - 1, 0, 0, y, color);
delay(0);
tft.drawLine(0, tft.height() - 1, x, 0, color);
delay(0);
tft.drawLine(0, tft.height() - 1, tft.width() - 1, y, color);
delay(0);
tft.drawLine(tft.width() - 1, tft.height() - 1, x, 0, color);
delay(0);
tft.drawLine(tft.width() - 1, tft.height() - 1, 0, y, color);
delay(0);
void testdrawtext(char *text, uint16_t color) {
tft.setCursor(0, 0);
tft.setTextColor(color);
tft.setTextWrap(true);
tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
for (int16_t y = 0; y < tft.height(); y += 5) {
tft.drawFastHLine(0, y, tft.width(), color1);
for (int16_t x = 0; x < tft.width(); x += 5) {
tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
tft.drawRect(tft.width() / 2 - x / 2, tft.height() / 2 - x / 2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
for (int16_t x = tft.width() - 1; x > 6; x -= 6) {
tft.fillRect(tft.width() / 2 - x / 2, tft.height() / 2 - x / 2 , x, x, color1);
tft.drawRect(tft.width() / 2 - x / 2, tft.height() / 2 - x / 2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
for (int16_t x = radius; x < tft.width(); x += radius * 2) {
for (int16_t y = radius; y < tft.height(); y += radius * 2) {
tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
for (int16_t x = 0; x < tft.width() + radius; x += radius * 2) {
for (int16_t y = 0; y < tft.height() + radius; y += radius * 2) {
tft.drawCircle(x, y, radius, color);
void testtriangles() {
uint16_t color = 0xF800;
int t;
int w = tft.width() / 2;
int x = tft.height() - 1;
int y = 0;
int z = tft.width();
for (t = 0 ; t <= 15; t++) {
tft.drawTriangle(w, y, y, x, z, x, color);
x -= 4;
y += 4;
z -= 4;
color += 100;
void testroundrects() {
uint16_t color = 100;
int i;
int t;
for (t = 0 ; t <= 4; t += 1) {
int x = 0;
int y = 0;
int w = tft.width() - 2;
int h = tft.height() - 2;
for (i = 0 ; i <= 16; i += 1) {
tft.drawRoundRect(x, y, w, h, 5, color);
x += 2;
y += 3;
w -= 4;
h -= 6;
color += 1100;
color += 100;
void tftPrintTest() {
tft.setTextWrap(false);
tft.setCursor(0, 30);
tft.setTextColor(ST77XX_RED);
tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(ST77XX_YELLOW);
tft.setTextSize(2);
tft.setTextColor(ST77XX_GREEN);
tft.setTextSize(3);
tft.setTextColor(ST77XX_BLUE);
tft.setTextSize(4);
tft.print(1234.567);
delay(1500);
tft.setTextColor(ST77XX_WHITE);
tft.setTextSize(0);
tft.setTextSize(1);
tft.print(p, 6);
tft.println(" Want pi?");
tft.println(" ");
tft.print(8675309, HEX); // print 8,675,309 out in HEX!
tft.println(" Print HEX!");
tft.println(" ");
tft.println("Sketch has been");
tft.println("running for: ");
tft.setTextColor(ST77XX_MAGENTA);
tft.print(millis() / 1000);
tft.print(" seconds.");
void mediabuttons() {
// play
tft.fillRoundRect(25, 10, 78, 60, 8, ST77XX_WHITE);
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_RED);
delay(500);
// pause
tft.fillRoundRect(25, 90, 78, 60, 8, ST77XX_WHITE);
tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_GREEN);
tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_GREEN);
delay(500);
// play color
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_BLUE);
delay(50);
// pause color
tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_RED);
tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_RED);
// play color
tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_GREEN);
Thanks for any help
