I am going to use 2 serial ports in my STM32F103C8 project. My development environment is Windows 10, Arduino IDE 1.8.15, Arduino_Core_STM32 2.0.0
My testing code is:
Serial1.begin(115200);
Serial2.begin(115200);
build_opt.h
-DENABLE_HWSERIAL2
I got compilation error with Arduino IDE 1.8.15 as follows:
arm-none-eabi-g++: error: #line: No such file or directory
arm-none-eabi-g++: error: 1: No such file or directory
exit status 1
Error compiling for board Generic STM32F1 series.
However when I use Arduino IDE 1.8.5 (older version) to compile the same code, the result is successful.
When I check the compilation process of Arduino IDE 1.8.15, I found the build_opt.h in build folder have a additional line at the beginning like this.
#line 1 "C:\\Users\\xxxxx\\Documents\\Arduino\\stm32-sample-codes\\hwserial-test\\build_opt.h"
-DENABLE_HWSERIAL2
Even though I manually modify the build_opt.h in build folder. I still can't build the sketch as the compiler cannot find SrcWrapper.h.
C:\\Temp\\arduino_build_300941\\sketch\\SrcWrapper.cpp:1:10: fatal error: SrcWrapper.h: No such file or directory
1 | #include <SrcWrapper.h>
compilation terminated.
Does anybody have the same problem and is there any way to resolve it?
Compile error using Arduino IDE 1.8.15 with build_opt.h
Re: Compile error using Arduino IDE 1.8.15 with build_opt.h
Hi @jasonhk
This is a know issue linked to Arduino cli which now preprocess ".h" file.
I've made a fix to bypass this issue:
https://github.com/stm32duino/Arduino_C ... /pull/1442
Arduino cli issue discussed here:
https://github.com/arduino/arduino-cli/issues/1338
Thanks, I try this later
i am uploading the sketch via FTDI - Serial ( UART1 ) it's working attached sketch
then i try to connect Serial 1 (UART2) ""NO"" output . - but no compile error
then i try to connect Serial 2 ( UART3) but following compiling error.
Arduino: 1.8.15 (Linux), Board: "Generic STM32F1 series, BluePill F103CB (or C8 with 128k), STM32CubeProgrammer (Serial), Enabled (generic 'Serial'), None, Low/Full Speed, Smallest (-Os default), Newlib Nano (default)"
/home/madhavan/.arduino15/packages/STMicroelectronics/tools/xpack-arm-none-eabi-gcc/9.3.1-1.3/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: sketch/rs232_two_arduino.ino.cpp.o: in function `setup':
rs232_two_arduino.ino.cpp:(.text.setup+0xc): undefined reference to `Serial2'
/home/madhavan/.arduino15/packages/STMicroelectronics/tools/xpack-arm-none-eabi-gcc/9.3.1-1.3/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: sketch/rs232_two_arduino.ino.cpp.o: in function `loop':
rs232_two_arduino.ino.cpp:(.text.loop+0x1c): undefined reference to `Serial2'
collect2: error: ld returned 1 exit status
exit status 1
i have followed steps from https://github.com/arduino/arduino-cli/issues/1338
Add a build_opt.h file containing the line -DHAL_CRC_MODULE_ENABLED to an example folder next to the blink ino.
exit status 1
exit status 1
Serial2.begin(9600);
Serial2.println("ok");
exit status 1
You have to instantiate Serial2. See the wiki
thank so much for information.... now it's working ..after many research
