Serial comunication beetwen Arduino and STM32 F401RE with Arduino ide
andreealombardo
Post by andreealombardo »
How can I pass through the serial ports an arduino number to the STM32 F401RE? Using the Arduino IDE? For now I have done this:
(i should do all this using just the arduino ide)
Code Arduino (TX)
int valueTX=5;
Serial.print(valueTX);
Code STM32 F401RE (RX)
int valueRX;
if(Serial.available()){
valueRX=Serial.read();
Serial.print(valueRX);
But the STM32 F401RE does not print 5, but -1, I do not understand why
Answers: 25
Re: Serial comunication beetwen Arduino and STM32 F401RE with Arduino ide
you'd need to explain what board you are using and which core you are using
viewtopic.php?f=2&t=3
viewtopic.php?f=2&t=301
andreealombardo
I'm using STM32F401RE, with core Arm Cortex-M4
Answers: 25
There are a few ways to move forward, you can present the schematics of the board (or a link). Nobody knows what is on your board to guess what is the problem. In addition you need to state the core you are using and if you are using usb (CDC) serial.
or you can choose your board from the list
note that install instructions for the stm32duino core is found here
ozcar
Answers: 5
Post by ozcar »
How have you wired things up? You seem to expect the Serial.read() on the F401 to read what came from the Arduino, but that Serial.print on the F401 will print the result so that you can see what was received.
Besides that, the Serial.print(valueTX) on the Arduino will convert valueTX to a character string, but the Serial.read() on the F401 will not convert back to int. Edit: at least I don't think so - I seem to remember having to use Serial.parseInt() to do that, but that was not using Stm32duino.
