Sleep Mode
Posted: Tue Sep 27, 2022 12:28 am
by hyur
Board : Stm32f103c8t6 (Roger's Core)
I want to use sleep mode on the board.
So I tried to use the STM32duino LOW POWER library,
Because it is Roger's Core, stm32_def.h compilation error occurs.
How does Roger's Core use sleep mode?
Can you provide a relevant register datasheet or example code?
Re: Sleep Mode
Posted: Tue Mar 07, 2023 5:25 pm
by Ouroboros
I'm trying to implement standby and stop modes on this core for STM32F103 mcu. I had no isues with standby mode, it works properly with power consumption about of 48 uA. Same power is consumed when using STM32LowPower with official core. Here it's my source:
void lp_init()
//enable power clock
RCC_BASE->APB1ENR |= RCC_APB1ENR_PWREN;
delay(10);
/* Enable access to RTC and backup registers */
PWR_BASE->CR |= PWR_CR_DBP;
/* Check if the system was resumed from StandBy mode */
if (PWR_BASE->CSR & SCB_SCR_SLEEPONEXIT) {
/* Clear Standby flag */
PWR_BASE->CR |= PWR_CR_CSBF;
//Clear wakeup flag
PWR_BASE->CR |= PWR_CR_CWUF;
void standby()
lp_init();
nvic_globalirq_disable();
SCB_BASE->SCR |= SCB_SCR_SLEEPDEEP;
//Power down deepsleep
PWR_BASE->CR |= PWR_CR_PDDS;
//Enable wakeup pin
PWR_BASE->CSR |= PWR_CSR_EWUP;
__asm volatile("WFI":::"memory");
There are some difficuelties with stop mode. It consumes about 79uA instead of 54uA using original core. Something keeps consuming 25uA. Here the sources of my implementation:
void stop()
for (int i = 0; i < BOARD_NR_GPIO_PINS; i++)
pinMode(i, INPUT);
digitalWrite(i, 0);
Serial.end();
adc_disable_all();
lp_init();
PWR_BASE->CR &= ~PWR_CR_PDDS;
//Low-power deepsleep
PWR_BASE->CR |= PWR_CR_LPDS;
SCB_BASE->SCR &= ~SCB_SCR_SLEEPDEEP;
//post wakeup setup
setup_clocks();
nvic_init((uint32)VECT_TAB_ADDR, 0); //setup_nvic();
systick_init(SYSTICK_RELOAD_VAL);
adc_set_prescaler(wirish::priv::w_adc_pre); adc_foreach(adc_default_config); //setup_adcs();
timer_foreach(timer_default_config); //setup_timers();
nvic_globalirq_enable();
