STM32F301K8U6-HardwareTimer interrupt does not work
Posted: Sat Feb 18, 2023 9:23 pm
by AkPat
Hello All,
I need your support in solving the following issue:
For my project I use the STM32F301K8U6 chip. In the application I need 0,1s timing, therefore I decided to use the HardwareTimer library.
To check the HW, I uploaded the simplest provided HarwareTimer example, that blinks an LED on pin PA3:
#if !defined(STM32_CORE_VERSION) || (STM32_CORE_VERSION  < 0x01090000)
#error "Due to API change, this sketch is compatible with STM32_CORE_VERSION  >= 0x01090000"
#if defined(LED_BUILTIN)
#define pin  LED_BUILTIN
#else
#define pin  PA3
void Update_IT_callback(void)
{ // Toggle pin. 10hz toogle --> 5Hz PWM
  digitalWrite(pin, !digitalRead(pin));
#if defined(TIM1)
  TIM_TypeDef *Instance = TIM1;
#else
  TIM_TypeDef *Instance = TIM2;
  // Instantiate HardwareTimer object. Thanks to 'new' instanciation, HardwareTimer is not destructed when setup() function is finished.
  // configure pin in output mode
  pinMode(pin, OUTPUT);
  MyTim->setOverflow(10, HERTZ_FORMAT); // 10 Hz
  MyTim->attachInterrupt(Update_IT_callback);
  MyTim->resume();
  /* Nothing to do all is done by hardware. Even no interrupt required. */
The LED does not blink. I have checked the LED by uploading the "Blink" sketch and it is working as it should.
Anybody has an idea what can be the reason for it?
Any hint on what I should check?
Thanks in advance.
Re: STM32F301K8U6-HardwareTimer interrupt does not work
Posted: Sun Feb 19, 2023 9:47 am
by GonzoG
I this example, if your board has LED_BUILTIN defined for a different pin than PA3, it won't work for PA3.
Posted: Sun Feb 19, 2023 10:33 am
by AkPat
Thanks for Your hint.
I totally overlooked it :shock:
I 've corrected it and it is working now. :)
