Learning of lorawan communication between gateway and sender
HelloWorld
Post by HelloWorld »
Hi all,I am currently using f411re connected with I-nucleo-lorawan1 to communicate with f746zg connected with lora hf band gateway expansion board. I have tried the example in aruino ide but it lora isn't starting in i-nucleo-lorawan1,may I ask if there is anyone doing the same attempt as I'm trying to do right now?
Answers: 92
Re: Learning of lorawan communication between gateway and sender
Pay attention to serial pins. See the readme you may need to change som soldier bridges
