STM32LowPower - Serial keeps STM32L452RE awake (undesired)
What are you developing?
brixton
Post by brixton »
Hello all,
I got my hands on a STML452RE nucleo board. I managed to write and run a program that demonstrates using timed-based sleep and external-interrupt-based sleep in the same program. It works fine and I've very happy with that. See script below.
However, it only works if Serial/hardwareSerial is not used in the program. As soon as I introduce those into the code (i.e. by uncommenting the sections of code below), the external-interrupt-based sleep is skipped and the MCU proceeds straight to the next piece of code, which is the time-based sleep.
Does anyone know what could be causing the issue here?
#include "STM32LowPower.h"
#ifndef USER_BTN
#define USER_BTN pinNametoDigitalPin(SYS_WKUP1)
const int pin = USER_BTN;
// HardwareSerial Serial1(PA10, PA9);
  pinMode(LED_BUILTIN, OUTPUT);
  // Serial1.begin(115200);
  // Serial1.println("A");
  LowPower.begin();
  LowPower.deepSleep(1000);
  // Serial1.println("B");
  LowPower.deepSleep(5*1000);
  // Serial1.println("C");
  // Serial1.println("D");
  pinMode(pin, INPUT_PULLUP);
  LowPower.begin();
  LowPower.attachInterruptWakeup(pin, emptyISR, RISING, SLEEP_MODE);
  LowPower.deepSleep();
  // Serial1.println("E");
void emptyISR() {
  // This function will be called once on device wakeup
Answers: 92
Re: STM32LowPower - Serial keeps STM32L452RE awake (undesired)
Serial uses IT, try to add Serial1.flush(); before entering in LP.
brixton
Post by brixton »
Hi fpiSTM,
Thanks that resolved the issue!
Funnily enough, when I disable Serial1.flush() the problem does not seem to reappear. Strange..
Best,
Return to “Projects”
