Making use of STM32F407VET6's Truly Random Number Generator in Arduino IDE
_Northstrix_
Post by _Northstrix_ »
Hello, Everyone.
Is there a way to make use of the STM32F407VET6's truly random number generator in the Arduino IDE?
Re: Making use of STM32F407VET6's Truly Random Number Generator in Arduino IDE
those peripherals are often fairly simple. Here is what I used for a STM32G030 (programmed as a G031): https://dannyelectronics.wordpress.com/ ... stm32g041/
the rng piece is here:
//true rng
//initialize the rng
void rngInit(void) {
	RCC->AHBENR |= RCC_AHBENR_RNGEN;	//ENABLE rng
	//configure the clock
	RCC->CCIPR = (RCC->CCIPR &~RCC_CCIPR_RNGSEL) | (1<<RCC_CCIPR_RNGSEL_Pos); //select the clock. 0->no clock, 1->HSI16, 2->sysclk, 3->pllclk
	RCC->CCIPR = (RCC->CCIPR &~RCC_CCIPR_RNGDIV) | (0<<RCC_CCIPR_RNGDIV_Pos); //set the divider. 0->1:1, 1->2:1, 2->4:1, 3->8:1
	RNG->CR = 0;						//default value
	RNG->SR = 0;						//default value
	RNG->CR|= RNG_CR_RNGEN;				//ENABLE rng
you will need to check for the data ready flag beore reading the rng.
yours must be roughly the same.
_Northstrix_
Thank you for your response.
But I guess these boards use different registers or something, so it won't even initialize.
And since I don't really understand how to work stuff like that, I guess, I'll just have to use the Arduino RNG again.
have you reviewed RM0009?
those are necessary references
_Northstrix_
Ok, thank you.
That document gave me a very vague understanding of how the RNG works (in theory).
But still, I don't know what to do with it in practice.
Answers: 92
You can also use HAL directly:
First HAL RNG have to be enabled, to do this, simply add a file named "hal_conf_extra.h" and add this:
#define HAL_RNG_MODULE_ENABLED
Then the code:
RNG_HandleTypeDef hrng;
* @brief RNG MSP Initialization
* This function configures the hardware resources used in this example
* @param hrng: RNG handle pointer
* @retval None
extern "C" void HAL_RNG_MspInit(RNG_HandleTypeDef* hrng) {
  /* Peripheral clock enable */
  __HAL_RCC_RNG_CLK_ENABLE();
* @brief RNG MSP De-Initialization
* This function freeze the hardware resources used in this example
* @retval None
extern "C" void HAL_RNG_MspDeInit(RNG_HandleTypeDef* hrng) {
  if (hrng->Instance == RNG) {
    /* Peripheral clock disable */
    __HAL_RCC_RNG_CLK_DISABLE();
    /* Enable RNG reset state */
    __HAL_RCC_RNG_FORCE_RESET();
    /* Release RNG from reset state */
    __HAL_RCC_RNG_RELEASE_RESET();
  hrng.Instance = RNG;
  if (HAL_RNG_Init(&hrng) != HAL_OK) {
    Error_Handler();
  uint32_t aRandom32bit;
  if (HAL_RNG_GenerateRandomNumber(&hrng, &aRandom32bit) != HAL_OK) {
    /* Random number generation error */
    Error_Handler();
  } else {
    Serial.println(aRandom32bit);
the code I gave was for the G0 series. For your chip, you will have to read the datasheet / reference manul and the header file to see which bits will need to be set / reset for this to work. But the general approach is the same.
_Northstrix_
fpiSTM wrote: Mon Sep 04, 2023 1:24 pm You can also use HAL directly:
Then the code:
* @retval None
* @retval None
    Error_Handler();
    Error_Handler();
  } else {
Thank you so much for that code. I have an issue with it though. It doesn't compile. And I don't know what to do with it.
I literally have zero experience with HAL. I only programmed the STM32 in Arduino IDE as if it was an Arduino.
Please, tell me what I'm doing wrong.
Answers: 92
Read carefully my post.
This means you have to create file with arduino ide
