[libmaple] SDIO
[libmaple] SDIO
Post by stevestrong » Sun Jun 18, 2017 5:20 pm
Hi all,
I finally managed to bring the SDIO files in an acceptable form to be published.
It works with 24MHz clock and 4bits wide bus, and tested only for the generic F407VET6 board.
I have committed 2 files to libmaple core directory, and 2 files to a new SDIO lib under STM32F4/libraries.
Usage:
- get the master branch from my repo
- get the SdFat lib from https://github.com/greiman/SdFat
- insert into line 164 of SdFatConfig:
#elif defined(__STM32F4__)
#define ENABLE_SDIO_CLASS 1
- use in example sketches
#include "SdioF4.h" // instead of #include "SdFat"
- insert in your sketch the function
void yield() {}
- do not use the "SdFatSdioEX" class, it will destroy the Fat structure on your card.
Note:
This is due to the EX class way of working, and NOT because the SDIO driver writes wrong data.
I have tested intensively, and the reads were always identical with the writes.
Current benchmarks:
- using bench.ino -- buffer size 512 bytes
write speed and latency
speed,max,min,avg
KB/Sec,usec,usec,usec
439.69,18756,870,1163
433.55,117741,865,1180
read speed and latency
speed,max,min,avg
2353.90,1252,211,216
2353.90,440,211,216
These is actually the best ever result, the read speed for 512 byte buffer is average 2.1MB, varying +/-10%, the write speed is only varying ~3%.
- using STM32F4SdioDemo.ino (see attached binary and INO files): (DO NOT USE the SdFatSdioEX" class!!!) - this has the "yield()" function already included.
size,write,read
bytes,KB/sec,KB/sec
512,432.94,2069.58
1024,710.33,2451.21
2048,1510.87,4270.57
4096,3418.99,5956.09
8192,5170.13,8611.31
16384,6654.81,9750.35
32768,8493.92,10667.59
totalMicros  56530544
yieldMicros  37059984
yieldCalls   51335
yieldMaxUsec 87835
kHzSdClk     24000
Done
Disclaimer:
- Use it on you own risk!
Although I tested as much as I could, and all examples worked, I cannot exclude that bugs are still in the software, so don't blame me if data gets lost from the card.
Just post here if you encounter any problem, or make a PR on github if you find a bug.
STM32SdioDemo.ino
(8.45 KiB) Downloaded 41 times
STM32SdioDemo.ino.bin.txt
(41.19 KiB) Downloaded 17 times
Last edited by stevestrong on Wed Jul 05, 2017 10:58 pm, edited 23 times in total.
Re: [libmaple] SDIO
Post by RogerClark » Sun Jun 18, 2017 9:31 pm
When I have enough time, I will pull you F4 changes
acronis
Re: [libmaple] SDIO
Post by acronis » Mon Jun 19, 2017 8:24 am
Hello. Will this work on version 1.8.2 or 1.8.3 ?
Re: [libmaple] SDIO
Post by stevestrong » Mon Jun 19, 2017 8:26 am
I tested it with 1.6.12 - I kept this version based on "never change a running system"- but I assume it should work with the latest versions as well.
If not, please post here any problems.
acronis
Re: [libmaple] SDIO
Post by acronis » Mon Jun 19, 2017 8:29 am
OK.
Thank YOU very much for YOUR work !
Re: [libmaple] SDIO
Post by stevestrong » Mon Jun 19, 2017 9:13 am
I have to first merge the latest commits from your master to my branch, I hope I manage it today in the evening.
I'll let you know.
Re: [libmaple] SDIO
Post by RogerClark » Mon Jun 19, 2017 10:37 am
I'll let you know.
OK
I think it may be OK without doing this.
But don't rush, I have so many other things I need to do.
Re: [libmaple] SDIO
Post by stevestrong » Mon Jun 19, 2017 5:50 pm
I have tested the reading/writing/CRC calculating sketch from Daniel (test file of 102.4MB), and this is the result:
Use a freshly formatted SD for best performance.
Type any character to start
Opening the read file..
Opening the write file..
Reading and Writing..
Done in 24063 msecs
Running CRC calculations...
File in CRC:  22BCDBEC
File out CRC: 22BCDBEC
Done in 70620 msecs
Done in 34167 msecs
Done in 70937 msecs
Done in 37755 msecs
Done in 70910 msecs
Done in 36741 msecs
Done in 70734 msecs
It is interesting to see that the first run (after reset) the reading/writing is always much less (30%!) than the following read/writes.
When I activated the debug output I saw that the first run involves much less block reads than the following ones, which are again all comparable.
There was no block number difference on CRC calculation.
Does anyone else experienced the same issue?
I think it has something to do with the SdFat lib, because the files system is the same after 5 runs than at the very first run. The difference is only the software reset.
Also interesting to see that, compared to the result for GENERIC core, the read/write takes here much less time (~37secs vs. 47secs), but CRC calculation lasts in average ~3 seconds more. Is that due to the different compiler versions?
danieleff
Re: [libmaple] SDIO
Post by danieleff » Wed Jun 21, 2017 5:03 am
100MB F407
I get with my:
Done in 61039 msecs
File in CRC:  DE9D6BE7
File out CRC: DE9D6BE7
Done in 71259 msecsType any character to start
Done in 60230 msecs
Done in 71251 msecsType any character to start
your:
Done in 34231 msecs
Done in 71164 msecsType any character to start
Done in 58237 msecs
Done in 71207 msecsType any character to start
All in all it seems to work pretty stable.
BTW I always get slower speeds than you all, even if the microSD has ⑩ written on it.
Re: [libmaple] SDIO
Post by stevestrong » Wed Jun 21, 2017 6:49 am
OK, so you could reproduce my issue.
For libmaple core, the first read and write takes a lot less time (34231 msecs) than the following read writes (58237 msecs).
Your core seems not to show this issue.
Hmmm.
