Greetings from Germany!
(Darmstadt, a little bit south from Frankfurt am Main)
I learned C language by myself 20 ... 30 years ago. With some of that object-oriented stuff in C++ I'm at war. Old dogs don't learn new tricks. After some first learning with ArduinoIDE I'm programming smaler projects with ESP32 or SAMD21.
Idea 1: A hardware watchdog with STM32C011F6P6. Some weeks ago I had trouble with a temperature logger (5x DS18B20, RTC and display), where I2C-bus and/or the board hanged up. In the end display caused the problem. Because the board should log each 3 minutes, a independent watchdog may be nice for similar situations - boards with STM32C011F6P6 are cheaper than ATtinys.
Idea 2: A logger for temperature, humidity and air pressure, when I'm on a hiking tour. At the moment I would realize it with a SAMD21. Otherwise a STM32Lxxx or the new STM32U031/73/83 sounds interesting ...
Idea 3: A large display (10 to 13 inch) for weather information or about photovoltaic device etc. I know how to connect ESP32/ESP32-S3 via SPI or 8bit parallel. But 7 inch are the largest displays with such interfaces. Otherwise HDMI for Raspberry Pi or a system like Nextion, Stone etc. So may be some larger STM32 can operate a RGB-display?
I'm using ArduinoIDE 2.3.2. After some troubles with Teensy 4.1 I decided to use a portable installation for STM32-boards. Waiting for the STM32C011F6P6-boards I wanted to program a "BlackPill" from WeAct. Like a lot of users I had problems with long pathes, then STM32CubeProgrammer wasn't found. No success via USB. In the end It works with a FTDI-adapter and A9/A10 pins.
Bye, Jürgen
finally account is active ...
Jump to
- Announcements
- New users start here
- ↳ Forum rules, FAQs and HowTo's
- ↳ Let us know a bit about you and your projects
- Arduino for STM32
- ↳ General discussion
- ↳ Ideas & suggestions
- ↳ Cores
- ↳ STM32 Core
- ↳ Builds and Announcements
- ↳ Code snippets
- ↳ Installation and OS related
- ↳ Libraries & Hardware
- ↳ PR's bugs and enhancements
- ↳ LibMaple
- ↳ Code snippets
- ↳ Steve's LibMaple core
- ↳ Projects
- ↳ IDE's
- ↳ Off topic
- Arduino for STM8
- ↳ Cores
- ↳ STM8 Core
- ↳ Other
- Boards
- ↳ Custom design boards
- ↳ Maple & Maple mini etc
- ↳ STM boards (Discovery, Eval, Nucleo, ...)
- ↳ All other boards
- ↳ STM32F0 based boards
- ↳ STM32F1 based boards
- ↳ STM32F2 based boards
- ↳ STM32F3 based boards
- ↳ STM32F4 based boards
- ↳ STM32F7 based boards
- ↳ STM32G0 based boards
- ↳ STM32G4 based boards
- ↳ STM32H7 based boards
- ↳ STM32L0 based boards
- ↳ STM32L1 based boards
- ↳ STM32L4 based boards
- ↳ STM32L5 based boards
- ↳ STM32MP1 based boards
- ↳ STM32WB based boards
- Bootloaders
- ↳ STM32 HID bootloader
- ↳ USB bootloader
- ↳ STM32 SD-Bootloader
- ↳ STM32 USB CDC bootloader
- Uploaders and debuggers
- ↳ STLink
- ↳ USB to Serial adaptors
- ↳ Black Magic Probe & other
- Dead Thread Graveyard
- ↳ Dead Thread Graveyard
