STM32F103 Register ID Memory Size?
ChrisMicro
Post by ChrisMicro » Sun Aug 20, 2017 7:35 am
In the data sheet there is a ID-Register ( Chapter 30 )
You can get the Flash-Size and some unique ID.
Would it be possible to derive somehow the MCU type out of the unique ID?
Re: STM32F103 Register ID Memory Size?
Post by fpiSTM » Sun Aug 20, 2017 8:00 am
Maybe you should better use the
31.6.1 MCU device ID code
But you will not know exactly which MCU, ex if it is a Low density this will be one of STM32F101xx, STM32F102xx and STM32F103xx:
Low-density devices are STM32F101xx, STM32F102xx and STM32F103xx microcontrollers where the Flash memory density ranges between 16 and 32 kbytes.
Medium-density devices are STM32F101xx, STM32F102xx and STM32F103xx microcontrollers where the Flash memory density ranges between 64 and 128 Kbytes.
High-density devices are STM32F101xx and STM32F103xx microcontrollers where the Flash memory density ranges between 256 and 512 Kbytes.
XL-density devices are STM32F101xx and STM32F103xx microcontrollers where the Flash memory density ranges between 768 Kbytes and 1 Mbyte.
Connectivity line devices are STM32F105xx and STM32F107xx microcontrollers.
Maybe by combining Flash and revision information it is possible to be more precise.
Post by RogerClark » Sun Aug 20, 2017 10:43 am
Often on the F1 series, the actual size of flash is not the same as would be indicated by using the device ID
The F103C8 often has 128kb flash instead of the guaranteed size of 64kb
