LiquidCrystal library
Phono
Post by Phono » Fri Sep 29, 2017 3:41 pm
I am in the process of migrating from the Maple IDE to the Arduino for STM32 IDE, and I had a problem with this library.
I am using a 3.3V, 2 x 16 character LCD module.
It worked with the Maple library, but would only display garbage in the Arduino environment.
I compared my source files, new version against current one, but no difference could explain it.
Then I compared the LiquidCrystal library of Arduino for STM32 against that from Maple, and again, no other difference than those required to run in the new environment.
Then I tried to tweak the value of the many delay() calls, and I found this:
In the following function :
void LiquidCrystal::pulseEnable(void) {
  // _enable_pin should already be LOW (unless someone else messed
  // with it), so don't sit around waiting for long.
  digitalWrite(_enable_pin, LOW);
  delayMicroseconds(1);
  // Enable pulse must be > 450 ns.  Value chosen here according to
  // the following threads:
  // http://forums.leaflabs.com/topic.php?id=640
  // http://forums.leaflabs.com/topic.php?id=512
  gpio_toggle_bit(PIN_MAP[_enable_pin].gpio_device, PIN_MAP[_enable_pin].gpio_bit);// togglePin(_enable_pin);
  delayMicroseconds(2);
  // Commands needs > 37us to settle.
  delayMicroseconds(42);
I increased the last delay and I found that 48 µs were the minimum value to have my LCD module work properly.
So I set it to 50.
Since 42 is the value used in the Maple library, can we conclude that the function delayMicroseconds() does not give the same duration in the two environments?
May I suggest that this delay be increased to 50 in the public library?
No doubt that I found a LCD controller chip that was a bit lazy, but for sure this increase is required, and does little harm to the application that uses it.
Re: LiquidCrystal library
Post by RogerClark » Fri Sep 29, 2017 8:47 pm
delays like that seem suspicious to me..
I agree the library should be updated to a value that works...
Phono
Post by Phono » Sun Oct 01, 2017 9:08 pm
It is very likely that the delayMicroseconds() function gives with the STM32 for arduino shorter delays than in the Maple library. Supposing they were correct in the Maple library, could we correct the timings in the STM32 for arduino?
Post by fpiSTM » Sun Oct 01, 2017 9:39 pm
Post by Pito » Mon Oct 02, 2017 6:16 am
You may measure the real delay's duration with high precision:
viewtopic.php?f=18&t=2004&p=26692&hilit=pito+dwt#p26692
