libmaple makefiles
Posted: Sun Dec 22, 2019 4:45 pm
this is probably for the linux users. but these days
one can do just this as well while working in windows
https://docs.microsoft.com/en-us/window ... tall-win10
i've been using this makefile for various sketches. I've been working in eclipse (rather than Arduino IDE) and transporting the defines and dependencies is tedious. Though in the more recent releases, you can export those configs and import them into new projects.
With the makefile, all the defines and dependencies are captured in the makefile. Hence, it makes the task significantly easier.
This makefile is written for libmaple core and specifically STM32F1 core.
# the directory structure needs to be
# Root
# +-- src (your sources e.g. the sketch
# | the files has to be cpp, c or h, no ino)
# +-- STM32F1 (copy from the libmaple core)
# +-- Makefile (this makefile)
place your sources in src.
for libraries yon can copy that libraries into src or define them as additional src_dirX paths.
edit the other things such as the defines and include paths (add those for the libraries you use as needed) for each project
when done it is mostly just running
make
the build output goes into $(out_dir) - currently defined as bin.
note that make clean deletes the the out dir.
https://gist.github.com/ag88/a6a02acbc7 ... 7c0f310268
# Root
make
# version 0 (alpha)
# This make file for libmaple core is possibly *dangerous*
# i.e. it compiles the sources (in src and STM32F1) directory
# and overwrite all the stuff in $(out_dir)
# $(out_dir) is the binary directory where the object files are dumped there
# make clean *deletes* the *$(out_dir)* (coded here as bin )
# this is a relative path makefile
# Root
# the make needs to be run from the root of this file structure
# the make is relative path from this Root
# generated object files and binaries (elf, bin) are placed into the
# $(out_dir) - bin
# make clean - *deletes* $(out_dir)
# make all - starts the build
# Lic: public domain.
# Anyone is free to copy, modify, publish, use, compile, sell, or
# distribute this software, either in source code form or as a compiled
# binary, for any purpose, commercial or non-commercial, and by any
# means.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
# EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
# MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
# IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR
# OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
# ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
# OTHER DEALINGS IN THE SOFTWARE.
# this folder is deleted with make clean
out_dir := bin
# this is the name of the subdirectory under STM32F1/variants
# it needs to match, this caters to a single variant
variant := maple_mini
# these are the defines passed to gcc, g++ and the assembler
# use += to add more definitions
defines := MCU_STM32F103CB
defines += __STM32F1__
defines += VECT_TAB_ADDR=0x8002000
defines += CONFIG_MAPLE_MINI_NO_DISABLE_DEBUG
defines += DEBUG_LEVEL=DEBUG_NONE
defines += F_CPU=72000000L
defines += SERIAL_USB
defines += USB_VID=0x1EAF
defines += USB_PID=0x0004
defines += USB_MANUFACTURER=\"Unknown\"
# source directories
# these are the initial directories to search for sources
# relative to this build (root) directory
# if you use libraries either put them in a sub-directory in src
srcdir := src
# or add it here
#srcdir += library1
#srcdir += library2
# points to the root folder of stm32duino libmaple core
# this should be 1 level above STM32F1 folder
# use of this is not encouraged, it is safer to copy the STM32F1
# folder into the current directory
# omit the final slash after the directory
core_root := .
# these are the source directories for the libmaple core
# and variant, normally they stay unchanged
# if you want to place the libmaple core directory somewhere else,
# define core_root above
coredir := $(core_root)/STM32F1/cores/maple
variantdir += $(core_root)/STM32F1/variants/$(variant)
coredir += $(variantdir)
#this is the ld script in STM32F1/variants/$(variant)/ld to use
ldscript := bootloader_20.ld
#the includes i.e. the -Ipath needs to be exlicitly stated
#no automatic recursive searching
#if you use libraries you may want to add it here
includedir += STM32F1/cores/maple/
includedir += STM32F1/system/libmaple/
includedir += STM32F1/system/libmaple/include/
includedir += STM32F1/system/libmaple/stm32f1/include/series/
includedir += STM32F1/system/libmaple/usb/stm32f1/
includedir += STM32F1/system/libmaple/usb/usb_lib/
includedir += STM32F1/variants/maple_mini/
#if you use core_root, you would need to add that as a prefix
#includedir := $(addprefix $(core_root)/,$(includedir))
# update this to match
# this should be the install base location of ARM_NONE_EABI_GCC toolchain
ARM_NONE_EABI_PATH := /opt5/opt/gcc-arm-none-eabi-6-2017-q1-update
# this should be the location of the arm standard libraries c & c++
# the arm-none-eabi/lib select the folder matching the arch
# compile options e.g. thumb and v7-m
LD_TOOLCHAIN_PATH := $(ARM_NONE_EABI_PATH)/arm-none-eabi/lib/thumb/v7-m
# recursive wildcard function, call with params:
# - start directory (finished with /) or empty string for current dir
# - glob pattern
# (taken from http://blog.jgc.org/2011/07/gnu-make-recursive-wildcard-function.html)
rwildcard=$(foreach d,$(wildcard $1*),$(call rwildcard,$d/,$2) $(filter $(subst *,%,$2),$d))
cfiles := $(strip $(foreach s, $(srcdir), $(call rwildcard,$(s),*.c)))
cxxfiles := $(strip $(foreach s, $(srcdir), $(call rwildcard,$(s),*.cpp)))
asfiles := $(strip $(foreach s, $(srcdir), $(call rwildcard,$(s),*.S)))
core_cfiles += $(subst $(core_root)/,,$(strip $(foreach s, $(coredir), $(call rwildcard,$(s),*.c))))
core_cxxfiles += $(subst $(core_root)/,,$(strip $(foreach s, $(coredir), $(call rwildcard,$(s),*.cpp))))
core_asfiles += $(subst $(core_root)/,,$(strip $(foreach s, $(coredir), $(call rwildcard,$(s),*.S))))
src_files := $(cfiles) $(cxxfiles) $(asfiles)
core_files := $(core_cfiles) $(core_cxxfiles) $(core_asfiles)
files := $(src_files) $(core_files)
sdirs := $(sort $(dir $(files)))
#hfiles := $(foreach s, $(includedir), $(call rwildcard,$(s),*.h))
#hfiles += $(foreach s, $(srcdir), $(call rwildcard,$(s),*.h))
#incdirs = $(sort $(dir $(hfiles)))
TOOLPREFIX := arm-none-eabi-
CC = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)gcc
CXX = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)g++
AS = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)as
OBJCOPY = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)objcopy
OBJDUMP = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)objdump
AR = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)ar
SIZE = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)size
NM = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)nm
LD = $(ARM_NONE_EABI_PATH)/bin/$(TOOLPREFIX)ld
RM = /usr/bin/rm
MKDIR = /usr/bin/mkdir -p
TEST = /usr/bin/test
DEFINES := $(addprefix -D,$(defines))
INCLUDES := $(addprefix -I,$(includedir))
#optimise
# -O0 - none
# -Os - optimise size
# -O1 - optimise
# -O2 - optimise more
# -O3 - optimise most
# -Og - optimise debug
OFLAG := -Os
#debug
# default none
# -g - debug
# -g1 - minimal
# -g3 - maximal
DFLAG = -g1
COMMON_OFLAGS := -Wl,--gc-sections $(OFLAG) $(DFLAG) \
-ffunction-sections -fdata-sections \
-fmessage-length=0 -fsigned-char \
-ffreestanding -fno-move-loop-invariants \
--specs=nano.specs -Wall -Wextra
TARGET_FLAGS += -mcpu=cortex-m3 -march=armv7-m -mthumb \
$(INCLUDES) $(DEFINES)
GLOBAL_CFLAGS := $(COMMON_OFLAGS) $(TARGET_FLAGS)
TARGET_CFLAGS :=
GLOBAL_CXXFLAGS := -fno-rtti -fno-exceptions \
-fno-use-cxa-atexit -fno-threadsafe-statics \
$(COMMON_OFLAGS) \
$(TARGET_FLAGS)
TARGET_CXXFLAGS :=
GLOBAL_ASFLAGS := $(TARGET_FLAGS)
#TARGET_ASFLAGS := -Wl,--gc-sections $(OFLAG) $(DFLAG) -Xassembler -Wall
LD_SCRIPT_PATH := $(variantdir)/ld/$(ldscript)
# -nostdlib
# -nodefaultlibs
# -nostartfiles
# -Wl,--gc-sections
GLOBAL_LDFLAGS := --specs=nano.specs \
-Xlinker --gc-sections
TARGET_LDFLAGS := -Xlinker -T$(LD_SCRIPT_PATH) \
-mcpu=cortex-m3 -mthumb -march=armv7-m \
-L $(variantdir)/ld
CFLAGS = $(GLOBAL_CFLAGS) $(TARGET_CFLAGS)
CXXFLAGS = $(GLOBAL_CXXFLAGS) $(TARGET_CXXFLAGS)
CPPFLAGS =
ASFLAGS = $(GLOBAL_ASFLAGS) $(TARGET_ASFLAGS)
# Add toolchain directory to LD search path
TOOLCHAIN_LDFLAGS := -L $(LD_TOOLCHAIN_PATH)
LDFLAGS = $(GLOBAL_LDFLAGS) $(TARGET_LDFLAGS) $(TOOLCHAIN_LDFLAGS)
#build lists of object files relative to $(out_dir)
COBJS = $(addprefix $(out_dir)/,$(patsubst %.c,%.o,$(cfiles)))
CXXOBJS = $(addprefix $(out_dir)/,$(patsubst %.cpp,%.o,$(cxxfiles)))
ASOBJS = $(addprefix $(out_dir)/,$(patsubst %.S,%.o,$(asfiles)))
CORE_COBJS = $(addprefix $(out_dir)/,$(patsubst %.c,%.o,$(core_cfiles)))
CORE_CXXOBJS = $(addprefix $(out_dir)/,$(patsubst %.cpp,%.o,$(core_cxxfiles)))
CORE_ASOBJS = $(addprefix $(out_dir)/,$(patsubst %.S,%.o,$(core_asfiles)))
variant.ELF = $(out_dir)/$(variant).elf
variant.BIN = $(out_dir)/$(variant).bin
.PHONY: all clean mkdir
all: mkdir $(variant.BIN)
@echo
@$(SIZE) $(variant.ELF)
@echo
@ls -l $(variant.BIN)
@echo
@$(OBJDUMP) --section-headers $(variant.ELF)
@echo
@echo Source dirs
@echo $(srcdir) $(coredir) | sed 's/ /\n/g'
@echo
@echo $(sort $(dir $(src_files))) | sed 's/ /\n/g'
@echo $(addprefix $(core_root)/,$(sort $(dir $(core_files)))) | sed 's/ /\n/g'
@echo
@echo Includes
@echo $(INCLUDES) | sed 's/ /\n/g'
@echo
@echo Defines
@echo $(DEFINES) | sed 's/ /\n/g'
$(variant.BIN): $(variant.ELF)
$(OBJCOPY) -v -Obinary $(variant.ELF) $@
$(variant.ELF): $(ASOBJS) $(COBJS) $(CXXOBJS) \
$(CORE_COBJS) $(CORE_CXXOBJS) $(CORE_ASOBJS)
$(CXX) $(LDFLAGS) -o $@ -Wl,-Map,$(out_dir)/$(variant).map $+
# General directory independent build rules, generate dependency information
$(COBJS): $(out_dir)/%.o: %.c
$(CC) $(CFLAGS) -MMD -MP -MF $(@:%.o=%.d) -MT $@ -o $@ -c $<
$(CXXOBJS): $(out_dir)/%.o: %.cpp
$(CXX) $(CXXFLAGS) -MMD -MP -MF $(@:%.o=%.d) -MT $@ -o $@ -c $<
$(ASOBJS): $(out_dir)/%.o: %.S
$(CC) $(ASFLAGS) -MMD -MP -MF $(@:%.o=%.d) -MT $@ -o $@ -c $<
$(CORE_COBJS): $(out_dir)/%.o: $(core_root)/%.c
$(CORE_CXXOBJS): $(out_dir)/%.o: $(core_root)/%.cpp
$(CORE_ASOBJS): $(out_dir)/%.o: $(core_root)/%.S
# create the build directories
tgtdirs := $(addsuffix .dir,$(addprefix $(out_dir)/,$(sdirs)))
mkdir: $(tgtdirs)
# the .dir file is a marker file that the directory is created
$(tgtdirs) : $(out_dir)/.dir
$(MKDIR) $(dir $@)
@touch $@
$(out_dir)/.dir:
$(MKDIR) $(dir $@)
@touch $@
clean:
@echo clean
$(RM) -r $(out_dir)
DEPENDS := $(COBJS:%.o=%.d) $(CXXOBJS:%.o=%.d) $(ASOBJS:%.o=%.d)
DEPENDS += $(CORE_COBJS:%.o=%.d) $(CORE_CXXOBJS:%.o=%.d) $(CORE_ASOBJS:%.o=%.d)
-include $(DEPENDS)
