Starting ADC with DMA Mode causes chip to freeze
Eldi4
Post by Eldi4 »
As explained by the thread title, my stm32f103c8t6 (blue pill) freezes when i call HAL_ADC_Start_DMA() function, i use STM32Core 1.8.0.
here is my whole code :
#include <hd44780.h>
#include <hd44780ioClass/hd44780_pinIO.h> // Arduino pin i/o class header
#include "stm32f1xx_hal.h"
#include <HardwareTimer.h>
#define CH2_PWM PB7
#define LCD_RS       PB12
#define LCD_EN       PB13
#define LCD_D4       PB14
#define LCD_D5       PB15
#define LCD_D6       PC14
#define LCD_D7       PC15
hd44780_pinIO lcd(LCD_RS, LCD_EN, LCD_D4, LCD_D5, LCD_D6, LCD_D7);
static void MX_GPIO_Init(void)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOB, GPIO_PIN_10, GPIO_PIN_RESET);
  /*Configure GPIO pin : PB10 */
  GPIO_InitStruct.Pin = GPIO_PIN_10;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
ADC_HandleTypeDef hadc1;
static void MX_ADC1_Init(void)
  /* USER CODE BEGIN ADC1_Init 0 */
  /* USER CODE END ADC1_Init 0 */
  ADC_ChannelConfTypeDef sConfig = {0};
  /* USER CODE BEGIN ADC1_Init 1 */
  /* USER CODE END ADC1_Init 1 */
  /** Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
  hadc1.Init.ContinuousConvMode = ENABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 2;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    Error_Handler();
  /** Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_6;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_CONVERSIONCLOCKCYCLES_SAMPLETIME_7CYCLES5;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK){
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_9;
  sConfig.Rank = ADC_REGULAR_RANK_2;
    Error_Handler();
  if (HAL_ADCEx_Calibration_Start(&hadc1) != HAL_OK){
    Error_Handler();
static void MX_DMA_Init(void)
  /* DMA controller clock enable */
  __HAL_RCC_DMA1_CLK_ENABLE();
  /* DMA interrupt init */
  /* DMA1_Channel1_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
void ErrorHandler(void){
  while(1){
    HAL_GPIO_TogglePin (GPIOB, GPIO_PIN_10);
    HAL_Delay(100);
uint32_t adc[2048];
  HAL_Init();
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_ADC1_Init();
  HAL_ADC_Start(&hadc1);
  HAL_ADC_Start_DMA(&hadc1, adc, 2048);
  lcd.begin(20,4);
  lcd.clear();
  TIM_TypeDef *Instance = (TIM_TypeDef *)pinmap_peripheral(digitalPinToPinName(CH2_PWM), PinMap_PWM);
  uint32_t channel = STM_PIN_CHANNEL(pinmap_function(digitalPinToPinName(CH2_PWM), PinMap_PWM));
  // Instantiate HardwareTimer object. Thanks to 'new' instantiation, HardwareTimer is not destructed when setup function is finished.
  MyTim->setMode(channel, TIMER_OUTPUT_COMPARE_PWM1, CH2_PWM);
  // MyTim->setPrescaleFactor(8); // Due to setOverflow with MICROSEC_FORMAT, prescaler will be computed automatically based on timer input clock
  MyTim->setOverflow(20, MICROSEC_FORMAT); // 100000 microseconds = 100 milliseconds
  MyTim->setCaptureCompare(channel, 30, PERCENT_COMPARE_FORMAT); // 50%
  MyTim->resume();
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("ADC PA6 : ");
  lcd.print(adc[0]);
  lcd.setCursor(0,1);
  lcd.print("ADC PB1 : ");
  lcd.print(adc[1]);
  lcd.setCursor(0,2);
  lcd.print(adc[2]);
  lcd.print(", ");
  lcd.print(adc[3]);
  lcd.print(", ");
  lcd.print(adc[4]);
  lcd.print(", ");
  lcd.print(adc[5]);
  lcd.print(", ");
  HAL_Delay(200);
I also had USB problem with my blue pill, cant recognized by any pc even after changing usb pull up resistor, but i guess this is risk of using china conterfeit.
did this DMA problem could actually because of counterfeit defect too?
Eldi4
Re: Starting ADC with DMA Mode causes chip to freeze
Post by Eldi4 »
using adc with Interrupt freezes my stm32 too, i guess i do something wrong.
#define CH2_PWM PB7
#define LCD_RS       PB12
#define LCD_EN       PB13
#define LCD_D4       PB14
#define LCD_D5       PB15
#define LCD_D6       PC14
#define LCD_D7       PC15
  /** Common config
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.ContinuousConvMode = DISABLE;
  hadc1.Init.NbrOfConversion = 1;
    Error_Handler();
  sConfig.SamplingTime = ADC_CONVERSIONCLOCKCYCLES_SAMPLETIME_239CYCLES5;
    Error_Handler();
    Error_Handler();
    Error_Handler();
  while(1){
    HAL_Delay(100);
unsigned long thisone,elapsed,lastone;
int idx;
uint32_t adc[2];
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc1)
  /* time between interrupts
  thisone = micros();
  elapsed = thisone - lastone;
  lastone = thisone;
  /* Get the converted value of regular channel */
  adc[0] = HAL_ADC_GetValue(hadc1);
  HAL_Init();
  MX_GPIO_Init();
  MX_ADC1_Init();
  HAL_NVIC_EnableIRQ(ADC1_IRQn);
  if(HAL_ADC_Start_IT(&hadc1) != HAL_OK)
    /***** HAL_ADC_Start_IT() always returns HAL_OK ******/
    Error_Handler();
  lcd.begin(20,4);
  lcd.clear();
  MyTim->resume();
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print(adc[0]);
  lcd.setCursor(0,1);
  lcd.print(adc[1]);
  lcd.setCursor(0,2);
  lcd.print(elapsed);
  lcd.print("uS");
  lcd.setCursor(0,3);
  lcd.print(millis()/1000);
  HAL_Delay(200);
Answers: 92
You have to disable HAL ADC module usage by Arduino API because the MSP init is defined and I guess this is the reason why it freeze.
See this example:
viewtopic.php?f=41&t=110
To achieve this I simply disable the HAL ADC usage by the arduino API by defining -DHAL_ADC_MODULE_ONLY in build_opt.h file.
Eldi4
Post by Eldi4 »
fpiSTM wrote: Sat May 02, 2020 4:59 am You have to disable HAL ADC module usage by Arduino API because the MSP init is defined and I guess this is the reason why it freeze.
See this example:
creating build_opt.h right beside my .ino file and fill it with "-DHAL_ADC_MODULE_ONLY" doesnt work.
I've managed to get multichannel with polling working before, then about to step it up to DMA but no luck.
stas2z
Answers: 8
Post by stas2z »
i can't see important parts in your code
at least i can't find init of analog pins, dma init and linking dma with adc
Eldi4
Post by Eldi4 »
stas2z wrote: Sat May 02, 2020 8:19 am i can't see important parts in your code
Im sorry this is my first time dealing with DMA, but i see a lot of cubeide tutorial and examples just using those functions to set up DMA and ADC.
or even stm32duino examples, but in F4 series like this https://github.com/palmerr23/Black-F407 ... on_DMA.ino
stas2z
Answers: 8
Post by stas2z »
that ino you posted have separate .c/.h files with init code
check it
https://github.com/palmerr23/Black-F407 ... c#L81-L108
that's the main part you missing imho
Eldi4
Post by Eldi4 »
Ahhh, just realized it!, thanks for pointing it out!,
Will try it and see if it's going to work.
Eldi4
Post by Eldi4 »
It's working!, thanks a lot for the helps!
