UART speed
jenspogo
UART speed
Post by jenspogo »
Hey guys,
I would like to speed up my UART communication.
actually it looks like this:
I would like to increase the time between the bits where nothing happens.
I'm using a Bluepill Board with the offical core.
My Code looks like this:
#define SAMPLERATE 2000000
HardwareSerial  mySerial(PA3, PA2); // RX, TX
int i = 64;
  pinMode(LED_BUILTIN, OUTPUT);
  // set the data rate for the HardwareSerial port
  mySerial.begin(SAMPLERATE);
void loop() { // run over and over
  mySerial.write("<");
  mySerial.write("ABCDEFGHIJKLMNOPQRSTUVWXYZ");
//  while (i <(94))
//  mySerial.write(i);
//  i++;
  mySerial.write(">");
  delay(10);                       // wait for a second
  digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
i = 64;
Im using "<" and ">" as start and stop on the receiver.
Is there any possibility?
Greetings,
Jens
Re: UART speed
Speed up? Like compressing but not really increasing the BAUD? Ummmm ... Serial is governed by Standards:
https://www.sealevel.com/support/overvi ... standards/
Re: https://www.electronicdesign.com/techno ... -baud-rate
Staying in the Arduino framework, we could just choose to not utilize the default serial and use SPI instead:
https://www.sciencedirect.com/topics/co ... /baud-rate
Of course, the above would require SPI ---> Serial conversion on the target end!
You can also just change the protocol:
https://forum.arduino.cc/index.php?topi ... msg2527550
If you really want to go structured, you can send/receive C structs. Reference Struct_send and Struct_receive libs:
https://github.com/LowPowerLab/RFM69/tr ... r/Examples
Answers: 8
Re: UART speed
remove delay(10)...
