Problem with SPI on Arduino IDE
Astroghost
Post by Astroghost »
I all ,
i can't get an RFM95W LORA Module working with an STM32 L432KC board.
The library working with it is https://github.com/matthijskooijman/arduino-lmic
What are the default SPI ports compatible with arduino on this board
MISO --> PB_5 ?
MOSI --> PB_4 ?
SCLK --> PB_3 ?
SS --> PA_4 ?
I've the same problem with an epaper screen , impossible to make it working with PI on this board ( L432KC)
For example it work with an NUCLEO64 L476RG
François
Answers: 92
Re: Problem with SPI on Arduino IDE
By default SPI instance use this:
https://github.com/stm32duino/Arduino_C ... #L180-L202
// Default for Arduino connector compatibility
// SPI Definitions
#ifndef PIN_SPI_SS
#define PIN_SPI_SS                  10
#ifndef PIN_SPI_SS1
#define PIN_SPI_SS1                 4
#ifndef PIN_SPI_SS2
#define PIN_SPI_SS2                 7
#ifndef PIN_SPI_SS3
#define PIN_SPI_SS3                 8
#ifndef PIN_SPI_MOSI
#define PIN_SPI_MOSI                11
#ifndef PIN_SPI_MISO
#define PIN_SPI_MISO                12
#ifndef PIN_SPI_SCK
#define PIN_SPI_SCK                 13
In case of Nucleo L432KC:
https://github.com/stm32duino/Arduino_C ... .h#L40-L43
#define PA11 10
#define PB5  11
#define PB4  12
#define PB3  13 // LED
So your pin description seems not correct.
