WeAct Studio STM32F411CEU6 BlackPill v3.1 crystal is 8 MHz
Fziegler_076
Re: WeAct Studio STM32F411CEU6 BlackPill v3.1 crystal is 8 MHz
Post by Fziegler_076 »
Friends, thanks for the tips!
So, I bought 10 8 MHz HSE boards.
All the boards are stitched by the manufacturer with a demo program with a flashing LED, and they all flash the LED when connected, which means that all the boards are working!
1. All boards with a frequency of 8 MHz - I took a photo and will attach it soon.
2. The boards switch to DFU mode by pressing the buttons, as you wrote
                       STM32CubeProgrammer v2.16.0
USB speed   : Full Speed (12MBit/s)
Manuf. ID   : STMicroelectronics
Product ID  : STM32  BOOTLOADER
SN          : 389E33553233
DFU protocol: 1.1
Board       : --
Device ID   : 0x0431
Device name : STM32F411xC/E
Flash size  : 512 KBytes (default)
Device type : MCU
Revision ID : --
Device CPU  : Cortex-M4
Memory Programming ...
  File          : Blink.ino.bin
  Address       : 0x08000000
sector 0000 does not exist
sector 0001 does not exist
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:00.493
RUNNING Program ...
  Address:      : 0x8000000
3. I select "USB CDC Serial", but after flashing the program into the microcontroller, the COM port is not displayed on PC devices (I checked in Windows Device Manager)- so the microcontroller does not start!
4. I have corrected the file C:\Users\Admin\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\variants\STM32F4xx\F411C(C-E)(U-Y)\variant_BLACKPILL_F411CE.cpp
  RCC_OscInitStruct.PLL.PLLN = 48;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
  RCC_OscInitStruct.PLL.PLLQ = 8;
Fziegler_076
Added a corrected file C:\Users\Admin\AppData\Local\Arduino15\packages\STMicroelectronics\hardware\stm32\2.4.0\variants\STM32F4xx\F411C(C-E)(U-Y)\variant_BLACKPILL_F411CE.cpp
I tried your advice, but the boards still don't work after the firmware.
Now I will try to flash through the stm32cube programmer
variant_BLACKPILL_F411CE.zip
(1.33 KiB) Downloaded 34 times
Fziegler_076
1. Updated STM32 Library to version 2.7.1
2. Performed the download via the stm32 cube programmer DFU
^ this won't work, try
  RCC_OscInitStruct.PLL.PLLN = 192;
  RCC_OscInitStruct.PLL.PLLQ = 4;
fcpu is HSE 8 Mhz / M * N / P = 8 / 8 * 192 / 2 = 96 Mhz
and usb bus speeds is HSE 8 Mhz / M * N / Q = 8 / 8 * 192 / 4 = 48 Mhz
Fziegler_076
Unfortunately, this does not work either (
(1.33 KiB) Downloaded 32 times
The values given and used are correct, yup check the LED, try to use a led connected to a different pin manually e.g. on the headers.
I've more than once used boards with a 'defective' LED, sometimes they put the LED reversed, that'd never light up.
manufacturing error. no need to look at schematic. if we assume that PC13 is correct.
the other way is to measure pins with a volt meter.
Fziegler_076
The documentation for the board version 3.1 indicates that the LED is connected to the PC 13. I indicated it correctly in the program
C:/Users/Admin/Downloads/WeActStudio.MiniSTM32F4x1-master/WeActStudio.MiniSTM32F4x1-master/HDK/MiniF4x1Cx_V31.pdf
Fziegler_076
I have tested this on 3 boards.
I think that the microcontroller freezes, because after the firmware, the COM port does not appear in the computer devices, although I turn on the "USB CDC Serial" setting
if you really want to get to the bottom of that, the only way seemed to be to use a st-link v2
https://octopart.com/search?q=st-link+v ... SD&specs=0
then you can try to debug that, but that would require setting up your IDE to work properly so that it actually trace the codes
for those PLL M,N,P.Q settings USB should work, so the virtual com port should appear.
but that is beyond basic test.
At a very least, if you turn on a led it should light up.
In fact, according to the schematic, just
pinMode(PC13, OUTPUT);
would light up the led, if the led is working correctly.
otherwise to check, use a led to check manually on the header pins or use a voltmeter (e.g. multi-meter) to measure that.
a HIGH level on a pin is close to VDD 3.3v
in fact for the led test, if you think that the crystal has a problem you can even try
void SystemClock_Config() {
return; // <- return on entry, so no clock setting is done
this will run on HSI (internal oscillator) 16 Mhz (no usb), select uart for serial so that it won't hang on the usb. but the led should still light up if
	pintMode(PC13, OUTPUT);
is run.
the stm32cube programmer log messages seem to indicate that the sketch firmware is installed correctly.
I'm not sure if that 'sector 0 does not exist' message meant any errors.
Fziegler_076
Thanks for the tips!
Now I will solder the connector to the board and try to flash it through ST-LINK.
